TMP235: Temperature drift issue
Part Number: TMP235
The DCP 60KW 800V HVDC project uses TI's TMP235A2DBZR for ambient temperature acquisition. We’ve run into an issue that we need some help with.
The test was done in a temperature chamber, and the module was only powered with the auxiliary supply—no load, no startup. The ambient temperature measured by a thermocouple didn’t change, and the test only started after the temperature chamber had been running for 30 minutes and the temperature had stabilized.
The problem is: at an ambient temperature of 65°C, when testing the TMP235's output with a high-precision multimeter, the output is stable just after powering on 3.3V, and it matches the analog voltage value for 65°C in the datasheet. After a while with 3.3V powered, the output slowly drifts higher, corresponding to around 68–69°C. Why is this happening? Is there something wrong with the schematic, and how should I troubleshoot it?
