AM3354: 拔插U盘导致后续usb无法再生成节点,usb无法使用
Part Number: AM3354
Other Parts Discussed in Thread: TPS65910
使用4.1.18版本 内核
拔插U盘报cppi41_stop_chan警告,后续再插入u盘无法生成/dev/sda*节点
7.465741] usb 2-1.2: new high-speed USB device number 8 using musb-hdrc
[   47.586802] usb 2-1.2: New USB device found, idVendor=14cd, idProduct=2536
[   47.593746] usb 2-1.2: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[   47.601383] usb 2-1.2: Product: Mass Storage Device
[   47.606319] usb 2-1.2: Manufacturer: Generic USB Device
[   47.612034] usb 2-1.2: SerialNumber: 2536201609180000
[   47.624742] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[   47.640044] scsi host5: usb-storage 2-1.2:1.0
[   48.646522] scsi 5:0:0:0: Direct-Access     Mass     Storage Device   1.00 PQ: 0 ANSI: 0 CCS
[   48.661282] sd 5:0:0:0: [sda] 15630336 512-byte logical blocks: (8.00 GB/7.45 GiB)
[   48.676750] sd 5:0:0:0: [sda] Write Protect is off
[   48.681596] sd 5:0:0:0: [sda] Mode Sense: 03 00 00 00
[   48.690803] sd 5:0:0:0: [sda] No Caching mode page found
[   48.696291] sd 5:0:0:0: [sda] Assuming drive cache: write through
[   48.707835]  sda: sda1
[   48.716875] sd 5:0:0:0: [sda] Attached SCSI removable disk
[   48.733075] pm_runtime_get
[   48.815747] usb 2-1.2: reset high-speed USB device number 8 using musb-hdrc
[   49.946034] usb 2-1.2: USB disconnect, device number 8
[   49.951493] pm_runtime_get
[   49.954048] ------------[ cut here ]------------
[   49.958894] WARNING: CPU: 0 PID: 37 at drivers/dma/cppi41.c:611 cppi41_stop_chan+0x230/0x32c()
[   49.967539] Modules linked in: spi_printer(O+) bc_example(O) pvrsrvkm(O)
[   49.974300] CPU: 0 PID: 37 Comm: kworker/0:2 Tainted: G      D    O    4.1.18 #334
[   49.981898] Hardware name: Generic AM33XX (Flattened Device Tree)
[   49.988028] Workqueue: usb_hub_wq hub_event
[   49.992229] Backtrace:
[   49.994711] [<c0012b18>] (dump_backtrace) from [<c0012d38>] (show_stack+0x18/0x1c)
[   50.002310]  r7:c08110b4 r6:00000263 r5:00000009 r4:00000000
[   50.008030] [<c0012d20>] (show_stack) from [<c065f804>] (dump_stack+0x20/0x28)
[   50.015289] [<c065f7e4>] (dump_stack) from [<c0035cf0>] (warn_slowpath_common+0x7c/0xb4)
[   50.023415] [<c0035c74>] (warn_slowpath_common) from [<c0035dcc>] (warn_slowpath_null+0x24/0x2c)
[   50.032234]  r8:00000010 r7:ddb45410 r6:ddb45410 r5:ddb45490 r4:ddb46f80
[   50.038997] [<c0035da8>] (warn_slowpath_null) from [<c037394c>] (cppi41_stop_chan+0x230/0x32c)
[   50.047659] [<c037371c>] (cppi41_stop_chan) from [<c04d7a28>] (cppi41_dma_channel_abort+0xf4/0x214)
[   50.056741]  r10:c0941e80 r9:c0941e8c r8:e09a4c10 r7:ddc0a010 r6:00000004 r5:00000000
[   50.064631]  r4:dd81d05c r3:c037371c
[   50.068235] [<c04d7934>] (cppi41_dma_channel_abort) from [<c04d4cd8>] (musb_cleanup_urb+0x64/0x13c)
[   50.077315]  r10:00000001 r9:dd81d05c r8:e09a4c10 r7:c0008880 r6:dcaa3a00 r5:00000080
[   50.085203]  r4:ddc0a460
[   50.087753] [<c04d4c74>] (musb_cleanup_urb) from [<c04d5468>] (musb_urb_dequeue+0x150/0x160)
[   50.096222]  r10:00000001 r9:ddff2800 r8:dcaa3a00 r7:c0008880 r6:ddc0a010 r5:a00b0193
