IWR6843: mmwavelib_windowing16x16_evenlen 、DSP_fft16x16
Part Number: IWR6843
Question 1: The sentence on page 37 of Sprueb8b is "The function is Accurateto about 68dB of signal to noise ratio to The DFT function as What does "follows" mean, does it have DSP_fft16x16 and SNR
Question 2: IWR6843 DSS end with function MMWAVeib_WINDOwing16x16_evenlen WINDOwing and DSP_fft16x16 function for 1DFFT calculation, the results and matlab simulation were compared, found that the shape is basically the same, The amplitude gets lower. What was done in the above function that resulted in this result
