我按照这个帖子将我的1642的代码进行了修改,但是好像并没有正确运行,通过数据串口观察到并没有数据发送回来。
网址如下:e2e.ti.com/.../iwr1443boost-send-config-to-iwr1443-without-using-visualizer
我附上我的CLI.c文件,以及对应的ini_cfg.c和ini_cfg.h文件,后面的两个ini开头的问题都是从上述网址下载的。
* @file cli.c
* @brief
* Mmw (Milli-meter wave) DEMO CLI Implementation
* \par
* NOTE:
* (C) Copyright 2016 Texas Instruments, Inc.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
*************************** Include Files ********************************
/* Standard Include Files. */
#include <stdint.h>
#include <stdlib.h>
#include <stddef.h>
#include <string.h>
#include <stdio.h>
/* BIOS/XDC Include Files. */
#include <xdc/std.h>
#include <xdc/cfg/global.h>
#include <xdc/runtime/IHeap.h>
#include <xdc/runtime/System.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/Memory.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/knl/Event.h>
#include <ti/sysbios/knl/Semaphore.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/heaps/HeapBuf.h>
#include <ti/sysbios/heaps/HeapMem.h>
/* mmWave SDK Include Files: */
#include <ti/common/sys_common.h>
#include <ti/common/mmwave_sdk_version.h>
#include <ti/drivers/uart/UART.h>
#include <ti/control/mmwavelink/mmwavelink.h>
#include <ti/utils/cli/cli.h>
/* Demo Include Files */
#include "ti/demo/xwr16xx/mmw/mss/mss_mmw.h"
#include "ti/demo/xwr16xx/mmw/common/mmw_messages.h"
#include"ini_cfg.h"
*************************** Local Definitions ****************************
/* CLI Extended Command Functions */
static int32_t MmwDemo_CLICfarCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIPeakGroupingCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIMultiObjBeamForming (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLICalibDcRangeSig (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIExtendedMaxVelocity (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIClutterRemoval (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLISensorStart (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLISensorStop (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIGuiMonSel (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLISetDataLogger (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIADCBufCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLICompRangeBiasAndRxChanPhaseCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIMeasureRangeBiasAndRxChanPhaseCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLINearFieldCorrection (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIChirpQualityRxSatMonCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIChirpQualitySigImgMonCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLIAnalogMonitorCfg (int32_t argc, char* argv[]);
static int32_t MmwDemo_CLILvdsStreamCfg (int32_t argc, char* argv[]);
*************************** Extern Definitions *******************************
extern MmwDemo_MCB gMmwMssMCB;
extern int32_t MmwDemo_mboxWrite(MmwDemo_message * message);
extern void MmwDemo_IniRSSDSSCfg(void);
*************************** CLI Function Definitions **************************
* @b Description
* @n
* This is the CLI Handler for the sensor start command
* @param[in] argc
* Number of arguments
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
bool doReconfig = true;
if (argc==2)
doReconfig = (bool) atoi (argv[1]);
/* Post sensorSTart event to notify configuration is done */
MmwDemo_notifySensorStart(doReconfig);
/* Pend for completion */
return (MmwDemo_waitSensorStartComplete());
* @b Description
* @n
* This is the CLI Handler for the sensor stop command
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
/* Post sensorSTOP event to notify sensor stop command */
MmwDemo_notifySensorStop();
MmwDemo_waitSensorStopComplete();
return 0;
static int32_t MmwDemo_CLIGetSubframe (int32_t argc, char* argv[], int32_t expectedArgc, int8_t* subFrameNum)
int8_t subframe;
/* Sanity Check: Minimum argument check */
if (argc != expectedArgc)
CLI_write ("Error: Invalid usage of the CLI command\n");
return -1;
/*Subframe info is always in position 1*/
subframe = (int8_t) atoi(argv[1]);
if(subframe >= (int8_t)RL_MAX_SUBFRAMES)
CLI_write ("Error: Subframe number is invalid\n");
return -1;
*subFrameNum = (int8_t)subframe;
return 0;
static void MmwDemo_mssCfgUpdate(void *srcPtr, uint32_t offset, uint32_t size, int8_t subFrameNum)
/* if subFrameNum undefined, broadcast to all sub-frames */
if(subFrameNum == MMWDEMO_SUBFRAME_NUM_FRAME_LEVEL_CONFIG)
uint8_t indx;
for(indx = 0; indx < RL_MAX_SUBFRAMES; indx++)
memcpy((void *)((uint32_t) &gMmwMssMCB.cliCfg[indx] + offset), srcPtr, size);
else
/* Apply configuration to specific subframe (or to position zero for the legacy case
where there is no advanced frame config) */
memcpy((void *)((uint32_t) &gMmwMssMCB.cliCfg[subFrameNum] + offset), srcPtr, size);
