Part Number: MMWCAS-RF-EVM
Other Parts Discussed in Thread: AWR1642BOOST, DCA1000EVM, AWR1642, IWR6843, IWR6843ISK, MMWAVEICBOOST
I would like to assemble a millimeter-wave radar transceiver system with the goal of collecting micro-Doppler signature signals generated by the rotation of rotors on multirotor UAVs. I have two proposed assembly schemes:
Scheme 1: Connect the MMWCAS-RF-EVM to the MMWCAS-DSP-EVM, then to a PC. Two WR-12 25 dBi horn antennas are used to achieve signal gain. The horn antennas are connected to the MMWCAS-RF-EVM via a 1.0 mm-f to WR-12 waveguide transition, a 1.85 mm to 1.0 mm adapter, and a SMPM-m to 1.85 mm-f 5 cm cable. This configuration enables signal enhancement without modifying the original structure of the MMWCAS-RF-EVM.
Scheme 2: Connect the AWR1642BOOST to the DCA1000EVM, then to a PC. Similarly, two WR-12 25 dBi horn antennas are used for gain, connected using a 1.0 mm-f to WR-12 waveguide transition, a 1.85 mm to 1.0 mm adapter, and a SMPM-m to 1.85 mm-f 5 cm cable, again without modifying the original structure of the AWR1642BOOST.
I would like to ask:
Do either of these two assembly schemes have any technical issues or compatibility concerns?
Which setup is more recommended?
Will the signal resolution from either system, under open outdoor conditions, be sufficient to clearly display the micro-Doppler frequency shifts caused by different UAV models (i.e., variations in rotor length and rotational speed)?
My UAV parameters are:
Rotor length: 20–80 cm
Propeller rotational speed: 2800–6000 RPM
RCS: 0.02–0.2 m²
If possible, I would also like to know the theoretical detection range of these systems under the given conditions, and whether the collected micro-Doppler features would be sufficient for UAV classification based on their signature differences.
