Other Parts Discussed in Thread: IWR1443
在mmw Demo for XWR1443中看到说每个板子距离都存在几厘米误差,如下:
For most boards, a range bias of few centimeters has been observed. User can estimate the range bias on their board and correct using the calibration procedure described in Range Bias and Rx Channel Gain/Offset Measurement and Compensation.
我用DCA1000+iwr1443 测量的距离貌也是有固定偏移,这个如何矫正呢。上面的看不太懂。。
