由于我每次用雷达板采集到的数据是一样的,所以我感觉每次都没有采集成功,我想请问我的操作步骤是否有问题,附上我的output文件
GM: Constructor
GM: Wed Jan 12 10:49:38 2022
RSTD.Transmit("/Settings")
[10:49:38]
[10:49:38] ### Running Startup script: "C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ###
[10:49:38] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[10:49:38] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[10:49:38] Scripter ignored: Attempt to UnBuild() again or before Build.
[10:49:38] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[10:49:38] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[10:49:38] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[10:49:38] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[10:49:38] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[10:49:38] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[10:49:38] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll")
[10:49:38] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[10:49:38] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[10:49:38] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[10:49:39] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[10:49:39] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[10:49:39] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[10:49:39] RSTD.Transmit("/")
[10:49:39] RSTD.SaveSettings(): Settings saved to "C:\Users\hp-pc\AppData\Roaming\RSTD\config.xml"
[10:49:39] RSTD.Build()
[10:49:39] RSTD.AL_Build()
[10:49:39] RSTD.AL_LoadXml()
[10:49:39] RSTD.AL_Init()
[10:49:39] RSTD.Clients_Build()
[10:49:39] GM: Init
[10:49:39] GM: Loaded 'C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll'
[10:49:39] GM: 1 Guest (s) init
[10:49:39] GM: 1 Module(s) init
[10:49:39] GM: 2 Tab (s) init
[10:49:39] RSTD.Client_LoadXml()
[10:49:39] [RadarAPI]: ar1.selectRadarMode(0)
[10:49:39] [RadarAPI]: Status: Passed
[10:49:39] Matlab Runtime Engine is installed
[10:49:39] [RadarAPI]: Starting Matlab Engine..
[10:49:41] [RadarAPI]: Matlab Engine Started!
[10:49:42] [RadarAPI]: ar1.selectCascadeMode(0)
[10:49:42] [RadarAPI]: Status: Passed
[10:49:42] [RadarAPI]: ar1.LoadSettings('C:\Users\hp-pc\AppData\Roaming\RSTD\ar1gui.ini')
[10:49:42] TESTING = false
[10:49:42] RstdNet: Port 2777: Listening..
[10:49:42]
[10:49:42] ***Script completed successfully.***
[10:50:15] [RadarAPI]: ar1.selectRadarMode(1)
[10:50:15] [RadarAPI]: ar1.selectCascadeMode(1)
[10:50:15] [RadarAPI]: Status: Passed
[10:50:16] [RadarAPI]: ar1.SelectCaptureDevice("TDA2XX")
[10:50:16] [RadarAPI]: Status: Passed
[10:50:18] [RadarAPI]: TDAStatusCallback Event Registered
[10:50:18] [RadarAPI]: registerTDAStatusCallback Status: Passed
[10:50:18] [RadarAPI]: ar1.ConnectTDA("192.168.33.180", 5001, 15)
[10:50:18] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:50:18] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_VERSION_INFO Async event recieved() with status 0. TDA Version : REL_VISION_SDK_03_07_01_00 Aug 5 2019 15:04:45 �4 2 a _ r 7 _ a d 1 G u i S t a t e Q
[10:50:18] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:50:20] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:50:20] [RadarAPI]: ConnectTDACaptureCard Status: Passed
[10:50:20] TDA Capture Card Status : CONNECTED!
[10:50:24] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:50:25] [RadarAPI]: ar1.FullReset(1)
[10:50:25] [RadarAPI]: Status: Passed
[10:50:25] [RadarAPI]: ar1.SOPControl_mult(1,4)
[10:50:27] [DeviceId-0] MSS power up done async event received!
[10:50:27] [RadarAPI]: ar1.PowerOn_mult(1, 0, 1000, 0,0)
[10:50:27] [RadarAPI]: Status: Passed
[10:50:29] [RadarAPI]: ar1.DownloadBSSFw_mult(1,"C:\\ti\\mmwave_dfp_01_02_06_03\\firmware\\xwr12xx_metaImage.bin")
[10:50:29] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(1, C:\\ti\\mmwave_dfp_01_02_06_03\\firmware\\xwr12xx_metaImage.bin)
[10:50:49] Device Status : UnDetDe/ASIL-B/SOP:4/ES:1
[10:50:49] [RadarAPI]: ar1.RfEnable_mult(1)
[10:50:49] [DeviceId-0] BSS power up done async event received!
