TDC7201测量設置多次 STOP,要怎麼使用其他STOP所計算出來的值,是否可以舉例說明
非常抱歉,这个我没找到相应的计算示例。但是这个仅是改变了 CLOCK_COUNTn值:
The CLOCK_COUNTn registers should be right shifted by the log2(AVG_CYCLES) before calculating the TOF. For example, if using the multi-cycle averaging mode, Equation 2 should be rewritten as: TOFn = normLSB [TDCx_TIME1 - TDCx_TIME(n+1)] + [TDCx_CLOCK_COUNTn >> log 2 (AVG_CYCLES)] x [CLOCKperiod]