[   50.104111]  r4:00000000 r3:ddff2800
[   50.107715] [<c04d5318>] (musb_urb_dequeue) from [<c049ee10>] (unlink1+0x38/0x158)
[   50.115313]  r10:00000002 r9:ddccd800 r8:ddbe2e00 r7:ffffff94 r6:ddbe2e00 r5:ddb92000
[   50.123201]  r4:dcaa3a00 r3:c04d5318
[   50.126804] [<c049edd8>] (unlink1) from [<c04a024c>] (usb_hcd_flush_endpoint+0x144/0x184)
[   50.135012]  r8:ddbe2e00 r7:dcaa3480 r6:dcaa3490 r5:ddb92000 r4:dcaa3a00
[   50.141775] [<c04a0108>] (usb_hcd_flush_endpoint) from [<c04a2f7c>] (usb_disable_endpoint+0x50/0x98)
[   50.150944]  r9:ddccd800 r8:00000000 r7:ddd1a000 r6:dca7c088 r5:ddd1a000 r4:dcaa3480
[   50.158755] [<c04a2f2c>] (usb_disable_endpoint) from [<c04a3008>] (usb_disable_interface+0x44/0x5c)
[   50.167836]  r5:00000000 r4:00000000
[   50.171440] [<c04a2fc4>] (usb_disable_interface) from [<c04a58b4>] (usb_unbind_interface+0x1e0/0x280)
[   50.180695]  r9:ddccd800 r8:ddccd600 r7:c08ffccc r6:ddccd620 r5:ddd1a068 r4:ddd1a000
[   50.188507] [<c04a56d4>] (usb_unbind_interface) from [<c03f0508>] (__device_release_driver+0x78/0xec)
[   50.197762]  r10:00000002 r9:ddccd800 r8:c0940f7c r7:ddd1a068 r6:c08fef94 r5:c08ffccc
[   50.205650]  r4:ddccd620
[   50.208198] [<c03f0490>] (__device_release_driver) from [<c03f05a0>] (device_release_driver+0x24/0x30)
[   50.217540]  r5:ddccd620 r4:ddccd654
[   50.221142] [<c03f057c>] (device_release_driver) from [<c03effc4>] (bus_remove_device+0xdc/0x10c)
[   50.230047]  r5:ddccd620 r4:dd922f2c
[   50.233657] [<c03efee8>] (bus_remove_device) from [<c03ecd94>] (device_del+0x110/0x218)
[   50.241691]  r7:ddd1a068 r6:ddccd628 r5:ddccd620 r4:ddd1a000
[   50.247398] [<c03ecc84>] (device_del) from [<c04a30c8>] (usb_disable_device+0xa8/0x1ec)
[   50.255433]  r8:ddccd600 r7:ddbe2e00 r6:00000000 r5:00000001 r4:ddd1a000
[   50.262194] [<c04a3020>] (usb_disable_device) from [<c0499ef8>] (usb_disconnect+0x70/0x258)
[   50.270577]  r9:ddccd800 r8:ddbe7e00 r7:ddd1a068 r6:ddd1a09c r5:ddd1a000 r4:00000000
[   50.278388] [<c0499e88>] (usb_disconnect) from [<c049ba6c>] (hub_event+0x554/0x1120)
[   50.286160]  r10:00000002 r9:00000100 r8:ddc19b04 r7:ddc04c00 r6:00000002 r5:00000004
[   50.294052]  r4:00000000
[   50.296610] [<c049b518>] (hub_event) from [<c004a39c>] (process_one_work+0x12c/0x374)
[   50.304470]  r10:ddb6df80 r9:00000000 r8:c08dd158 r7:de347800 r6:00000000 r5:ddc19b04
[   50.312359]  r4:ddb6df80
[   50.314909] [<c004a270>] (process_one_work) from [<c004a644>] (worker_thread+0x60/0x5cc)
[   50.323031]  r10:ddb6df80 r9:00000000 r8:c08dd158 r7:c08dd168 r6:00000008 r5:ddb6df98
[   50.330919]  r4:c08dd158
[   50.333469] [<c004a5e4>] (worker_thread) from [<c004fa14>] (kthread+0xd4/0xf0)
[   50.340718]  r10:00000000 r9:00000000 r8:00000000 r7:c004a5e4 r6:ddb6df80 r5:ddb730c0
[   50.348607]  r4:00000000
[   50.351156] [<c004f940>] (kthread) from [<c000f928>] (ret_from_fork+0x14/0x2c)
[   50.358406]  r7:00000000 r6:00000000 r5:c004f940 r4:ddb730c0
[   50.364111] ---[ end trace e169cfd9255a0258 ]---
[   50.376305] scsi 5:0:0:0: rejecting I/O to offline device