* @b Description
* @n
* This is the CLI Handler for gui monitoring configuration
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_GuiMonSel guiMonSel;
MmwDemo_message message;
int8_t subFrameNum;
if(MmwDemo_CLIGetSubframe(argc, argv, 8, &subFrameNum) < 0)
return -1;
/* Initialize the guiMonSel configuration: */
memset ((void *)&guiMonSel, 0, sizeof(MmwDemo_GuiMonSel));
/* Populate configuration: */
guiMonSel.detectedObjects = atoi (argv[2]);
guiMonSel.logMagRange = atoi (argv[3]);
guiMonSel.noiseProfile = atoi (argv[4]);
guiMonSel.rangeAzimuthHeatMap = atoi (argv[5]);
guiMonSel.rangeDopplerHeatMap = atoi (argv[6]);
guiMonSel.statsInfo = atoi (argv[7]);
MmwDemo_mssCfgUpdate((void *)&guiMonSel, offsetof(MmwDemo_CliCfg_t, guiMonSel),
sizeof(MmwDemo_GuiMonSel), subFrameNum);
/* Send configuration to DSS */
memset((void *)&message, 0, sizeof(MmwDemo_message));
message.type = MMWDEMO_MSS2DSS_GUIMON_CFG;
message.subFrameNum = subFrameNum;
memcpy((void *)&message.body.guiMonSel, (void *)&guiMonSel, sizeof(MmwDemo_GuiMonSel));
if (MmwDemo_mboxWrite(&message) == 0)
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for CFAR configuration
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_CfarCfg cfarCfg;
uint32_t procDirection;
int8_t subFrameNum;
if(MmwDemo_CLIGetSubframe(argc, argv, 9, &subFrameNum) < 0)
return -1;
/* Initialize configuration: */
memset ((void *)&cfarCfg, 0, sizeof(MmwDemo_CfarCfg));
procDirection = (uint32_t) atoi (argv[2]);
cfarCfg.averageMode = (uint8_t) atoi (argv[3]);
cfarCfg.winLen = (uint8_t) atoi (argv[4]);
cfarCfg.guardLen = (uint8_t) atoi (argv[5]);
cfarCfg.noiseDivShift = (uint8_t) atoi (argv[6]);
cfarCfg.cyclicMode = (uint8_t) atoi (argv[7]);
cfarCfg.thresholdScale = (uint16_t) atoi (argv[8]);
/* Save Configuration to use later */
if (procDirection == 0)
MmwDemo_mssCfgUpdate((void *)&cfarCfg, offsetof(MmwDemo_CliCfg_t, cfarCfgRange),
sizeof(MmwDemo_CfarCfg), subFrameNum);
else
MmwDemo_mssCfgUpdate((void *)&cfarCfg, offsetof(MmwDemo_CliCfg_t, cfarCfgDoppler),
message.type = MMWDEMO_MSS2DSS_CFAR_RANGE_CFG;
else if (procDirection == 1)
message.type = MMWDEMO_MSS2DSS_CFAR_DOPPLER_CFG;
else
return -1;
memcpy((void *)&message.body.cfarCfg, (void *)&cfarCfg, sizeof(MmwDemo_CfarCfg));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for Peak grouping configuration
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_PeakGroupingCfg peakGroupingCfg;
int8_t subFrameNum;
if(MmwDemo_CLIGetSubframe(argc, argv, 7, &subFrameNum) < 0)
return -1;
memset ((void *)&peakGroupingCfg, 0, sizeof(MmwDemo_PeakGroupingCfg));
peakGroupingCfg.scheme = (uint8_t) atoi (argv[2]);
peakGroupingCfg.inRangeDirectionEn = (uint8_t) atoi (argv[3]);
peakGroupingCfg.inDopplerDirectionEn = (uint8_t) atoi (argv[4]);
peakGroupingCfg.minRangeIndex = (uint16_t) atoi (argv[5]);
peakGroupingCfg.maxRangeIndex = (uint16_t) atoi (argv[6]);
if (peakGroupingCfg.scheme != 1 && peakGroupingCfg.scheme != 2)
CLI_write ("Error: Invalid peak grouping scheme\n");
return -1;
MmwDemo_mssCfgUpdate((void *)&peakGroupingCfg, offsetof(MmwDemo_CliCfg_t, peakGroupingCfg),
sizeof(MmwDemo_PeakGroupingCfg), subFrameNum);
message.type = MMWDEMO_MSS2DSS_PEAK_GROUPING_CFG;
memcpy((void *)&message.body.peakGroupingCfg, (void *)&peakGroupingCfg, sizeof(MmwDemo_PeakGroupingCfg));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for multi object beam forming configuration
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_MultiObjBeamFormingCfg cfg;
int8_t subFrameNum;
if(MmwDemo_CLIGetSubframe(argc, argv, 4, &subFrameNum) < 0)
return -1;
memset ((void *)&cfg, 0, sizeof(MmwDemo_MultiObjBeamFormingCfg));
cfg.enabled = (uint8_t) atoi (argv[2]);
cfg.multiPeakThrsScal = (float) atof (argv[3]);
MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, multiObjBeamFormingCfg),
sizeof(MmwDemo_MultiObjBeamFormingCfg), subFrameNum);
message.type = MMWDEMO_MSS2DSS_MULTI_OBJ_BEAM_FORM;
memcpy((void *)&message.body.multiObjBeamFormingCfg, (void *)&cfg, sizeof(MmwDemo_MultiObjBeamFormingCfg));
return 0;
else
return -1;
uint32_t log2Approx(uint32_t x)
uint32_t idx, detectFlag = 0;
if ( x < 2)
return (0);
idx = 32U;
while((detectFlag==0U) || (idx==0U))
if(x & 0x80000000U)
detectFlag = 1;
x <<= 1U;
idx--;
if(x != 0)
idx = idx + 1;
return(idx);
* @b Description
* @n
* This is the CLI Handler for DC range calibration
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_CalibDcRangeSigCfg cfg;
uint32_t log2NumAvgChirps;
int8_t subFrameNum;
if(MmwDemo_CLIGetSubframe(argc, argv, 6, &subFrameNum) < 0)
return -1;
/* Initialize configuration for DC range signature calibration */
memset ((void *)&cfg, 0, sizeof(MmwDemo_CalibDcRangeSigCfg));
cfg.enabled = (uint16_t) atoi (argv[2]);
cfg.negativeBinIdx = (int16_t) atoi (argv[3]);