[10:50:49] [RadarAPI]: Status: Passed
[10:50:55] [RadarAPI]: ar1.ChanNAdcConfig_mult(1, 1, 1, 0, 1, 1, 1, 1, 2, 1, 0, 1)
[10:50:55] [RadarAPI]: Status: Passed
[10:51:00] [RadarAPI]: ar1.RfLdoBypassConfig_mult(1, 0x1)
[10:51:00] [RadarAPI]: Status: Passed
[10:51:21] [RadarAPI]: ar1.LPModConfig_mult(1, 0,0)
[10:51:21] [RadarAPI]: Status: Passed
[10:51:21] [RadarAPI]: ar1.RfInit_mult(1)
[10:51:21] [DeviceId-0] RF Init async event received!
[10:51:21] [RadarAPI]: Time stamp, Temperture: 32644,34; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[10:51:31] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:51:31] [RadarAPI]: ar1.FullReset(2)
[10:51:31] [RadarAPI]: Status: Passed
[10:51:31] [RadarAPI]: ar1.SOPControl_mult(2,4)
[10:51:32] [DeviceId-1] MSS power up done async event received!
[10:51:32] [RadarAPI]: ar1.AddDevice(2)
[10:51:32] [RadarAPI]: Status: Passed
[10:51:34] [RadarAPI]: ar1.DownloadBSSFw_mult(2,"C:\\ti\\mmwave_dfp_01_02_06_03\\firmware\\xwr12xx_metaImage.bin")
[10:51:34] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(2, C:\\ti\\mmwave_dfp_01_02_06_03\\firmware\\xwr12xx_metaImage.bin)
[10:52:12] Slave1 Device Status : UnDetDe/ASIL-B/SOP:4/ES:1
[10:52:12] [RadarAPI]: ar1.RfEnable_mult(2)
[10:52:12] [DeviceId-1] BSS power up done async event received!
[10:52:12] [RadarAPI]: Status: Passed
[10:52:19] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:52:20] [RadarAPI]: ar1.FullReset(4)
[10:52:20] [RadarAPI]: Status: Passed
[10:52:20] [RadarAPI]: ar1.SOPControl_mult(4,4)
[10:52:22] [DeviceId-2] MSS power up done async event received!
[10:52:22] [RadarAPI]: ar1.AddDevice(4)
[10:52:22] [RadarAPI]: Status: Passed
[10:52:26] [RadarAPI]: ar1.DownloadBSSFw_mult(4,"C:\\ti\\mmwave_dfp_01_02_06_03\\firmware\\xwr12xx_metaImage.bin")
[10:52:26] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(4, C:\\ti\\mmwave_dfp_01_02_06_03\\firmware\\xwr12xx_metaImage.bin)
[10:52:45] Slave2 Device Status : UnDetDe/ASIL-B/SOP:4/ES:1
[10:52:45] [RadarAPI]: ar1.RfEnable_mult(4)
[10:52:45] [DeviceId-2] BSS power up done async event received!
[10:52:45] [RadarAPI]: Status: Passed
[10:52:51] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:52:52] [RadarAPI]: ar1.FullReset(8)
[10:52:52] [RadarAPI]: Status: Passed
[10:52:52] [RadarAPI]: ar1.SOPControl_mult(8,4)
[10:52:55] [DeviceId-3] MSS power up done async event received!
[10:52:55] [RadarAPI]: ar1.AddDevice(8)
[10:52:55] [RadarAPI]: Status: Passed
[10:52:58] [RadarAPI]: ar1.DownloadBSSFw_mult(8,"C:\\ti\\mmwave_dfp_01_02_06_03\\firmware\\xwr12xx_metaImage.bin")
[10:52:58] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(8, C:\\ti\\mmwave_dfp_01_02_06_03\\firmware\\xwr12xx_metaImage.bin)
[10:53:19] Slave3 Device Status : UnDetDe/ASIL-B/SOP:4/ES:1
[10:53:19] [RadarAPI]: ar1.RfEnable_mult(8)
[10:53:19] [DeviceId-3] BSS power up done async event received!
