Other Parts Discussed in Thread: AWR2243, AWR1243
您好!我按照“Processor SDK – Radar (v03.08) User Guide”和“Vision SDK TDA2xx (v03.08.00) User Guide”上面的参考,成功的编译了例程 tda2xx_cascade_bios_radar,并且得到了appimage和MLO,boot方式是SD卡,开发板成功的启动,但是当到下载BSS固件这一步失败,我怀疑是下载的是awr1243的固件,而我用的是AWR2243开发板,请问该怎样解决?谢谢!
TDA2xx SBL Boot
DPLL Configuration Completed
Clock Domain Configuration Completed
Module Enable Configuration Completed
TI EVM PAD Config Completed
DDR Config Completed
App Image Download Begins
SD Boot - file open completed successfully
IPU1 CPU0 Image Load Completed
IPU1 CPU1 Image Load Completed
DSP1 Image Load Completed
EVE1 Image Load Completed
EVE2 Image Load Completed
EVE3 Image Load Completed
EVE4 Image Load Completed
App Image Download Completed
Putting MPU CPU1 in Off mode
EVE MMU configuration completed
PMCCNTR counts once every 64 clock cycles, multiple by 64 to get actual CPU cycles
SBL Initial Config Cycles - 124378 (10.61 ms)
SOC Init Cycles - 170923 (14.58 ms)
DDR Config Clock Cycles - 58850 (5.2 ms)
App Image Load Cycles - 41499751 (3541.31 ms)
Slave Core Bootup Cycles - 208411 (17.78 ms)
SBL Boot-up Cycles - 42063372 (3589.40 ms)
Time at which SBL started IPU1_0 - 128667 (3926.60 ms)
Putting MPU in Retention...
[IPU1-0] 3.929878 s: ***** IPU1_0 Firmware build time 11:53:54 Aug 9 2021
[IPU1-0] 3.930092 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU1-0] 3.931891 s: SYSTEM: System Common Init in progress !!!
[IPU1-0] 3.942475 s: SYSTEM: IPC init in progress !!!
[IPU1-0] 3.942566 s: SYSTEM: IPCLIB init in progress !!!
[IPU1-0] 3.942963 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[IPU1-0] 3.943085 s: SYSTEM: IPCLIB: register to [DSP1] event 15...
[IPU1-0] 3.943176 s: SYSTEM: IPCLIB: register to [EVE1] event 15...
[IPU1-0] 3.943268 s: SYSTEM: IPCLIB: register to [EVE2] event 15...
[IPU1-0] 3.943359 s: SYSTEM: IPCLIB: register to [EVE3] event 15...
[IPU1-0] 3.943451 s: SYSTEM: IPCLIB: register to [EVE4] event 15...
[IPU1-0] 3.943542 s: SYSTEM: IPCLIB init DONE !!!
[IPU1-0] 3.943603 s: SYSTEM: Notify init done !!!
[IPU1-0] 3.945403 s: SYSTEM: MsgQ init done !!!
[IPU1-0] 3.946227 s: SYSTEM: Work Queue init done !!!
[IPU1-0] 3.946318 s: SYSTEM: IPC init DONE !!!
[IPU1-0] 3.950070 s: SYSTEM: System Common Init Done !!!
[IPU1-0] 3.950222 s: SYSTEM: System Init in progress !!!
[IPU1-0] 3.950283 s: SYSTEM: BSP Common Init in progress !!!
[IPU1-0] 3.950344 s: SYSTEM: BSP Common Init Done !!!
[IPU1-0] 3.950405 s: SYSTEM: BSP Platform Init in progress !!!
[IPU1-0] 3.950527 s: SYSTEM: BSP Platform Init Done !!!
[IPU1-0] 3.950619 s: SYSTEM: FVID2 Init in progress !!!
[IPU1-0] 3.950741 s: SYSTEM: FVID2 Init Done !!!
[IPU1-0] 3.950802 s: SYSTEM: VPS Init in progress !!!
