AWR1443: DATAPATH PROBLEM
Part Number: AWR1443
When configuring the EDMA link for AWR1443 and checking the DATAPATH document, I found that the starting configuration of EDMA corresponds to a unit named H1, which is documented on page 33 of the DATAPATH manual. Could you explain the relevant information about H1? For instance, if data is transferred via EDMA, where is its storage address located? 1787111445292.jpg
