DM368 找不到库
Other Parts Discussed in Thread: TMS320DM368
安装好dvsdk_dm368-evm_4_02_00_06_setuplinux.bin
TMS320DM368_Software_Developers_Guide.pdf
文档
setup.sh 都没有问题
执行
source /opt/dvsdk368/linux-devkit/environment-setup
执行
makefile
include /opt/dvsdk368/Rules.make
a:a.c
arm-none-linux-gnueabi-gcc -o a a.c
a.c:8:30: error: ti/sdo/ce/Engine.h: No such file or directory
a.c:9:33: error: ti/sdo/ce/CERuntime.h: No such file or directory
a.c:11:30: error: ti/sdo/dmai/Dmai.h: No such file or directory
a.c:12:31: error: ti/sdo/dmai/Sound.h: No such file or directory
a.c:13:32: error: ti/sdo/dmai/Loader.h: No such file or directory
a.c:14:34: error: ti/sdo/dmai/ce/Sdec1.h: No such file or directory
  • 请问是否有修改Rules.make里面的内容以匹配你的自己机器上的路径?
  • [linux-devkit]:~/c> ls /opt/dvsdk368/
    bin                              gstreamer-ti_svnr919
    codec-engine_2_26_02_11          linux-devkit
    codecs-dm365_4_02_00_00          linuxutils_2_26_01_02
    dm365mm-module_01_00_03          Makefile
    dmai_2_20_00_15                  psp
    docs                             Rules.make
    dvsdk-demos_4_02_00_01           setup.sh
    dvtb_4_20_18                     setup_uimage-tftp_fs-nfs.minicom
    etc                              usr
    example-applications             xdais_6_26_01_03
    filesystem                       xdctools_3_16_03_36
    framework-components_2_26_00_01
    [linux-devkit]:~/c>
    [linux-devkit]:~/c> cat  /opt/dvsdk368/Rules.make
    # Define target platform.
    PLATFORM=dm368
    # The installation directory of the DVSDK.
    DVSDK_INSTALL_DIR=/opt/dvsdk368
    # For backwards compatibility
    DVEVM_INSTALL_DIR=$(DVSDK_INSTALL_DIR)
    # Where the Codec Engine package is installed.
    CE_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/codec-engine_2_26_02_11
    # Where the codecs are installed.
    CODEC_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/codecs-dm365_4_02_00_00
    # Where DMAI package is installed.
    DMAI_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dmai_2_20_00_15
    # Where the SDK demos are installed
    DEMO_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dvsdk-demos_4_02_00_01
    # Where the DVTB package is installed.
    DVTB_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dvtb_4_20_18
    # Where the Framework Components package is installed.
    FC_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/framework-components_2_26_00_01
    # Where the DM365mm module is installed.
    DM365MM_MODULE_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/dm365mm-module_01_00_03
    # Where the PSP is installed.
    PSP_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/psp
    # Where the MFC Linux Utils package is installed.
    LINUXUTILS_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/linuxutils_2_26_01_02
    CMEM_INSTALL_DIR=$(LINUXUTILS_INSTALL_DIR)
    # Where the XDAIS package is installed.
    XDAIS_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/xdais_6_26_01_03
    # Where the RTSC tools package is installed.
    XDC_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/xdctools_3_16_03_36
    # The directory that points to your kernel source directory.
    LINUXKERNEL_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/psp/linux-2.6.32.17-psp03.01.01.39
    # Where temporary Linux headers and libs are installed.
    LINUXLIBS_INSTALL_DIR=$(DVSDK_INSTALL_DIR)/linux-devkit/arm-none-linux-gnueabi/usr
    # The prefix to be added before the GNU compiler tools (optionally including # path), i.e. "arm_v5t_le-" or "/opt/bin/arm_v5t_le-".