[   50.381763] scsi 5:0:0:0: [sda] killing request
[   50.386325] scsi 5:0:0:0: rejecting I/O to offline device
[   50.391749] scsi 5:0:0:0: [sda] killing request
[   50.396301] scsi 5:0:0:0: rejecting I/O to dead device
[   50.401508] scsi 5:0:0:0: rejecting I/O to dead device
[   50.406692] scsi 5:0:0:0: rejecting I/O to dead device
[   50.411990] scsi 5:0:0:0: [sda] UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[   50.419888] scsi 5:0:0:0: [sda] CDB: opcode=0x28 28 00 00 00 00 20 00 00 18 00
[   50.427165] blk_update_request: I/O error, dev sda, sector 32
[   50.432973] scsi 5:0:0:0: [sda] UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
[   50.440860] scsi 5:0:0:0: [sda] CDB: opcode=0x28 28 00 00 00 00 10 00 00 08 00
[   50.448126] blk_update_request: I/O error, dev sda, sector 16
[   50.454516] Buffer I/O error on dev sda, logical block 2, async page read
[   50.462111] Buffer I/O error on dev sda, logical block 2, async page read
后更换SDK版本9.01.00 内核版本6.1.45在官方开发板上复现
root@am335x-evm:/proc/sys/kernel# [ 3012.816671] usb 2-1: USB disconnect, device number 24
[ 3012.822727] ------------[ cut here ]------------
[ 3012.827401] WARNING: CPU: 0 PID: 1273 at drivers/dma/ti/cppi41.c:720 cppi41_stop_chan+0x1c8/0x3f8 [cppi41]
[ 3012.837202] Modules linked in: uas irq_pruss_intc pru_rproc 8250_pruss sha256_generic libsha256 sha256_arm ti_am335x_tsc cfg80211 snd_soc_simple_card snd_soc_simple_card_utils pvrsrvkm(O) pruss tilc                            dc drm_dma_helper pwm_tiecap snd_soc_davinci_mcasp snd_soc_ti_udma snd_soc_ti_edma snd_soc_ti_sdma musb_dsps musb_hdrc phy_am335x phy_am335x_control rtc_omap cppi41 omap_wdt snd_soc_tlv320aic3x_i2c snd                            _soc_tlv320aic3x snd_soc_core rtc_tps65910 snd_pcm_dmaengine ac97_bus snd_pcm snd_timer snd ti_am335x_tscadc soundcore cryptodev(O)
[ 3012.884408] CPU: 0 PID: 1273 Comm: kworker/0:1 Tainted: G           O       6.1.46-g1d4b5da681 #1
[ 3012.893357] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 3012.899501] Workqueue: usb_hub_wq hub_event
[ 3012.903807]  unwind_backtrace from show_stack+0x10/0x14
[ 3012.909123]  show_stack from dump_stack_lvl+0x24/0x2c
[ 3012.914262]  dump_stack_lvl from __warn+0x7c/0x130
[ 3012.919157]  __warn from warn_slowpath_fmt+0x9c/0x178
[ 3012.924304]  warn_slowpath_fmt from cppi41_stop_chan+0x1c8/0x3f8 [cppi41]
[ 3012.931221]  cppi41_stop_chan [cppi41] from cppi41_dma_channel_abort+0x134/0x2e0 [musb_hdrc]
[ 3012.939895]  cppi41_dma_channel_abort [musb_hdrc] from musb_cleanup_urb+0x58/0x200 [musb_hdrc]
[ 3012.948733]  musb_cleanup_urb [musb_hdrc] from musb_urb_dequeue+0x114/0x1a0 [musb_hdrc]
[ 3012.956960]  musb_urb_dequeue [musb_hdrc] from usb_hcd_flush_endpoint+0x11c/0x158
[ 3012.964599]  usb_hcd_flush_endpoint from usb_disable_interface+0x54/0xd4
[ 3012.971385]  usb_disable_interface from usb_unbind_interface+0x110/0x268
[ 3012.978172]  usb_unbind_interface from device_release_driver_internal+0x194/0x21c
[ 3012.985753]  device_release_driver_internal from bus_remove_device+0xcc/0xf8