cfg.positiveBinIdx = (int16_t) atoi (argv[4]);
cfg.numAvgChirps = (uint16_t) atoi (argv[5]);
if (cfg.negativeBinIdx > 0)
CLI_write ("Error: Invalid negative bin index\n");
return -1;
if ((cfg.positiveBinIdx - cfg.negativeBinIdx + 1) > DC_RANGE_SIGNATURE_COMP_MAX_BIN_SIZE)
CLI_write ("Error: Number of bins exceeds the limit\n");
return -1;
log2NumAvgChirps = (uint32_t) log2Approx (cfg.numAvgChirps);
if (cfg.numAvgChirps != (1 << log2NumAvgChirps))
CLI_write ("Error: Number of averaged chirps is not power of two\n");
return -1;
MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, calibDcRangeSigCfg),
sizeof(MmwDemo_CalibDcRangeSigCfg), subFrameNum);
message.type = MMWDEMO_MSS2DSS_CALIB_DC_RANGE_SIG;
memcpy((void *)&message.body.calibDcRangeSigCfg, (void *)&cfg, sizeof(MmwDemo_CalibDcRangeSigCfg));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for Velocity Disambiguation Configuration
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_ExtendedMaxVelocityCfg cfg;
int8_t subFrameNum;
if(MmwDemo_CLIGetSubframe(argc, argv, 3, &subFrameNum) < 0)
return -1;
memset ((void *)&cfg, 0, sizeof(MmwDemo_ExtendedMaxVelocityCfg));
MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, extendedMaxVelocityCfg),
sizeof(MmwDemo_ExtendedMaxVelocityCfg), subFrameNum);
message.type = MMWDEMO_MSS2DSS_EXTENDED_MAX_VELOCITY;
memcpy((void *)&message.body.extendedMaxVelocityCfg, (void *)&cfg, sizeof(MmwDemo_ExtendedMaxVelocityCfg));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for Near field correction Configuration
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_NearFieldCorrectionCfg cfg;
int8_t subFrameNum;
if(MmwDemo_CLIGetSubframe(argc, argv, 5, &subFrameNum) < 0)
return -1;
/* Initialize configuration for Near Field Correction */
memset ((void *)&cfg, 0, sizeof(MmwDemo_NearFieldCorrectionCfg));
cfg.enabled = (uint8_t) atoi(argv[2]);
cfg.startRangeIdx = (uint16_t) atoi(argv[3]);
cfg.endRangeIdx = (uint16_t) atoi(argv[4]);
MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, nearFieldCorrectionCfg),
sizeof(MmwDemo_NearFieldCorrectionCfg), subFrameNum);
message.type = MMWDEMO_MSS2DSS_NEAR_FIELD_CFG;
memcpy((void *)&message.body.nearFieldCorrectionCfg, (void *)&cfg,
return 0;
else
return -1;
* @b Description
* @n
* Clutter removal Configuration
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_ClutterRemovalCfg cfg;
int8_t subFrameNum;
return -1;
/* Initialize configuration for clutter removal */
memset ((void *)&cfg, 0, sizeof(MmwDemo_ClutterRemovalCfg));
MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, clutterRemovalCfg),
sizeof(MmwDemo_ClutterRemovalCfg), subFrameNum);
message.type = MMWDEMO_MSS2DSS_CLUTTER_REMOVAL;
memcpy((void *)&message.body.clutterRemovalCfg, (void *)&cfg, sizeof(MmwDemo_ClutterRemovalCfg));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for data logger set command
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
if (argc != 2)
return -1;
if (strcmp(argv[1], "mssLogger") == 0)
gMmwMssMCB.cfg.dataLogger = 0;
else if (strcmp(argv[1], "dssLogger") == 0)
gMmwMssMCB.cfg.dataLogger = 1;
else
return -1;
message.type = MMWDEMO_MSS2DSS_SET_DATALOGGER;
message.body.dataLogger = gMmwMssMCB.cfg.dataLogger;
return 0;
else
return -1;
* @b Description
* @n
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_ADCBufCfg adcBufCfg;
int8_t subFrameNum;
return -1;
/* Initialize the ADC Output configuration: */
memset ((void *)&adcBufCfg, 0, sizeof(MmwDemo_ADCBufCfg));
adcBufCfg.adcFmt = (uint8_t) atoi (argv[2]);
adcBufCfg.iqSwapSel = (uint8_t) atoi (argv[3]);
adcBufCfg.chInterleave = (uint8_t) atoi (argv[4]);
adcBufCfg.chirpThreshold = (uint8_t) atoi (argv[5]);
MmwDemo_mssCfgUpdate((void *)&adcBufCfg, offsetof(MmwDemo_CliCfg_t, adcBufCfg),
sizeof(MmwDemo_ADCBufCfg), subFrameNum);
message.type = MMWDEMO_MSS2DSS_ADCBUFCFG;
memcpy((void *)&message.body.adcBufCfg, (void *)&adcBufCfg, sizeof(MmwDemo_ADCBufCfg));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for compensation of range bias and channel phase offsets
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_compRxChannelBiasCfg_t cfg;
int32_t Re, Im;
int32_t argInd;
int32_t i;
if (argc != (1+1+SYS_COMMON_NUM_TX_ANTENNAS*SYS_COMMON_NUM_RX_CHANNEL*2))
return -1;
memset ((void *)&cfg, 0, sizeof(MmwDemo_compRxChannelBiasCfg_t));
cfg.rangeBias = (float) atof (argv[1]);
argInd = 2;
for (i=0; i < SYS_COMMON_NUM_TX_ANTENNAS*SYS_COMMON_NUM_RX_CHANNEL; i++)
Re = (int32_t) (atof (argv[argInd++]) * 32768.);
Re = MMWDEMO_SATURATE_HIGH(Re);
Re = MMWDEMO_SATURATE_LOW(Re);
cfg.rxChPhaseComp[i].real = (int16_t) Re;
Im = (int32_t) (atof (argv[argInd++]) * 32768.);
Im = MMWDEMO_SATURATE_HIGH(Im);
Im = MMWDEMO_SATURATE_LOW(Im);
cfg.rxChPhaseComp[i].imag = (int16_t) Im;