[10:53:19] [RadarAPI]: Status: Passed
[10:53:28] [RadarAPI]: ar1.ChanNAdcConfig_mult(14, 1, 1, 0, 1, 1, 1, 1, 2, 1, 0, 2)
[10:53:28] [RadarAPI]: Status: Passed
[10:53:29] [RadarAPI]: ar1.LPModConfig_mult(14, 0,0)
[10:53:29] [RadarAPI]: Status: Passed
[10:53:29] [RadarAPI]: ar1.RfInit_mult(14)
[10:53:30] [DeviceId-2] RF Init async event received!
[10:53:30] [DeviceId-1] RF Init async event received!
[10:53:30] [DeviceId-3] RF Init async event received!
[10:53:30] [RadarAPI]: Time stamp, Temperture: 10664,34; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[10:53:30] [RadarAPI]: Status: Passed
[10:54:49] [RadarAPI]: ar1.DataPathConfig_mult(15, 513, 1216644097,0)
[10:54:49] [RadarAPI]: Status: Passed
[10:54:51] [RadarAPI]: ar1.LvdsClkConfig_mult(15, 1,1)
[10:54:51] [RadarAPI]: Status: Passed
[10:54:53] [RadarAPI]: ar1.LVDSLaneConfig_mult(15, 0, 1, 1, 1, 1, 1, 0,0)
[10:54:53] [RadarAPI]: Status: Passed
[10:55:11] [RadarAPI]: ar1.ProfileConfig_mult(15, 0, 77, 100, 6, 38, 0, 0, 0, 0, 0, 0, 105.202, 0, 64, 2001, 0, 0, 30)
[10:55:11] [RadarAPI]: Status: Passed
[10:55:14] [RadarAPI]: ar1.ChirpConfig_mult(15, 0, 0, 0, 0, 0, 0, 0, 1, 0,0)
[10:55:14] [RadarAPI]: Status: Passed
[10:55:17] [RadarAPI]: ar1.ChirpConfig_mult(15, 1, 1, 0, 0, 0, 0, 0, 0, 1,0)
[10:55:18] [RadarAPI]: Status: Passed
[10:55:24] Test Source Already Disabled...!!!
[10:55:24] [RadarAPI]: ar1.DisableTestSource_mult(1,0)
[10:55:24] [RadarAPI]: Status: Passed
[10:55:24] [RadarAPI]: ar1.FrameConfig_mult(1, 0, 1, 32, 128, 40, 0, 0, 1)
[10:55:30] Test Source Already Disabled...!!!
[10:55:30] [RadarAPI]: ar1.DisableTestSource_mult(14,0)
[10:55:30] [RadarAPI]: Status: Passed
[10:55:30] [RadarAPI]: ar1.FrameConfig_mult(14, 0, 1, 32, 128, 40, 0, 0, 2)
[10:55:36] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, adc_data, 0)
[10:55:36] Device 0 - Configuring TDA with Width : 512 and Height : 256
[10:55:36] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[10:55:36] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:55:36] Device 1 - Configuring TDA with Width : 512 and Height : 256
[10:55:36] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[10:55:36] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:55:36] Device 2 - Configuring TDA with Width : 512 and Height : 256
[10:55:36] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[10:55:36] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:55:36] Device 3 - Configuring TDA with Width : 512 and Height : 256
[10:55:36] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[10:55:36] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:55:36] Sending Frame Periodicity of 40 to TDA..
[10:55:36] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[10:55:36] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:55:36] Sending Capture Directory with name /mnt/ssd/adc_data to TDA..
[10:55:36] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[10:55:36] Sending File Allocation of 0 files to TDA..
[10:55:36] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[10:55:36] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[10:55:36] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[10:55:36] Sending Number of frames to capture with value of 0 to TDA..
[10:55:36] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[10:55:36] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[10:55:36] [RadarAPI]: Status: Passed for notifying TDA about Start Frame
[10:55:39] [RadarAPI]: ar1.StartFrame_mult(2)
[10:55:39] [RadarAPI]: Status: Passed
[10:55:39] [DeviceId-1] Frame start async event received!
[10:55:42] [RadarAPI]: ar1.StartFrame_mult(4)
[10:55:42] [RadarAPI]: Status: Passed
[10:55:43] [DeviceId-2] Frame start async event received!
[10:55:45] [RadarAPI]: ar1.StartFrame_mult(8)
[10:55:45] [RadarAPI]: Status: Passed
[10:55:45] [DeviceId-3] Frame start async event received!