[IPU1-0] 3.950924 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0xa0000000 -> 0x80000000]
[IPU1-0] 3.954126 s: *** VPDMA Firmware Loading... ***
[IPU1-0] 3.954248 s: VPDMA Firmware Address = 0x9fc8a500
[IPU1-0] 3.954340 s: VPDMA Load Address = 0x4897d004
[IPU1-0] 3.954431 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0] 3.954523 s: VPDMA List Busy Status = 0x00000000
[IPU1-0] 3.954584 s: *** VPDMA Firmware Load Success ***
[IPU1-0] 3.954980 s: *** VPDMA Firmware Loading... ***
[IPU1-0] 3.955072 s: VPDMA Firmware Address = 0x9fc8a500
[IPU1-0] 3.955163 s: VPDMA Load Address = 0x4899d004
[IPU1-0] 3.955255 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0] 3.955346 s: VPDMA List Busy Status = 0x00000000
[IPU1-0] 3.955438 s: *** VPDMA Firmware Load Success ***
[IPU1-0] 3.955773 s: *** VPDMA Firmware Loading... ***
[IPU1-0] 3.955895 s: VPDMA Firmware Address = 0x9fc8a500
[IPU1-0] 3.955987 s: VPDMA Load Address = 0x489bd004
[IPU1-0] 3.956078 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0] 3.956170 s: VPDMA List Busy Status = 0x00000000
[IPU1-0] 3.956261 s: *** VPDMA Firmware Load Success ***
[IPU1-0] 4.010980 s: SYSTEM: VPS Init Done !!!
[IPU1-0] 4.011803 s: UTILS: DMA: HWI Create for INT34 !!!
[IPU1-0] 4.012047 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU1-0] 4.012169 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261576 B (255 KB)
[IPU1-0] 4.012322 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[IPU1-0] 4.012505 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x8a783000, Total size = 355979264 B (339 MB), Free size = 355979264 B (339 MB)
[IPU1-0] 4.012688 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0x00000000, Total size = 0 B (0 MB), Free size = 0 B (0 MB)
[IPU1-0] 4.012901 s: SYSTEM: Initializing Links !!!
[IPU1-0] 4.175257 s: SYSTEM: Initializing Links ... DONE !!!
[IPU1-0] 4.254620 s: BOARD: Board Init in progress !!!
[IPU1-0] 4.255169 s: BOARD: Board Init Done !!!
[IPU1-0] 4.265113 s: EEPROM Base Board Name: [DRA74CAS]
[IPU1-0] 4.265448 s:
[IPU1-0] 4.265479 s: Vision SDK Version : [REL_VISION_SDK_03_08_00_00]
[IPU1-0] 4.265540 s: FVID2 Version : [FVID_02_01_00_01]
[IPU1-0] 4.265601 s: BSP Version : [PDK_01_10_04__xx]
[IPU1-0] 4.265692 s: Platform : [EVM]
[IPU1-0] 4.265753 s: SOC : [TDA2XX]
[IPU1-0] 4.265814 s: SOC Revision : [ES2.0]
[IPU1-0] 4.265875 s: Board Detected : [TDA2XX CASCADE RADAR]
[IPU1-0] 4.265967 s: Base Board Revision : [REV E]
[IPU1-0] 4.266028 s: Daughter Card Revision: [REV A]
[IPU1-0] 4.266089 s:
[IPU1-1] 3.941773 s: ***** IPU1_1 Firmware build time 11:52:25 Aug 9 2021
[IPU1-1] 3.941987 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU1-1] 3.945220 s: UTILS: DMA: HWI Create for INT25 !!!
[IPU1-1] 3.975263 s: SYSTEM: System Common Init in progress !!!
[IPU1-1] 3.975599 s: SYSTEM: IPC init in progress !!!
[IPU1-1] 3.975721 s: SYSTEM: IPCLIB init in progress !!!
[IPU1-1] 3.976148 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[IPU1-1] 3.976300 s: SYSTEM: IPCLIB: register to [DSP1] event 15...
[IPU1-1] 3.976392 s: SYSTEM: IPCLIB: register to [EVE1] event 15...
[IPU1-1] 3.976483 s: SYSTEM: IPCLIB: register to [EVE2] event 15...