memcpy((void *) &gMmwMssMCB.cliCommonCfg.compRxChanCfg, &cfg, sizeof(MmwDemo_compRxChannelBiasCfg_t));
message.type = MMWDEMO_MSS2DSS_COMP_RANGE_BIAS_AND_RX_CHAN_PHASE;
memcpy((void *)&message.body.compRxChanCfg, (void *)&cfg, sizeof(MmwDemo_compRxChannelBiasCfg_t));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for measurement configuration of range bias
* and channel phase offsets
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
MmwDemo_measureRxChannelBiasCfg_t cfg;
if (argc != 4)
return -1;
memset ((void *)&cfg, 0, sizeof(MmwDemo_measureRxChannelBiasCfg_t));
cfg.enabled = (uint8_t) atoi (argv[1]);
cfg.targetDistance = (float) atof (argv[2]);
cfg.searchWinSize = (float) atof (argv[3]);
memcpy((void *) &gMmwMssMCB.cliCommonCfg.measureRxChanCfg, &cfg, sizeof(MmwDemo_measureRxChannelBiasCfg_t));
message.type = MMWDEMO_MSS2DSS_MEASURE_RANGE_BIAS_AND_RX_CHAN_PHASE;
memcpy((void *)&message.body.measureRxChanCfg, (void *)&cfg, sizeof(MmwDemo_measureRxChannelBiasCfg_t));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for BPM configuration supported by the mmw Demo
* Note that there is a generic BPM configuration command supported by
* utils/cli and mmwave. The generic BPM command is not supported by the
* demo as the mmw demo assumes a specific BPM pattern for the TX antennas.
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
static int32_t MmwDemo_CLIBpmCfg (int32_t argc, char* argv[])
int8_t subFrameNum;
MmwDemo_BpmCfg cfg;
if (argc != 5)
return -1;
return -1;
memset ((void *)&cfg, 0, sizeof(MmwDemo_BpmCfg));
cfg.isEnabled = (bool) atoi(argv[2]) ;
cfg.chirp0Idx = (uint16_t) atoi(argv[3]) ;
cfg.chirp1Idx = (uint16_t) atoi(argv[4]) ;
MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, bpmCfg),
sizeof(MmwDemo_BpmCfg), subFrameNum);
message.type = MMWDEMO_MSS2DSS_BPM_CFG;
memcpy((void *)&message.body.bpmCfg, (void *)&cfg, sizeof(MmwDemo_BpmCfg));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for configuring CQ RX Saturation monitor
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
rlRxSatMonConf_t cqSatMonCfg;
if (argc != 6)
return -1;
memset ((void *)&cqSatMonCfg, 0, sizeof(rlRxSatMonConf_t));
cqSatMonCfg.profileIndx = (uint8_t) atoi (argv[1]);
if(cqSatMonCfg.profileIndx < RL_MAX_PROFILES_CNT)
cqSatMonCfg.satMonSel = (uint8_t) atoi (argv[2]);
cqSatMonCfg.primarySliceDuration = (uint16_t) atoi (argv[3]);
cqSatMonCfg.numSlices = (uint16_t) atoi (argv[4]);
cqSatMonCfg.rxChannelMask = (uint8_t) atoi (argv[5]);
memcpy((void *) &gMmwMssMCB.cliCommonCfg.cqSatMonCfg[cqSatMonCfg.profileIndx],
&cqSatMonCfg,
message.type = MMWDEMO_MSS2DSS_CQ_SATURATION_MONITOR;
memcpy((void *)&message.body.cqSatMonCfg, (void *)&cqSatMonCfg, sizeof(rlRxSatMonConf_t));
return 0;
else
return -1;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for configuring CQ Singal & Image band monitor
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
rlSigImgMonConf_t cqSigImgMonCfg;
if (argc != 4)
return -1;
memset ((void *)&cqSigImgMonCfg, 0, sizeof(rlSigImgMonConf_t));
cqSigImgMonCfg.profileIndx = (uint8_t) atoi (argv[1]);
if(cqSigImgMonCfg.profileIndx < RL_MAX_PROFILES_CNT)
cqSigImgMonCfg.numSlices = (uint8_t) atoi (argv[2]);
cqSigImgMonCfg.timeSliceNumSamples = (uint16_t) atoi (argv[3]);
memcpy((void *) &gMmwMssMCB.cliCommonCfg.cqSigImgMonCfg[cqSigImgMonCfg.profileIndx],
&cqSigImgMonCfg,
message.type = MMWDEMO_MSS2DSS_CQ_SIGIMG_MONITOR;
memcpy((void *)&message.body.cqSigImgMonCfg, (void *)&cqSigImgMonCfg, sizeof(rlSigImgMonConf_t));
return 0;
else
return -1;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for enabling analog monitors
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
if (argc != 3)
return -1;
gMmwMssMCB.cliCommonCfg.anaMonCfg.rxSatMonEn = atoi (argv[1]);
gMmwMssMCB.cliCommonCfg.anaMonCfg.sigImgMonEn = atoi (argv[2]);
message.type = MMWDEMO_MSS2DSS_ANALOG_MONITOR;
memcpy((void *)&message.body.anaMonCfg,
(void *)&gMmwMssMCB.cliCommonCfg.anaMonCfg,
sizeof(MmwDemo_AnaMonitorCfg));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Handler for the High Speed Interface
* @param[in] argc
* @param[in] argv
* Arguments
* @retval
* Success - 0
* @retval
* Error - <0
int8_t subFrameNum;
MmwDemo_LvdsStreamCfg cfg;
if (argc != 5)
return -1;
return -1;
memset ((void *)&cfg, 0, sizeof(MmwDemo_LvdsStreamCfg));
cfg.isHeaderEnabled = (bool) atoi(argv[2]) ;
cfg.dataFmt = (uint8_t) atoi(argv[3]) ;
cfg.isSwEnabled = (bool) atoi(argv[4]) ;
MmwDemo_mssCfgUpdate((void *)&cfg, offsetof(MmwDemo_CliCfg_t, lvdsStreamCfg),
sizeof(MmwDemo_LvdsStreamCfg), subFrameNum);
message.type = MMWDEMO_MSS2DSS_LVDSSTREAM_CFG;
memcpy((void *)&message.body.lvdsStreamCfg, (void *)&cfg, sizeof(MmwDemo_LvdsStreamCfg));
return 0;
else
return -1;
* @b Description
* @n
* This is the CLI Execution Task
* @retval
* Not Applicable.