    CSTOOL_DIR=/opt/arm-2009q1-203/
    CSTOOL_PREFIX=$(CSTOOL_DIR)/bin/arm-none-linux-gnueabi-
    MVTOOL_DIR=$(CSTOOL_DIR)
    MVTOOL_PREFIX=$(CSTOOL_PREFIX)
    # Where to copy the resulting executables
    EXEC_DIR=/root/targetfs
    [linux-devkit]:~/c>
  • linux-devkit]:~/c> export
    declare -x AR="arm-none-linux-gnueabi-ar"
    declare -x AS="arm-none-linux-gnueabi-as"
    declare -x CC="arm-none-linux-gnueabi-gcc"
    declare -x COLORTERM="gnome-terminal"
    declare -x CONFIG_SITE="/opt/dvsdk368/linux-devkit//site-config"
    declare -x CPATH="/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/include:/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/include:"
        为什么这里是两个"/"
    declare -x CPP="arm-none-linux-gnueabi-gcc -E"
    declare -x DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-ZkOxAjCuwU,guid=5e191ace5d96bb7c1740a77c4f7bbd1f"
    declare -x DEFAULTS_PATH="/usr/share/gconf/gnome.default.path"
    declare -x DESKTOP_SESSION="gnome"
    declare -x DISPLAY=":0.0"
    declare -x GDMSESSION="gnome"
    declare -x GDM_KEYBOARD_LAYOUT="us"
    declare -x GDM_LANG="en_US.UTF-8"
    declare -x GNOME_DESKTOP_SESSION_ID="this-is-deprecated"
    declare -x GNOME_KEYRING_CONTROL="/tmp/keyring-bqLXmJ"
    declare -x GNOME_KEYRING_PID="1107"
    declare -x GTK_MODULES="canberra-gtk-module"
    declare -x HOME="/root"
    declare -x LANG="en_US.UTF-8"
    declare -x LESSCLOSE="/usr/bin/lesspipe %s %s"
    declare -x LESSOPEN="| /usr/bin/lesspipe %s"
    declare -x LIBTOOL_SYSROOT_PATH="/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi"
        为什么这里是两个"/"
    declare -x LOGNAME="root"
    declare -x LS_COLORS="rs=0:di=01;34:ln=01;36:hl=44;37:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:"
    declare -x MANDATORY_PATH="/usr/share/gconf/gnome.mandatory.path"
    declare -x NM="arm-none-linux-gnueabi-nm"
    declare -x OBJCOPY="arm-none-linux-gnueabi-objcopy"
    declare -x OBJDUMP="arm-none-linux-gnueabi-objdump"
    declare -x OE_QMAKE_AR="arm-none-linux-gnueabi-ar"
    declare -x OE_QMAKE_CC="arm-none-linux-gnueabi-gcc"
    declare -x OE_QMAKE_CXX="arm-none-linux-gnueabi-g++"
    declare -x OE_QMAKE_INCDIR_QT="/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/include/qtopia"
    declare -x OE_QMAKE_LDFLAGS="-L/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/lib -Wl,-rpath-link,/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/lib -Wl,-O1 -Wl,--hash-style=gnu'
    declare -x OE_QMAKE_LIBDIR_QT="/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/lib"
    declare -x OE_QMAKE_LINK="arm-none-linux-gnueabi-g++"
    declare -x OE_QMAKE_MOC="/opt/dvsdk368/linux-devkit//bin/moc4"
    declare -x OE_QMAKE_QDBUSCPP2XML="/opt/dvsdk368/linux-devkit//bin/qdbuscpp2xml4"
    declare -x OE_QMAKE_QDBUSXML2CPP="/opt/dvsdk368/linux-devkit//bin/qdbusxml2cpp4"
    declare -x OE_QMAKE_QT_CONFIG="/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/qconfig.pri"
    declare -x OE_QMAKE_RCC="/opt/dvsdk368/linux-devkit//bin/rcc4"
    declare -x OE_QMAKE_STRIP="echo"
    declare -x OE_QMAKE_UIC="/opt/dvsdk368/linux-devkit//bin/uic4"
    declare -x OE_QMAKE_UIC3="/opt/dvsdk368/linux-devkit//bin/uic34"
    declare -x OLDPWD="/root"
    declare -x ORBIT_SOCKETDIR="/tmp/orbit-root"
    declare -x PATH="/opt/dvsdk368/linux-devkit//bin:/opt/arm-2009q1-203//bin:/opt/dvsdk368/linux-devkit//bin:/opt/arm-2009q1-203//bin:/opt/arm-2009q1-203/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games"
    declare -x PKG_CONFIG_ALLOW_SYSTEM_LIBS="1"
    declare -x PKG_CONFIG_PATH="/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/lib/pkgconfig"
