请问执行到哪一步报上面的错?安装的是\mmwave_studio_03_00_00_14\docs\mmwave_studio_user_guide.pdf文档里提供的下载链接吗?
2. Install 32-bit Matlab Runtime Engine (Version 8.5.1): It is used to run the PostProcessing utility within mmWaveStudio. in.mathworks.com/.../R2015 aSP1/installers/win32/MCR_R2015aSP1_win32_installer.exe NOTE: Please make sure the Matlab Runtime Engine installed is exactly same as 32-bit Version 8.5.1
是用的文档里的下载链接,执行到最后一步“Run the following command: mmwave_studio_cli.exe”时出错,只能采集4秒的数据,4秒后后就会出现该报错信息。
