Other Parts Discussed in Thread: IWR1843,
各位工程师好,在这里有一个关于iwr1843供电的问题,我在采集数据的时候需要移动,那么该选取什么类型的移动电源给iwr1843板子供电呢?
下面是iwr1843boost开发板供电要求:
: A 5-V, > 2.5-A supply brick with a 2.1-mm barrel jack (center positive) is not included. TI recommends using an external power supply that complies with applicable regional safety standards, such as UL, CSA, VDE, CCC, PSE, and more. The length of the power cable should be < 3 m.