[IPU1-1] 3.976605 s: SYSTEM: IPCLIB: register to [EVE3] event 15...
[IPU1-1] 3.976727 s: SYSTEM: IPCLIB: register to [EVE4] event 15...
[IPU1-1] 3.976819 s: SYSTEM: IPCLIB init DONE !!!
[IPU1-1] 3.976941 s: SYSTEM: Notify init done !!!
[IPU1-1] 3.978740 s: SYSTEM: MsgQ init done !!!
[IPU1-1] 3.979564 s: SYSTEM: Work Queue init done !!!
[IPU1-1] 3.979655 s: SYSTEM: IPC init DONE !!!
[IPU1-1] 3.983621 s: SYSTEM: System Common Init Done !!!
[IPU1-1] 3.983712 s: SYSTEM: System IPU1_1 Init in progress !!!
[IPU1-1] 3.983804 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU1-1] 3.983956 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 655360 B (640 KB), Free size = 627720 B (613 KB)
[IPU1-1] 3.984170 s: SYSTEM: Initializing Links !!!
[IPU1-1] 4.088909 s: UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
[IPU1-1] 4.091593 s: UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
[IPU1-1] 4.094339 s: UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
[IPU1-1] 4.097602 s: UTILS: PRF: ##### Cannot allocate Object for TFDTPRX ####
[IPU1-1] 4.101049 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
[IPU1-1] 4.104434 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
[IPU1-1] 4.107759 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
[IPU1-1] 4.111236 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
[IPU1-1] 4.114927 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
[IPU1-1] 4.118739 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
[IPU1-1] 4.122247 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
[IPU1-1] 4.125785 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
[IPU1-1] 4.125968 s: SYSTEM: Initializing Links ... DONE !!!
[IPU1-1] 4.127096 s: SYSTEM: System IPU1_1 Init Done !!!
[DSP1 ] 3.927804 s: SYSTEM: System Common Init Done !!!
[DSP1 ] 3.927835 s: SYSTEM: System DSP Init in progress !!!
[DSP1 ] 3.927987 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[DSP1 ] 3.928018 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP1 ] 3.928079 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 524128 B (511 KB)
[DSP1 ] 3.928109 s: SYSTEM: Initializing Links !!!
[DSP1 ] 3.935460 s: SYSTEM: Initializing Links ... DONE !!!
[DSP1 ] 3.935521 s: SYSTEM: System DSP Init Done !!!
[DSP1 ] 4.184560 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[DSP1 ] 4.184590 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[EVE1 ] 3.940523 s: ***** EVE Firmware build time 11:47:56 Aug 9 2021
[EVE1 ] 3.942200 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[EVE1 ] 3.944732 s: SYSTEM: System Common Init in progress !!!
[EVE1 ] 3.945891 s: SYSTEM: IPC init in progress !!!
[EVE1 ] 3.946745 s: SYSTEM: IPCLIB init in progress !!!
[EVE1 ] 3.948301 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[EVE1 ] 3.949429 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[EVE1 ] 3.950588 s: SYSTEM: IPCLIB: register to [DSP1] event 15...
[EVE1 ] 3.951778 s: SYSTEM: IPCLIB: register to [EVE2] event 15...
[EVE1 ] 3.952906 s: SYSTEM: IPCLIB: register to [EVE3] event 15...
[EVE1 ] 3.954004 s: SYSTEM: IPCLIB: register to [EVE4] event 15...
[EVE1 ] 3.955163 s: SYSTEM: IPCLIB init DONE !!!
[EVE1 ] 3.956078 s: SYSTEM: Notify init done !!!
[EVE1 ] 3.957786 s: SYSTEM: MsgQ init done !!!
[EVE1 ] 3.959067 s: SYSTEM: Work Queue init done !!!
[EVE1 ] 3.959982 s: SYSTEM: IPC init DONE !!!
[EVE1 ] 3.973769 s: SYSTEM: System Common Init Done !!!
[EVE1 ] 3.974775 s: SYSTEM: System EVE Init in progress !!!