[10:55:49] [RadarAPI]: ar1.StartFrame_mult(1)
[10:55:49] [RadarAPI]: Status: Passed
[10:55:49] [DeviceId-0] Frame start async event received!
[10:55:50] [RadarAPI]: Frame Ended
[10:55:50] [DeviceId-2] Frame End async event received!
[10:55:50] [DeviceId-3] Frame End async event received!
[10:55:50] [DeviceId-0] Frame End async event received!
[10:55:50] [DeviceId-1] Frame End async event received!
[10:55:50] Status: Passed for notifying TDA about Stop Frame
[10:55:50] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[10:55:55] Downloading file /mnt/ssd/adc_data/master_0000_data.bin...
[10:55:57] Downloaded file /mnt/ssd/adc_data/master_0000_data.bin from SSD!
[10:55:57] Downloading file /mnt/ssd/adc_data/master_0000_idx.bin...
[10:55:57] Downloaded file /mnt/ssd/adc_data/master_0000_idx.bin from SSD!
[10:55:57] Downloading file /mnt/ssd/adc_data/master_0001_data.bin...
[10:56:02] Downloaded file /mnt/ssd/adc_data/master_0001_data.bin from SSD!
[10:56:02] Downloading file /mnt/ssd/adc_data/master_0001_idx.bin...
[10:56:02] Downloaded file /mnt/ssd/adc_data/master_0001_idx.bin from SSD!
[10:56:02] Downloading file /mnt/ssd/adc_data/master_0002_data.bin...
[10:56:03] Downloaded file /mnt/ssd/adc_data/master_0002_data.bin from SSD!
[10:56:03] Downloading file /mnt/ssd/adc_data/master_0002_idx.bin...
[10:56:03] Downloaded file /mnt/ssd/adc_data/master_0002_idx.bin from SSD!
[10:56:03] Downloading file /mnt/ssd/adc_data/master_0003_data.bin...
[10:56:04] Downloaded file /mnt/ssd/adc_data/master_0003_data.bin from SSD!
[10:56:04] Downloading file /mnt/ssd/adc_data/master_0003_idx.bin...
[10:56:04] Downloaded file /mnt/ssd/adc_data/master_0003_idx.bin from SSD!
[10:56:04] Downloading file /mnt/ssd/adc_data/slave1_0000_data.bin...
[10:56:07] Downloaded file /mnt/ssd/adc_data/slave1_0000_data.bin from SSD!
[10:56:07] Downloading file /mnt/ssd/adc_data/slave1_0000_idx.bin...
[10:56:07] Downloaded file /mnt/ssd/adc_data/slave1_0000_idx.bin from SSD!
[10:56:07] Downloading file /mnt/ssd/adc_data/slave1_0001_data.bin...
[10:56:11] Downloaded file /mnt/ssd/adc_data/slave1_0001_data.bin from SSD!
[10:56:11] Downloading file /mnt/ssd/adc_data/slave1_0001_idx.bin...
[10:56:11] Downloaded file /mnt/ssd/adc_data/slave1_0001_idx.bin from SSD!
[10:56:11] Downloading file /mnt/ssd/adc_data/slave1_0002_data.bin...
[10:56:12] Downloaded file /mnt/ssd/adc_data/slave1_0002_data.bin from SSD!
[10:56:12] Downloading file /mnt/ssd/adc_data/slave1_0002_idx.bin...
[10:56:12] Downloaded file /mnt/ssd/adc_data/slave1_0002_idx.bin from SSD!
[10:56:12] Downloading file /mnt/ssd/adc_data/slave1_0003_data.bin...
[10:56:14] Downloaded file /mnt/ssd/adc_data/slave1_0003_data.bin from SSD!
[10:56:14] Downloading file /mnt/ssd/adc_data/slave1_0003_idx.bin...
[10:56:14] Downloaded file /mnt/ssd/adc_data/slave1_0003_idx.bin from SSD!
[10:56:14] Downloading file /mnt/ssd/adc_data/slave2_0000_data.bin...
[10:56:16] Downloaded file /mnt/ssd/adc_data/slave2_0000_data.bin from SSD!
[10:56:16] Downloading file /mnt/ssd/adc_data/slave2_0000_idx.bin...
[10:56:17] Downloaded file /mnt/ssd/adc_data/slave2_0000_idx.bin from SSD!
[10:56:17] Downloading file /mnt/ssd/adc_data/slave2_0001_data.bin...
