Other Parts Discussed in Thread: IWR6843, , AWR2944
I only have an AWR2243 radar board and a DCA1000 data acquisition card now, can I measure the pitch angle of an aerial object? If not, what radar board is most common to use?iwr6843?
可以测量俯仰角,但角度有限。另外还要考虑飞行物体的速度。
(+) AWR2243: 非均匀阵列方位角和俯仰角角分辨率如何计算 - 传感器论坛 - 传感器 - E2E 设计支持
级联的方案 AWRx Cascaded Radar RF Evaluation Module (MMWCAS-RF-EVM) User's Guide (Rev. A) 支持± 30 deg Elevation
AWR2944方案 TIDEP-01027 参考设计 | 德州仪器 TI.com.cn
下面帖子请参考