[EVE1 ] 3.976178 s: UTILS: DMA: HWI Create for INT8 !!!
[EVE1 ] 3.977307 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE1 ] 3.978527 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE1 ] 3.980814 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB)
[EVE1 ] 3.982950 s: SYSTEM: Initializing Links !!!
[EVE1 ] 4.070731 s: SYSTEM: Initializing Links ... DONE !!!
[EVE1 ] 4.071615 s: SYSTEM: System EVE Init Done !!!
[EVE2 ] 3.943847 s: ***** EVE Firmware build time 11:48:40 Aug 9 2021
[EVE2 ] 3.945617 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[EVE2 ] 3.948118 s: SYSTEM: System Common Init in progress !!!
[EVE2 ] 3.949338 s: SYSTEM: IPC init in progress !!!
[EVE2 ] 3.950283 s: SYSTEM: IPCLIB init in progress !!!
[EVE2 ] 3.951839 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[EVE2 ] 3.952998 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[EVE2 ] 3.954126 s: SYSTEM: IPCLIB: register to [DSP1] event 15...
[EVE2 ] 3.955316 s: SYSTEM: IPCLIB: register to [EVE1] event 15...
[EVE2 ] 3.956475 s: SYSTEM: IPCLIB: register to [EVE3] event 15...
[EVE2 ] 3.957664 s: SYSTEM: IPCLIB: register to [EVE4] event 15...
[EVE2 ] 3.958823 s: SYSTEM: IPCLIB init DONE !!!
[EVE2 ] 3.959708 s: SYSTEM: Notify init done !!!
[EVE2 ] 3.961385 s: SYSTEM: MsgQ init done !!!
[EVE2 ] 3.962697 s: SYSTEM: Work Queue init done !!!
[EVE2 ] 3.963612 s: SYSTEM: IPC init DONE !!!
[EVE2 ] 3.977490 s: SYSTEM: System Common Init Done !!!
[EVE2 ] 3.978435 s: SYSTEM: System EVE Init in progress !!!
[EVE2 ] 3.979838 s: UTILS: DMA: HWI Create for INT8 !!!
[EVE2 ] 3.980967 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE2 ] 3.982187 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE2 ] 3.984505 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB)
[EVE2 ] 3.986762 s: SYSTEM: Initializing Links !!!
[EVE2 ] 4.074269 s: SYSTEM: Initializing Links ... DONE !!!
[EVE2 ] 4.075215 s: SYSTEM: System EVE Init Done !!!
[EVE3 ] 3.947172 s: ***** EVE Firmware build time 11:49:23 Aug 9 2021
[EVE3 ] 3.948911 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[EVE3 ] 3.951381 s: SYSTEM: System Common Init in progress !!!
[EVE3 ] 3.952571 s: SYSTEM: IPC init in progress !!!
[EVE3 ] 3.953486 s: SYSTEM: IPCLIB init in progress !!!
[EVE3 ] 3.955041 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[EVE3 ] 3.956200 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[EVE3 ] 3.957390 s: SYSTEM: IPCLIB: register to [DSP1] event 15...
[EVE3 ] 3.958549 s: SYSTEM: IPCLIB: register to [EVE1] event 15...
[EVE3 ] 3.959708 s: SYSTEM: IPCLIB: register to [EVE2] event 15...
[EVE3 ] 3.960836 s: SYSTEM: IPCLIB: register to [EVE4] event 15...
[EVE3 ] 3.961995 s: SYSTEM: IPCLIB init DONE !!!
[EVE3 ] 3.962880 s: SYSTEM: Notify init done !!!
[EVE3 ] 3.964649 s: SYSTEM: MsgQ init done !!!
[EVE3 ] 3.965961 s: SYSTEM: Work Queue init done !!!
[EVE3 ] 3.966876 s: SYSTEM: IPC init DONE !!!
[EVE3 ] 3.980570 s: SYSTEM: System Common Init Done !!!
[EVE3 ] 3.981516 s: SYSTEM: System EVE Init in progress !!!
[EVE3 ] 3.982919 s: UTILS: DMA: HWI Create for INT8 !!!