[10:56:22] Downloaded file /mnt/ssd/adc_data/slave2_0001_data.bin from SSD!
[10:56:22] Downloading file /mnt/ssd/adc_data/slave2_0001_idx.bin...
[10:56:22] Downloaded file /mnt/ssd/adc_data/slave2_0001_idx.bin from SSD!
[10:56:22] Downloading file /mnt/ssd/adc_data/slave2_0002_data.bin...
[10:56:22] Downloaded file /mnt/ssd/adc_data/slave2_0002_data.bin from SSD!
[10:56:22] Downloading file /mnt/ssd/adc_data/slave2_0002_idx.bin...
[10:56:23] Downloaded file /mnt/ssd/adc_data/slave2_0002_idx.bin from SSD!
[10:56:23] Downloading file /mnt/ssd/adc_data/slave2_0003_data.bin...
[10:56:24] Downloaded file /mnt/ssd/adc_data/slave2_0003_data.bin from SSD!
[10:56:24] Downloading file /mnt/ssd/adc_data/slave2_0003_idx.bin...
[10:56:24] Downloaded file /mnt/ssd/adc_data/slave2_0003_idx.bin from SSD!
[10:56:24] Downloading file /mnt/ssd/adc_data/slave3_0000_data.bin...
[10:56:27] Downloaded file /mnt/ssd/adc_data/slave3_0000_data.bin from SSD!
[10:56:27] Downloading file /mnt/ssd/adc_data/slave3_0000_idx.bin...
[10:56:27] Downloaded file /mnt/ssd/adc_data/slave3_0000_idx.bin from SSD!
[10:56:27] Downloading file /mnt/ssd/adc_data/slave3_0001_data.bin...
[10:56:32] Downloaded file /mnt/ssd/adc_data/slave3_0001_data.bin from SSD!
[10:56:32] Downloading file /mnt/ssd/adc_data/slave3_0001_idx.bin...
[10:56:32] Downloaded file /mnt/ssd/adc_data/slave3_0001_idx.bin from SSD!
[10:56:32] Downloading file /mnt/ssd/adc_data/slave3_0002_data.bin...
[10:56:33] Downloaded file /mnt/ssd/adc_data/slave3_0002_data.bin from SSD!
[10:56:33] Downloading file /mnt/ssd/adc_data/slave3_0002_idx.bin...
[10:56:33] Downloaded file /mnt/ssd/adc_data/slave3_0002_idx.bin from SSD!
[10:56:33] Downloading file /mnt/ssd/adc_data/slave3_0003_data.bin...
[10:56:34] Downloaded file /mnt/ssd/adc_data/slave3_0003_data.bin from SSD!
[10:56:34] Downloading file /mnt/ssd/adc_data/slave3_0003_idx.bin...
[10:56:34] Downloaded file /mnt/ssd/adc_data/slave3_0003_idx.bin from SSD!
[10:56:35] Export Operation was successful!
[10:56:35] [RadarAPI]: Transfer of the Captured files COMPLETE!
[10:56:39] [RadarAPI]: ar1.StartMatlabPostProc("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[10:56:39] [RadarAPI]: No of files Captured: 4, Total no of frames for each device : 32
[11:01:51] CAPTURE_RESPONSE_NETWORK_ERROR Async event recieved! Connection error! Please reboot the TDA board
[11:01:51] [RadarAPI]: ar1.RemoveDevice(8)
[11:01:51] [RadarAPI]: Status: Passed
[11:01:51] [RadarAPI]: ar1.RemoveDevice(4)
[11:01:51] [RadarAPI]: ar1.RemoveDevice(2)
[11:01:51] [RadarAPI]: ar1.PowerOff_mult()
[11:01:52] [RadarAPI]: ar1.FullReset(1)
[11:01:52] [RadarAPI]: Status: Passed
[11:01:52] [RadarAPI]: ar1.SOPControl_mult(1,4)
[11:01:52] TDA Capture Card Status : DISCONNECTED!
[14:58:00] [RadarAPI]: ar1.SaveSettings('C:\Users\hp-pc\AppData\Roaming\RSTD\ar1gui.ini')
[14:58:00] RSTD.ExitRstd()
[14:58:00] RSTD.SaveSettings(): Settings saved to "C:\Users\hp-pc\AppData\Roaming\RSTD\config.xml"
