I need to ask a senior TI engineer who knows more about this chip to answer your question. I will get back to you as soon as I get a reply.
This may be a duplicate post.
If this is a different issue, please share the configuration and logs.
By adjusting parameters, there is no problem in using C API 204B to re-establish the connection. However, using C API to re-establish the connection will cause failure to obtain the delay value of ExternalDelayChar. I don’t know if this bug exists in the C API version 1.1.2. Is there any fix?
