Other Parts Discussed in Thread: DCA1000EVM
5.16.12 Sub block 0x404B – AWR_DEV_TESTPATTERN_GEN_SET_SB
This sub block contains the confifigurations to setup the test pattern to be generated and trans
ferred over the selected high speed interface (LVDS). This command has to be issued after the
data path confifigurations commands are issued. This can be used to perform a sanity test of the
high speed interface connectivity and correct reception.
Table 5.137 describes the contents of this sub block.
关于AWR2243-LVDS-HSI-TEST-MODE的设置,我想咨询一下关于Sub block 0x404B – AWR_DEV_TESTPATTERN_GEN_SET_SB此命令的使用,配置的顺序是否有特殊要求,文档上面说的是需要放在datapath之后,就可以了,但是我通过读回指令,读回设置的参数,发现读回这个功能对应的参数都是零,并非我设置的值,请问是什么原因导致的呢?如下是我相关部分的代码:
参数设置函数:
#ifdef HSI_TEST_ENABLE
int MMWL_HSItestCfg(unsigned int deviceMap)
int32_t retVal = 0;
rltestPattern_t hsitestdata;
hsitestdata.testPatGenCtrl = 1;
hsitestdata.testPatGenTime = 1;
hsitestdata.testPatrnPktSize = 64;
hsitestdata.numTestPtrnPkts = 0;
hsitestdata.testPatRx0Icfg = 0x00010001;
hsitestdata.testPatRx0Qcfg = 0x00020002;
hsitestdata.testPatRx1Icfg = 0x00030003;
hsitestdata.testPatRx1Qcfg = 0x00040004;
hsitestdata.testPatRx2Icfg = 0x00050005;
hsitestdata.testPatRx2Qcfg = 0x00060006;
hsitestdata.testPatRx3Icfg = 0x00070007;
hsitestdata.testPatRx3Qcfg = 0x00080008;
retVal = rlDeviceSetTestPatternConfig(deviceMap, &hsitestdata);
return retVal;
参数配置函数配置顺序如下:
retVal = MMWL_dataPathConfig(deviceMap);
if (retVal != RL_RET_CODE_OK)
#ifdef UART_DEBUG_INFO
UART_WriteStr(UART0,"MMWL_dataPathConfig fail!!!\n\r");
#endif
return -1;
UART_WriteStr(UART0,"MMWL_dataPathConfig success!!!\n\r");
#endif
retVal = MMWL_HSItestCfg(deviceMap);
UART_WriteStr(UART0,"MMWL_HSItestCfg fail!!!\n\r");
#endif
return -1;
UART_WriteStr(UART0,"MMWL_HSItestCfg success!!!\n\r");
#endif
#endif
retVal = MMWL_hsiClockConfig(deviceMap);
UART_WriteStr(UART0,"MMWL_hsiClockConfig fail!!!\n\r");
#endif
return -1;
UART_WriteStr(UART0,"MMWL_hsiClockConfig success!!!\n\r");
#endif
UART_WriteStr(UART0,"MMWL_hsiLaneConfig fail!!!\n\r");
#endif
return -1;
UART_WriteStr(UART0,"MMWL_hsiLaneConfig success!!!\n\r");
#endif