void MmwDemo_CLIInit (void)
CLI_Cfg cliCfg;
char demoBanner[256];
uint32_t cnt;
/* Create Demo Banner to be printed out by CLI */
sprintf(&demoBanner[0],
"******************************************\n" \
"xWR16xx MMW Demo %02d.%02d.%02d.%02d\n" \
"******************************************\n",
MMWAVE_SDK_VERSION_MAJOR,
MMWAVE_SDK_VERSION_MINOR,
MMWAVE_SDK_VERSION_BUGFIX,
MMWAVE_SDK_VERSION_BUILD
/* Initialize the CLI configuration: */
memset ((void *)&cliCfg, 0, sizeof(CLI_Cfg));
/* Populate the CLI configuration: */
cliCfg.cliPrompt = "mmwDemo:/>";
cliCfg.cliBanner = demoBanner;
cliCfg.cliUartHandle = gMmwMssMCB.commandUartHandle;
cliCfg.taskPriority = 3;
cliCfg.mmWaveHandle = gMmwMssMCB.ctrlHandle;
cliCfg.enableMMWaveExtension = 1U;
cliCfg.usePolledMode = true;
cnt=0;
cliCfg.tableEntry[cnt].cmd = "sensorStart";
cliCfg.tableEntry[cnt].helpString = "[doReconfig(optional, default:enabled)]";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLISensorStart;
cnt++;
cliCfg.tableEntry[cnt].cmd = "sensorStop";
cliCfg.tableEntry[cnt].helpString = "No arguments";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLISensorStop;
cnt++;
cliCfg.tableEntry[cnt].cmd = "guiMonitor";
cliCfg.tableEntry[cnt].helpString = "<subFrameIdx> <detectedObjects> <logMagRange> <noiseProfile> <rangeAzimuthHeatMap> <rangeDopplerHeatMap> <statsInfo>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIGuiMonSel;
cnt++;
cliCfg.tableEntry[cnt].cmd = "cfarCfg";
cliCfg.tableEntry[cnt].helpString = "<subFrameIdx> <procDirection> <averageMode> <winLen> <guardLen> <noiseDiv> <cyclicMode> <thresholdScale>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLICfarCfg;
cnt++;
cliCfg.tableEntry[cnt].cmd = "peakGrouping";
cliCfg.tableEntry[cnt].helpString = "<subFrameIdx> <groupingMode> <rangeDimEn> <dopplerDimEn> <startRangeIdx> <endRangeIdx>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIPeakGroupingCfg;
cnt++;
cliCfg.tableEntry[cnt].cmd = "dataLogger";
cliCfg.tableEntry[cnt].helpString = "<mssLogger | dssLogger>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLISetDataLogger;
cnt++;
cliCfg.tableEntry[cnt].cmd = "multiObjBeamForming";
cliCfg.tableEntry[cnt].helpString = "<subFrameIdx> <enabled> <threshold>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIMultiObjBeamForming;
cnt++;
cliCfg.tableEntry[cnt].cmd = "calibDcRangeSig";
cliCfg.tableEntry[cnt].helpString = "<subFrameIdx> <enabled> <negativeBinIdx> <positiveBinIdx> <numAvgFrames>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLICalibDcRangeSig;
cnt++;
cliCfg.tableEntry[cnt].cmd = "extendedMaxVelocity";
cliCfg.tableEntry[cnt].helpString = "<subFrameIdx> <enabled>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIExtendedMaxVelocity;
cnt++;
cliCfg.tableEntry[cnt].cmd = "clutterRemoval";
cliCfg.tableEntry[cnt].helpString = "<enabled>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIClutterRemoval;
cnt++;
cliCfg.tableEntry[cnt].cmd = "adcbufCfg";
cliCfg.tableEntry[cnt].helpString = "<subFrameIdx> <adcOutputFmt> <SampleSwap> <ChanInterleave> <ChirpThreshold>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIADCBufCfg;
cnt++;
cliCfg.tableEntry[cnt].cmd = "compRangeBiasAndRxChanPhase";
cliCfg.tableEntry[cnt].helpString = "<rangeBias> <Re00> <Im00> <Re01> <Im01> <Re02> <Im02> <Re03> <Im03> <Re10> <Im10> <Re11> <Im11> <Re12> <Im12> <Re13> <Im13> ";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLICompRangeBiasAndRxChanPhaseCfg;
cnt++;
cliCfg.tableEntry[cnt].cmd = "measureRangeBiasAndRxChanPhase";
cliCfg.tableEntry[cnt].helpString = "<enabled> <targetDistance> <searchWin>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIMeasureRangeBiasAndRxChanPhaseCfg;