    declare -x PKG_CONFIG_SYSROOT_DIR="/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi"
    declare -x PS1="\\[\\e[32;1m\\][linux-devkit]\\[\\e[0m\\]:\\w> "
    declare -x PWD="/root/c"
    declare -x QMAKESPEC="/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/linux-g++"
    declare -x RANLIB="arm-none-linux-gnueabi-ranlib"
    declare -x SDK_PATH="/opt/dvsdk368/linux-devkit/"
    declare -x SESSION_MANAGER="local/a-desktop:@/tmp/.ICE-unix/1126,unix/a-desktop:/tmp/.ICE-unix/1126"
    declare -x SHELL="/bin/bash"
    declare -x SHLVL="1"
    declare -x SPEECHD_PORT="6560"
    declare -x SSH_AGENT_PID="1191"
    declare -x SSH_AUTH_SOCK="/tmp/keyring-bqLXmJ/ssh"
    declare -x STRIP="arm-none-linux-gnueabi-strip"
    declare -x TARGET_SYS="arm-none-linux-gnueabi"
    declare -x TERM="xterm"
    declare -x TOOLCHAIN_PATH="/opt/arm-2009q1-203/"
    declare -x USER="root"
    declare -x USERNAME="root"
    declare -x WINDOWID="62914563"
    declare -x XAUTHORITY="/var/run/gdm/auth-for-root-0wtTNq/database"
    declare -x XDG_CONFIG_DIRS="/etc/xdg/xdg-gnome:/etc/xdg"
    declare -x XDG_DATA_DIRS="/usr/share/gnome:/usr/local/share/:/usr/share/"
    declare -x XDG_SESSION_COOKIE="08eca9deab4a6915351d1eba4f7ad008-1333509405.114481-1154226377"
    dmai_2_20_00_15                  psp
    docs                             Rules.make
    etc                              usr
    [linux-devkit]:~/c> cat Rules.m^C
    PLATFORM=dm368
  • 修改/opt/dvsdk368/linux-devkit/environment-setup  问题依然在
    [linux-devkit]:~/c> export
    declare -x CONFIG_SITE="/opt/dvsdk368/linux-devkit/site-config"
    declare -x CPATH="/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi/usr/include:/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi/usr/include:/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/include:/opt/dvsdk368/linux-devkit//arm-none-linux-gnueabi/usr/include:"
    declare -x LIBTOOL_SYSROOT_PATH="/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi"
    declare -x OE_QMAKE_INCDIR_QT="/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi/usr/include/qtopia"
    declare -x OE_QMAKE_LDFLAGS="-L/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi/usr/lib -Wl,-rpath-link,/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi/usr/lib -Wl,-O1 -Wl,--hash-style=gnu"
    declare -x OE_QMAKE_LIBDIR_QT="/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi/usr/lib"
    declare -x OE_QMAKE_MOC="/opt/dvsdk368/linux-devkit/bin/moc4"
    declare -x OE_QMAKE_QDBUSCPP2XML="/opt/dvsdk368/linux-devkit/bin/qdbuscpp2xml4"
    declare -x OE_QMAKE_QDBUSXML2CPP="/opt/dvsdk368/linux-devkit/bin/qdbusxml2cpp4"
    declare -x OE_QMAKE_QT_CONFIG="/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/qconfig.pri"
    declare -x OE_QMAKE_RCC="/opt/dvsdk368/linux-devkit/bin/rcc4"
    declare -x OE_QMAKE_UIC="/opt/dvsdk368/linux-devkit/bin/uic4"
    declare -x OE_QMAKE_UIC3="/opt/dvsdk368/linux-devkit/bin/uic34"
    declare -x PATH="/opt/dvsdk368/linux-devkit/bin:/opt/arm-2009q1-203/bin:/opt/dvsdk368/linux-devkit/bin:/opt/arm-2009q1-203//bin:/opt/dvsdk368/linux-devkit//bin:/opt/arm-2009q1-203//bin:/opt/dvsdk368/linux-devkit//bin:/opt/arm-2009q1-203//bin:/opt/arm-2009q1-203/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games"
    declare -x PKG_CONFIG_PATH="/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi/usr/lib/pkgconfig"
    declare -x PKG_CONFIG_SYSROOT_DIR="/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi"
    declare -x QMAKESPEC="/opt/dvsdk368/linux-devkit/arm-none-linux-gnueabi/usr/share/qtopia/mkspecs/linux-g++"
    declare -x SDK_PATH="/opt/dvsdk368/linux-devkit"
    declare -x TOOLCHAIN_PATH="/opt/arm-2009q1-203"