[ 3012.992883]  bus_remove_device from device_del+0x16c/0x468
[ 3012.998461]  device_del from usb_disable_device+0xcc/0x178
[ 3013.004029]  usb_disable_device from usb_disconnect+0xb4/0x224
[ 3013.009953]  usb_disconnect from hub_event+0x984/0x16a8
[ 3013.015271]  hub_event from process_one_work+0x1c0/0x4bc
[ 3013.020694]  process_one_work from worker_thread+0x58/0x584
[ 3013.026361]  worker_thread from kthread+0xd8/0x108
[ 3013.031249]  kthread from ret_from_fork+0x14/0x2c
[ 3013.036024] Exception stack(0xd040dfb0 to 0xd040dff8)
[ 3013.041127] dfa0:                                     00000000 00000000 00000000 00000000
[ 3013.049372] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3013.057613] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 3013.064276] ---[ end trace 0000000000000000 ]---
[ 3013.069483] BUG: scheduling while atomic: kworker/0:1/1273/0x00000002
[ 3013.076084] Modules linked in: uas irq_pruss_intc pru_rproc 8250_pruss sha256_generic libsha256 sha256_arm ti_am335x_tsc cfg80211 snd_soc_simple_card snd_soc_simple_card_utils pvrsrvkm(O) pruss tilc                            dc drm_dma_helper pwm_tiecap snd_soc_davinci_mcasp snd_soc_ti_udma snd_soc_ti_edma snd_soc_ti_sdma musb_dsps musb_hdrc phy_am335x phy_am335x_control rtc_omap cppi41 omap_wdt snd_soc_tlv320aic3x_i2c snd                            _soc_tlv320aic3x snd_soc_core rtc_tps65910 snd_pcm_dmaengine ac97_bus snd_pcm snd_timer snd ti_am335x_tscadc soundcore cryptodev(O)
[ 3013.123342] Preemption disabled at:
[ 3013.123359] [<bf0dbf74>] musb_urb_dequeue+0x40/0x1a0 [musb_hdrc]
[ 3013.133115] CPU: 0 PID: 1273 Comm: kworker/0:1 Tainted: G        W  O       6.1.46-g1d4b5da681 #1
[ 3013.142066] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 3013.148208] Workqueue: usb_hub_wq hub_event
[ 3013.152482]  unwind_backtrace from show_stack+0x10/0x14
[ 3013.157788]  show_stack from dump_stack_lvl+0x24/0x2c
[ 3013.162917]  dump_stack_lvl from __schedule_bug+0x88/0x9c
[ 3013.168391]  __schedule_bug from __schedule+0x52c/0x6bc
[ 3013.173679]  __schedule from schedule+0x54/0xf0
[ 3013.178266]  schedule from schedule_timeout+0xb0/0x140
[ 3013.183476]  schedule_timeout from __wait_for_common+0x88/0x1d0
[ 3013.189467]  __wait_for_common from devtmpfs_submit_req+0x70/0x94
[ 3013.195655]  devtmpfs_submit_req from devtmpfs_delete_node+0x70/0x94
[ 3013.202099]  devtmpfs_delete_node from device_del+0x3d0/0x468
[ 3013.207942]  device_del from cdev_device_del+0x14/0x44
[ 3013.213163]  cdev_device_del from bsg_unregister_queue+0x38/0x44
[ 3013.219249]  bsg_unregister_queue from __scsi_remove_device+0xfc/0x158
[ 3013.225875]  __scsi_remove_device from scsi_forget_host+0x94/0xac
[ 3013.232053]  scsi_forget_host from scsi_remove_host+0x7c/0x1dc
[ 3013.237983]  scsi_remove_host from usb_stor_disconnect+0x44/0xe4
[ 3013.244102]  usb_stor_disconnect from usb_unbind_interface+0x78/0x268
[ 3013.250642]  usb_unbind_interface from device_release_driver_internal+0x194/0x21c
[ 3013.258214]  device_release_driver_internal from bus_remove_device+0xcc/0xf8