cnt++;
cliCfg.tableEntry[cnt].cmd = "bpmCfg";
cliCfg.tableEntry[cnt].helpString = "<subFrameIdx> <enabled> <chirp0Idx> <chirp1Idx>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIBpmCfg;
cnt++;
cliCfg.tableEntry[cnt].cmd = "nearFieldCfg";
cliCfg.tableEntry[cnt].helpString = "<enabled> <startRangeIndex> <endRangeIndex>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLINearFieldCorrection;
cnt++;
cliCfg.tableEntry[cnt].cmd = "CQRxSatMonitor";
cliCfg.tableEntry[cnt].helpString = "<profile> <satMonSel> <priSliceDuration> <numSlices> <rxChanMask>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIChirpQualityRxSatMonCfg;
cnt++;
cliCfg.tableEntry[cnt].cmd = "CQSigImgMonitor";
cliCfg.tableEntry[cnt].helpString = "<profile> <numSlices> <numSamplePerSlice>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIChirpQualitySigImgMonCfg;
cnt++;
cliCfg.tableEntry[cnt].cmd = "analogMonitor";
cliCfg.tableEntry[cnt].helpString = "<rxSaturation> <sigImgBand>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLIAnalogMonitorCfg;
cnt++;
cliCfg.tableEntry[cnt].cmd = "lvdsStreamCfg";
cliCfg.tableEntry[cnt].helpString = "<subFrameIdx> <enableHeader> <dataFmt> <enableSW>";
cliCfg.tableEntry[cnt].cmdHandlerFxn = MmwDemo_CLILvdsStreamCfg;
cnt++;
/* Open the CLI: */
if (CLI_open (&cliCfg) < 0)
System_printf ("Error: Unable to open the CLI\n");
return;
System_printf ("Debug: CLI is operational\n");
return;
MmwDemo_IniRSSDSSCfg();
* @file ini_cfg.c
* Created on: Nov 9, 2017
* Author: hstubeda
* @brief
* MMWave Demo automatic self-configuration
* \par
* NOTE:
* (C) Copyright 2017 Ross Video, Ltd.
* are met:
* distribution.
#include <string.h>
#include <ti/utils/cli/include/cli_internal.h>
/* local includes */
//#include "cli.h"
#include "ini_cfg.h"
extern int32_t MmwDemo_CLICfarCfg (int32_t argc, char* argv[]);
extern int32_t MmwDemo_CLIPeakGroupingCfg (int32_t argc, char* argv[]);
extern int32_t MmwDemo_CLIMultiObjBeamForming (int32_t argc, char* argv[]);
extern int32_t MmwDemo_CLICalibDcRangeSig (int32_t argc, char* argv[]);
extern int32_t MmwDemo_CLISensorStart (int32_t argc, char* argv[]);
extern int32_t MmwDemo_CLISensorStop (int32_t argc, char* argv[]);
extern int32_t MmwDemo_CLIGuiMonSel (int32_t argc, char* argv[]);
extern int32_t MmwDemo_CLISetDataLogger (int32_t argc, char* argv[]);
****************** Local Function Definitions ***************************
* @b Description
* @n
* This function uses CLI command string to configure the sensor;
* This function can be run from within code, and does not require user input from CLI.
* @param[in] cmd[]
* CLI command, broken into its constituent arguments
* e.g multiObjBeamForming 1 0.5 is {"multiObjBeamForming", "1", "0.5"}
* @retval
* Not Applicable.
void MmwDemo_CfgWithCmdString (uint32_t num_arg, char* cmd[])
if( strcmp("sensorStop", cmd[0]) == 0)
MmwDemo_CLISensorStop (num_arg, cmd);
else if(strcmp("guiMonitor", cmd[0]) == 0)
MmwDemo_CLIGuiMonSel (num_arg, cmd);
else if(strcmp("cfarCfg", cmd[0]) == 0)
MmwDemo_CLICfarCfg (num_arg, cmd);
else if(strcmp("peakGrouping", cmd[0]) == 0)
MmwDemo_CLIPeakGroupingCfg (num_arg, cmd);
else if(strcmp("multiObjBeamForming", cmd[0]) == 0)
MmwDemo_CLIMultiObjBeamForming(num_arg, cmd);
else if(strcmp("calibDcRangeSig", cmd[0]) == 0)
MmwDemo_CLICalibDcRangeSig (num_arg, cmd);
else if(strcmp("sensorStart", cmd[0]) == 0)
MmwDemo_CLISensorStart (num_arg, cmd);
else
CLI_MMWaveExtensionHandler (num_arg, cmd);
return;
* @b Description
* @n
* This function instantiates initial configuration structure using CLI command strings,
* and uses these strings to configure the sensor
* @param[in] cmd
* Commands
* @retval
* Not Applicable.