[EVE3 ] 3.984048 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE3 ] 3.985390 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE3 ] 3.987738 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB)
[EVE3 ] 3.989873 s: SYSTEM: Initializing Links !!!
[EVE3 ] 4.076221 s: SYSTEM: Initializing Links ... DONE !!!
[EVE3 ] 4.077075 s: SYSTEM: System EVE Init Done !!!
[EVE4 ] 3.950497 s: ***** EVE Firmware build time 11:50:06 Aug 9 2021
[EVE4 ] 3.952174 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[EVE4 ] 3.954553 s: SYSTEM: System Common Init in progress !!!
[EVE4 ] 3.955773 s: SYSTEM: IPC init in progress !!!
[EVE4 ] 3.956688 s: SYSTEM: IPCLIB init in progress !!!
[EVE4 ] 3.958305 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[EVE4 ] 3.959433 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[EVE4 ] 3.960562 s: SYSTEM: IPCLIB: register to [DSP1] event 15...
[EVE4 ] 3.961782 s: SYSTEM: IPCLIB: register to [EVE1] event 15...
[EVE4 ] 3.962910 s: SYSTEM: IPCLIB: register to [EVE2] event 15...
[EVE4 ] 3.964070 s: SYSTEM: IPCLIB: register to [EVE3] event 15...
[EVE4 ] 3.965290 s: SYSTEM: IPCLIB init DONE !!!
[EVE4 ] 3.966174 s: SYSTEM: Notify init done !!!
[EVE4 ] 3.967852 s: SYSTEM: MsgQ init done !!!
[EVE4 ] 3.969133 s: SYSTEM: Work Queue init done !!!
[EVE4 ] 3.970078 s: SYSTEM: IPC init DONE !!!
[EVE4 ] 3.983682 s: SYSTEM: System Common Init Done !!!
[EVE4 ] 3.984688 s: SYSTEM: System EVE Init in progress !!!
[EVE4 ] 3.986122 s: UTILS: DMA: HWI Create for INT8 !!!
[EVE4 ] 3.987220 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE4 ] 3.988470 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE4 ] 3.990788 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB)
[EVE4 ] 3.992893 s: SYSTEM: Initializing Links !!!
[EVE4 ] 4.078844 s: SYSTEM: Initializing Links ... DONE !!!
[EVE4 ] 4.079668 s: SYSTEM: System EVE Init Done !!!
[IPU1-0] 5.269657 s: QSPI Init Started
[IPU1-0] 5.269871 s: MID - 20
[IPU1-0] 5.269932 s: DID - 21
[IPU1-0] 5.269993 s: QSPI Init Completed Sucessfully
[IPU1-0] 5.275208 s:
[IPU1-0] 5.275269 s: Current System Settings,
[IPU1-0] 5.275330 s: ========================
[IPU1-0] 5.275391 s: Display Type : HDMI 1920x1080 @ 60fps
[IPU1-0] 5.275452 s: My IP address for interface 1 : 0.0.0.0
[IPU1-0] 5.275513 s: My IP address for interface 2 : 0.0.0.0
[IPU1-0] 5.275574 s:
[IPU1-0] 5.275605 s: ============
[IPU1-0] 5.275666 s: Usecase Menu
[IPU1-0] 5.275696 s: ============
[IPU1-0] 5.275757 s:
[IPU1-0]
[IPU1-0] Vision SDK Usecases,
[IPU1-0] --------------------
[IPU1-0]
[IPU1-0] 1: RADAR Usecases
[IPU1-0] 2: MISC Tests
[IPU1-0]
[IPU1-0] s: System Settings
[IPU1-0]
[IPU1-0] x: Exit
[IPU1-0]
[IPU1-0] Enter Choice:
[IPU1-0]
[IPU1-1] 6.344201 s: NSP GMAC: PHY 2 Found on MAC Port 0
[IPU1-1] 9.127005 s: NETWORK_CTRL: Starting Server (port=5000) !!!
