Part Number: AM6411
Other Parts Discussed in Thread: AM6442,
The customer requests a motherboard design
Compatibility: The designed AM64 motherboard needs to be compatible with AM64 series main control chips, from the lowest version AM6411 to the highest version AM6442, ensuring pin-to-pin compatibility. The main control chips can be switched without changing the circuit board design. May I ask if it is compatible? What are the real differences between them? Is there any document detailing them?