String_Cfg_Cmds iniCfgCmds;
uint32_t c = 0;
iniCfgCmds.sensorStop[0] = "sensorStop";
iniCfgCmds.flushCfg[0] = "flushCfg";
iniCfgCmds.dfeDataOutputMode[0] = "dfeDataOutputMode";
iniCfgCmds.dfeDataOutputMode[1] = "1";
iniCfgCmds.channelCfg[0] = "channelCfg";
iniCfgCmds.channelCfg[1] = "15";
iniCfgCmds.channelCfg[2] = "3";
iniCfgCmds.channelCfg[3] = "0";
iniCfgCmds.adcCfg[0] = "adcCfg";
iniCfgCmds.adcCfg[1] = "2";
iniCfgCmds.adcCfg[2] = "1";
iniCfgCmds.adcbufCfg[0] = "adcbufCfg";
iniCfgCmds.adcbufCfg[1] = "0";
iniCfgCmds.adcbufCfg[2] = "0";
iniCfgCmds.adcbufCfg[3] = "1";
iniCfgCmds.adcbufCfg[4] = "1";
iniCfgCmds.profileCfg [0] = "profileCfg";
iniCfgCmds.profileCfg[ 1] = "0";
iniCfgCmds.profileCfg[ 2] = "77";
iniCfgCmds.profileCfg[ 3] = "194";
iniCfgCmds.profileCfg[ 4] = "7";
iniCfgCmds.profileCfg[ 5] = "40";
iniCfgCmds.profileCfg[ 6] = "0";
iniCfgCmds.profileCfg[ 7] = "0";
iniCfgCmds.profileCfg[ 8] = "100";
iniCfgCmds.profileCfg[ 9] = "1";
iniCfgCmds.profileCfg[10] = "64";
iniCfgCmds.profileCfg[11] = "2000";
iniCfgCmds.profileCfg[12] = "0";
iniCfgCmds.profileCfg[13] = "0";
iniCfgCmds.profileCfg[14] = "30";
iniCfgCmds.chirpCfg1[0] = "chirpCfg";
iniCfgCmds.chirpCfg1[1] = "0";
iniCfgCmds.chirpCfg1[2] = "0";
iniCfgCmds.chirpCfg1[3] = "0";
iniCfgCmds.chirpCfg1[4] = "0";
iniCfgCmds.chirpCfg1[5] = "0";
iniCfgCmds.chirpCfg1[6] = "0";
iniCfgCmds.chirpCfg1[7] = "0";
iniCfgCmds.chirpCfg1[8] = "1";
iniCfgCmds.chirpCfg2[0] = "chirpCfg";
iniCfgCmds.chirpCfg2[1] = "1";
iniCfgCmds.chirpCfg2[2] = "1";
iniCfgCmds.chirpCfg2[3] = "0";
iniCfgCmds.chirpCfg2[4] = "0";
iniCfgCmds.chirpCfg2[5] = "0";
iniCfgCmds.chirpCfg2[6] = "0";
iniCfgCmds.chirpCfg2[7] = "0";
iniCfgCmds.chirpCfg2[8] = "2";
iniCfgCmds.frameCfg[0] = "frameCfg";
iniCfgCmds.frameCfg[1] = "0";
iniCfgCmds.frameCfg[2] = "1";
iniCfgCmds.frameCfg[3] = "16";
iniCfgCmds.frameCfg[4] = "0";
iniCfgCmds.frameCfg[5] = "100";
iniCfgCmds.frameCfg[6] = "1";
iniCfgCmds.frameCfg[7] = "0"; //frame delay upon sensor startup; change this value between different sensors to avoid sensor cross-interference
iniCfgCmds.guiMonitor[0] = "guiMonitor";
iniCfgCmds.guiMonitor[1] = "1";
iniCfgCmds.guiMonitor[2] = "0";
iniCfgCmds.guiMonitor[3] = "0";
iniCfgCmds.guiMonitor[4] = "0";
iniCfgCmds.guiMonitor[5] = "0";
iniCfgCmds.guiMonitor[6] = "0";
iniCfgCmds.cfarCfgRange[0] = "cfarCfg";
iniCfgCmds.cfarCfgRange[1] = "0";
iniCfgCmds.cfarCfgRange[2] = "0";
iniCfgCmds.cfarCfgRange[3] = "8";
iniCfgCmds.cfarCfgRange[4] = "4";
iniCfgCmds.cfarCfgRange[5] = "4";
iniCfgCmds.cfarCfgRange[6] = "0";
iniCfgCmds.cfarCfgRange[7] = "5120";
iniCfgCmds.cfarCfgDoppler[0] = "cfarCfg";
iniCfgCmds.cfarCfgDoppler[1] = "1";
iniCfgCmds.cfarCfgDoppler[2] = "0";
iniCfgCmds.cfarCfgDoppler[3] = "4";
iniCfgCmds.cfarCfgDoppler[4] = "2";
iniCfgCmds.cfarCfgDoppler[5] = "3";
iniCfgCmds.cfarCfgDoppler[6] = "0";
iniCfgCmds.cfarCfgDoppler[7] = "3413";
iniCfgCmds.peakGrouping[0] = "peakGrouping";
iniCfgCmds.peakGrouping[1] = "1";
iniCfgCmds.peakGrouping[2] = "1";
iniCfgCmds.peakGrouping[3] = "1";
iniCfgCmds.peakGrouping[4] = "1";
iniCfgCmds.peakGrouping[5] = "63";
iniCfgCmds.multiObjBeamForming[0] = "multiObjBeamForming";
iniCfgCmds.multiObjBeamForming[1] = "1";
iniCfgCmds.multiObjBeamForming[2] = "0.5";
iniCfgCmds.calibDcRangeSig[0] = "calibDcRangeSig";
iniCfgCmds.calibDcRangeSig[1] = "1";
iniCfgCmds.calibDcRangeSig[2] = "-5";
iniCfgCmds.calibDcRangeSig[3] = "20";
iniCfgCmds.calibDcRangeSig[4] = "256";
iniCfgCmds.sensorStart[0] = "sensorStart";
//arrays cannot be set like this in C; need to copy them, or set each pointer individually, as was done above