[ 3013.265340]  bus_remove_device from device_del+0x16c/0x468
[ 3013.270906]  device_del from usb_disable_device+0xcc/0x178
[ 3013.276472]  usb_disable_device from usb_disconnect+0xb4/0x224
[ 3013.282397]  usb_disconnect from hub_event+0x984/0x16a8
[ 3013.287714]  hub_event from process_one_work+0x1c0/0x4bc
[ 3013.293132]  process_one_work from worker_thread+0x58/0x584
[ 3013.298800]  worker_thread from kthread+0xd8/0x108
[ 3013.303678]  kthread from ret_from_fork+0x14/0x2c
[ 3013.308450] Exception stack(0xd040dfb0 to 0xd040dff8)
[ 3013.313552] dfa0:                                     00000000 00000000 00000000 00000000
[ 3013.321796] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3013.330037] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 3013.336957] sd 0:0:0:0: [sda] Unaligned partial completion (resid=2, sector_sz=512)
[ 3013.358079] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 ee 7f f8 00 00 01 00
[ 3013.374451] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=DRIVER_OK cmd_age=14s
[ 3013.394427] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 ee 7f f8 00 00 01 00
[ 3013.407657] I/O error, dev sda, sector 15630328 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 3013.417846] device offline error, dev sda, sector 15630328 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 3013.429302] buffer_io_error: 6 callbacks suppressed
[ 3013.429324] Buffer I/O error on dev sda, logical block 1953791, async page read
  • 您好,
    已经收到了您的案例,调查需要些时间,感谢您的耐心等待。
  • 你好,
    在第一个日志中,拔下USB设备时,消息来自哪一行?
    在第二个日志中,拔下USB设备时是否会打印第一行?如果是这样,请在连接设备时附加枚举控制台日志。
    你用哪个“官方发展委员会”来重现这个问题?
    问题只发生在单个USB设备上还是发生在不同品牌的设备上?
  • 1.在第一个日志中拔下usb消息来自第19行(每次出现异常的情况在拔出之前都会第18行usb-reset的日志)
    2.在拔出usb设备时会打印第一行,这个是当时的枚举日志后面的就跟上面贴的第二个日志一样
    [  945.778883] usb 2-1: new high-speed USB device number 50 using musb-hdrc
    [  945.908121] usb-storage 2-1:1.0: USB Mass Storage device detected
    [  945.919418] scsi host0: usb-storage 2-1:1.0
    [  946.977891] scsi 0:0:0:0: Direct-Access     Mass     Storage Device   1.00 PQ: 0 ANSI: 0 CCS
    [  946.985365] sd 0:0:0:0: [sda] 15630336 512-byte logical blocks: (8.00 GB/7.45 GiB)
    [  946.985569] sd 0:0:0:0: [sda] Write Protect is off
    [  946.985740] sd 0:0:0:0: [sda] No Caching mode page found
    [  946.985751] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [  947.021659]  sda: sda1
    [  947.022401] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [  948.021659] musb-hdrc musb-hdrc.1: ep2 RX three-strikes error
    [  952.022401] usb 2-1: USB disconnect, device number 50
    [  95.581764] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=DRIVER_OK cmd_age=0s
    [  957.581796] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x28 28 00 00 00 00 38 00 00 08 00
    [  947.021659] blk_print_reg_errot: 10 callbacks suppressed
    3.是使用am335x-evm. 的sdk自带的镜像am335x-evmsk.dtb和zImage-am335x-evm.bin
    4.目前只发现一款u盘容易复现,还有我司另一个连的usb打印机也有类似现象,以下链接
    e2e.ti.com/.../am3354-am3354-usb-mushw_tx_flush-fifo
  • 你好,
    您在9天前发布的第一个日志在USB枚举结束时显示了以下消息。
    每次发生USB问题时,是否都会打印此消息?
