Other Parts Discussed in Thread: , IWR6843AOP
AWR6843AOP 天线端口平均输出功率是多少?天线端口峰值输出功率是多少?Antenna Max. Peak Gain是多少dBi?
请参考下面AWR6843AOPEVM user guide。
The IWR6843AOP and AWR6843AOP operate at a 4-Ghz bandwidth from 60 to 64 GHz, with a maximum output power of 10 dBm and an antenna gain of ~5 dBi.
https://www.ti.com/lit/ug/swru546e/swru546e.pdf
可以参考数据手册里的8.10.1.2 Antenna Radiation Patterns for Transmitter
https://www.ti.com/lit/ds/symlink/awr6843aop.pdf