//iniCfgCmds.sensorStop = {"sensorStop"};
//iniCfgCmds.flushCfg = {"flushCfg"};
//iniCfgCmds.dfeDataOutputMode = {"dfeDataOutputMode", "1"};
//iniCfgCmds.channelCfg = {"channelCfg", "15", "3", "0"};
//iniCfgCmds.adcCfg = {"adcCfg", "2", "1"};
//iniCfgCmds.adcbufCfg = {"adcbufCfg", "0", "0", "1", "1"};
//iniCfgCmds.profileCfg = {"profileCfg", "0", "77", "194", "7", "40", "0", "0", "100", "1", "64", "2000", "0", "0", "30"};
//iniCfgCmds.chirpCfg1 = {"chirpCfg1", "0", "0", "0", "0", "0", "0", "0", "1"};
//iniCfgCmds.chirpCfg2 = {"chirpCfg2", "1", "1", "0", "0", "0", "0", "0", "2"};
//iniCfgCmds.frameCfg = {"frameCfg", "0", "1", "16", "0", "100", "1", "0"};
//iniCfgCmds.guiMonitor = {"guiMonitor", "1", "0", "0", "0", "0", "0"};
//iniCfgCmds.cfarCfgRange = {"cfarCfg", "0", "0", "8", "4", "4", "0", "3413"};
//iniCfgCmds.cfarCfgDoppler = {"cfarCfg", "1", "0", "4", "2", "3", "0", "5120"};
//iniCfgCmds.peakGrouping = {"peakGrouping", "1", "1", "1", "1", "63"};
//iniCfgCmds.multiObjBeamForming = {"multiObjBeamForming", "1", "0.5"};
//iniCfgCmds.calibDcRangeSig = {"calibDcRangeSig", "1", "-5", "20", "256"};
//iniCfgCmds.sensorStart = {"sensorStart"};
MmwDemo_CfgWithCmdString ( 1, iniCfgCmds.sensorStop );
for (c = 1 ; c <= 50000000 ; c++); //this delay ensures the sensor stops
MmwDemo_CfgWithCmdString ( 1, iniCfgCmds.flushCfg );
MmwDemo_CfgWithCmdString ( 2, iniCfgCmds.dfeDataOutputMode );
MmwDemo_CfgWithCmdString ( 4, iniCfgCmds.channelCfg );
MmwDemo_CfgWithCmdString ( 3, iniCfgCmds.adcCfg );
MmwDemo_CfgWithCmdString ( 5, iniCfgCmds.adcbufCfg );
MmwDemo_CfgWithCmdString (15, iniCfgCmds.profileCfg );
MmwDemo_CfgWithCmdString ( 9, iniCfgCmds.chirpCfg1 );
MmwDemo_CfgWithCmdString ( 9, iniCfgCmds.chirpCfg2 );
MmwDemo_CfgWithCmdString ( 8, iniCfgCmds.frameCfg );
MmwDemo_CfgWithCmdString ( 7, iniCfgCmds.guiMonitor );
MmwDemo_CfgWithCmdString ( 8, iniCfgCmds.cfarCfgRange );
MmwDemo_CfgWithCmdString ( 8, iniCfgCmds.cfarCfgDoppler );
MmwDemo_CfgWithCmdString ( 6, iniCfgCmds.peakGrouping );
MmwDemo_CfgWithCmdString ( 3, iniCfgCmds.multiObjBeamForming);
MmwDemo_CfgWithCmdString ( 5, iniCfgCmds.calibDcRangeSig );
MmwDemo_CfgWithCmdString ( 1, iniCfgCmds.sensorStart );
return;
* @file ini_cfg.h
* Author: hstubeda
* @brief
* MMWave Demo automatic self-configuration header file
* \par
* NOTE:
* are met:
* distribution.
#ifndef INI_CFG_H_
#define INI_CFG_H_
#include <string.h>
#ifdef __cplusplus
extern "C" {
#endif
* @brief
* Configuration Commands Structure
* @details
* The structure is used to hold all initial configuration parameters for the
* Millimeter Wave sensor; see mmwave_sdk_user_guide for parameter examples and descriptions
typedef struct String_Cfg_Cmds_t
/*! @brief */
char* sensorStop[1];
/*! @brief */
char* flushCfg[1];
/*! @brief */
char* dfeDataOutputMode[2];
/*! @brief */
char* channelCfg[4];
/*! @brief */
char* adcCfg[3];
/*!@brief */
char* adcbufCfg[5];
/*! @brief */
char* profileCfg[15];
/*! @brief */
char* chirpCfg1[9];
/*! @brief */
char* chirpCfg2[9];
/*! @brief */
char* frameCfg[8];
/*! @brief */
char* guiMonitor[7];
/*! @brief */
char* cfarCfgRange[8];
/*! @brief */
char* cfarCfgDoppler[8];
/*! @brief */
char* peakGrouping[6];
/*! @brief */
char* multiObjBeamForming[3];
/*! @brief */
char* calibDcRangeSig[5];
/*! @brief */
char* sensorStart[1];
} String_Cfg_Cmds;
* @b Description
* @n
* This is the configuration command handler, when we want to configure sensor from within software
* @param[in] cmd
* Commands
* @retval
* Not Applicable.
void MmwDemo_CfgWithCmdString (uint32_t num_arg, char* cmd[]);
#ifdef __cplusplus
#endif
#endif /* INI_CFG_H_ */