  • 不是每次都打印musb-hdrc musb-hdrc.1: ep2 RX three-strikes error
  • 后更换SDK版本9.01.00 内核版本6.1.45在官方开发板上复现
    在EVM上安装SDK9.1时,请在内核配置中禁用CPPI41_DMA,看看问题是否仍然存在。如果是,请附上控制台日志。
  • root@am335x-evm:~# [   35.385667] usb 2-1.2: new high-speed USB device number 3 using musb-hdrc
    [   35.506687] usb 2-1.2: New USB device found, idVendor=14cd, idProduct=2536
    [   35.513609] usb 2-1.2: New USB device strings: Mfr=1, Product=3, SerialNumber=2
    [   35.521286] usb 2-1.2: Product: Mass Storage Device
    [   35.526231] usb 2-1.2: Manufacturer: Generic USB Device
    [   35.531914] usb 2-1.2: SerialNumber: 2536201609180000
    [   35.545793] usb-storage 2-1.2:1.0: USB Mass Storage device detected
    [   35.560692] scsi host0: usb-storage 2-1.2:1.0
    [   36.566456] scsi 0:0:0:0: Direct-Access     Mass     Storage Device   1.00 PQ: 0 ANSI: 0 CCS
    [   36.581248] sd 0:0:0:0: [sda] 15630336 512-byte logical blocks: (8.00 GB/7.45 GiB)
    [   36.593508] sd 0:0:0:0: [sda] Write Protect is off
    [   36.605017] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
    [   36.610766] sd 0:0:0:0: [sda] No Caching mode page found
    [   36.616568] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [   36.628244]  sda: sda1
    [   36.637723] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [   36.775683] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   36.915829] musb_ep_program 896: broken !rx_reinit, ep2 csr 0003
    [   37.015659] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   37.155797] musb_ep_program 896: broken !rx_reinit, ep2 csr 0003
    [   37.255662] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   37.475649] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   37.695668] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   37.835786] musb_ep_program 896: broken !rx_reinit, ep2 csr 0003
    [   37.935659] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   38.056286] sd 0:0:0:0: [sda] UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
    [   38.064014] sd 0:0:0:0: [sda] CDB: opcode=0x28 28 00 00 00 01 70 00 00 90 00
    [   38.071125] blk_update_request: I/O error, dev sda, sector 368
    [   38.155696] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   38.375658] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   38.595652] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   38.815653] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   39.035653] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   39.255664] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   39.376205] sd 0:0:0:0: [sda] UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
    [   39.383912] sd 0:0:0:0: [sda] CDB: opcode=0x28 28 00 00 00 01 70 00 00 08 00
    [   39.391025] blk_update_request: I/O error, dev sda, sector 368
    [   39.396912] Buffer I/O error on dev sda, logical block 46, async page read
    [   39.495665] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   39.715661] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   39.935659] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   40.155666] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   40.375652] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   40.595654] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   40.716209] sd 0:0:0:0: [sda] UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=0x00
    [   40.723914] sd 0:0:0:0: [sda] CDB: opcode=0x28 28 00 00 00 01 70 00 00 08 00
    [   40.731039] blk_update_request: I/O error, dev sda, sector 368
    [   40.736918] Buffer I/O error on dev sda, logical block 46, async page read
    [   40.825677] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   41.045664] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    root@am335x-evm:~# [   41.266080] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   41.485661] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   41.705661] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   41.925659] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    root@am335x-evm:~# [   42.125667] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    root@am335x-evm:~# [   42.345668] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    root@am335x-evm:~# [   42.565661] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   42.785654] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   43.005663] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   43.225658] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   43.425659] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   43.645651] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   43.865650] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   44.085675] usb 2-1.2: reset high-speed USB device number 3 using musb-hdrc
    [   44.226107] sda: detected capacity change from 8002732032 to 0
    [   44.313064] sd 0:0:0:0: [sda] 15630336 512-byte logical blocks: (8.00 GB/7.45 GiB)
    [   44.322925]  sda: sda1
    root@am335x-evm:~#
    root@am335x-evm:~# [   44.908243] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    禁用CPPI41_DMA暂时未复现,插入U盘会频繁reset,才枚举成功。
  • 日志中的总线重置可能是由于USB传输中的数据损坏造成的。为了真正理解这个问题,您可能需要一个USB协议分析器来捕获USB设备枚举期间的USB流量。
