Other Parts Discussed in Thread: AWR2243
您好AWR2243工程师,我设置了如下参数想要采集1000Hz帧率的数据,采集一直不成功,麻烦帮忙看下有什么问题。另外四级联版最高可以采集多高的帧率?
参数如下:
%% Chirp Configuration 64m 0.2m 1000Hz
c0 = physconst('LightSpeed'); % [m/s]
adc_start_time = 2 * 10^-6; % [s]
sample_freq = 22.5 * 10^6; % [Hz]
adc_samples = 320; % Number of samples per chirp
num_antenna = 86; % Number of virtual antennas [-]
length_antenna = 3; % Length of one antenna [lambda]
adc_smpl_time = adc_samples / sample_freq; % [s]
slope = 52.735 * 10^12; % [Hz/s]
chrp_bw = adc_smpl_time * slope; % [Hz]
f0 = 77 * 10^9 + ( adc_start_time * slope ); % [Hz]
fc = f0 + chrp_bw / 2; % [Hz] 中心频率
lambda = c0 / fc; % [m]
rng_res = c0 / (2 * chrp_bw); % [m]
idle_time = 2 * 10^-6; % [s] 空闲时间
ramp_end_time = 18 * 10^-6; % [s] 斜坡开始到chirp结束时间
nchirp_loops = 2; % frame内的chirp数量
Inter_Frame_Interval = 1 * 10^-3; % [s]frame之间的间隔时间,控制采集频率
rng_max = sample_freq*c0/slope/2; %最远测量距离
frame_time = (idle_time+ramp_end_time)*nchirp_loops; %帧时长