[IPU1-1] 9.127279 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
[IPU1-1] 9.244586 s: NDK: Link Status: 1000Mb/s Full Duplex on PHY 2
[IPU1-0] 21.826450 s:
[IPU1-0] 21.826572 s:
[IPU1-0]
[IPU1-0] RADAR Usecases
[IPU1-0]
[IPU1-0] 9: Cascade Radar (4 AWR1243) Capture + Null (TDA2xx Only)
[IPU1-0] a: Cascade Radar (4 AWR1243) Capture + Radar Object Detect (DSP) + NetworkTx (TDA2xx Only)
[IPU1-0] b: Cascade Radar (4 AWR1243) Capture + FFT (EVE) + Tx Beam Form Static Map (DSP) + NetworkTx (TDA2xx Only)
[IPU1-0]
[IPU1-0] x: Exit
[IPU1-0]
[IPU1-0]
[IPU1-0] 21.826907 s:
[IPU1-0] 21.826938 s: Unsupported option '
[IPU1-0] '. Please try again
[IPU1-0] 21.827029 s:
[IPU1-0]
[IPU1-0]
[IPU1-0]
[IPU1-0] x: Exit
[IPU1-0]
[IPU1-0]
[IPU1-0] 21.827365 s:
[IPU1-0] 21.827426 s: Unsupported option '
[IPU1-0] 21.827548 s:
[IPU1-0]
[IPU1-0]
[IPU1-0]
[IPU1-0] x: Exit
[IPU1-0]
[IPU1-0]
[IPU1-0] 30.942688 s:
[IPU1-0] 30.942749 s:
[IPU1-0]
[IPU1-0] ========================
[IPU1-0] 2D FFT Core Selection
[IPU1-0]
[IPU1-0] 1: DSP
[IPU1-0]
[IPU1-0] 2: EVE
[IPU1-0]
[IPU1-0] 30.943054 s:
[IPU1-0] Unsupported option '
[IPU1-0] 30.943115 s:
[IPU1-0]
[IPU1-0]
[IPU1-0] 1: DSP
[IPU1-0]
[IPU1-0] 2: EVE
[IPU1-0]
[IPU1-0] 30.943420 s:
[IPU1-0] 30.943512 s:
[IPU1-0]
[IPU1-0]
[IPU1-0] 1: DSP
[IPU1-0]
[IPU1-0] 2: EVE
[IPU1-0]
[IPU1-0] 43.035472 s: CHAINS_COMMON_CASCADE AR12xx Initializing FPGA ...
[IPU1-0] 44.635088 s: CHAINS_COMMON_CASCADE AR12xx Initializing FPGA Done...
[IPU1-0] 44.635301 s: Parsing radar_test_vector/sensor_master_config.txt
[IPU1-0] 44.652138 s: !!!No Valid Configuration file is found. Use Default Configurations!!!
[IPU1-0] 44.652260 s: CHAINS: Init AR12xx ...
[IPU1-0] 44.652504 s: UTILS_MCSPI: McSPI is configured in interrupt mode!!
[IPU1-0] 44.652839 s: UTILS_MCSPI: McSPI is configured in interrupt mode!!
[IPU1-0] 44.653053 s: UTILS_MCSPI: McSPI is configured in interrupt mode!!
[IPU1-0] 44.653205 s: UTILS_MCSPI: McSPI is configured in interrupt mode!!
[IPU1-0] 44.877478 s: AR12XX: ES1.0 Device detected!!
[IPU1-0] 44.877600 s: AR12XX: Firmware Download Started : Ftype: MSS_BUILD
[IPU1-0] 46.969072 s: AR12XX: Firmware Download Successful : Ftype: MSS_BUILD
[IPU1-0] 46.969194 s: AR12XX: Firmware Download Started : Ftype: BSS_BUILD
[IPU1-0] 46.981669 s: AR12XX: Firmware chunk No. 19 download Failed : Ftype: BSS_BUILD
[IPU1-0] 46.981760 s: Assertion @ Line: 280 in E:/vision_sdk/apps/src/rtos/radar/src/common/chains_common_ar12xx.c: SYSTEM_LINK_STATUS_SOK == retVal : failed !!!
