Other Parts Discussed in Thread: MATHLIB
您好,我在在根据mmwave_mcuplus_sdk_user_guide的build demo 部分的操作进行cmd命令行操作时,我发现我可以正确设置环境,然后运行gamke all,但是他好像无法识别ti-cgt-c6000_8.3.12,我尝试把这个编译器从新下载到其他地方并且修改对应的环境位置,但是它还是提示错误,报错如下图所示,我安装CGT的位置也如下图所指示,我的完整cmd编译在下面给出。请帮我分析一下是什么问题导致的无法识别这个cgt
Microsoft Windows [版本 10.0.19044.2364] (c) Microsoft Corporation。保留所有权利。 C:\Users\try3701>D: D:\>CD D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>setenv.bat D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set MMWAVE_SDK_DEVICE=am273x D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set DOWNLOAD_FROM_CCS=yes D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set MMWAVE_SDK_TOOLS_INSTALL_PATH=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set MMWAVE_SDK_INSTALL_PATH=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set CCS_INSTALL_PATH=C:\ti\ccs1120 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set R5F_CLANG_INSTALL_PATH=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/ti-cgt-armllvm_2.1.1.LTS D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set XDC_INSTALL_PATH=C:\ti\ccs1120/xdctools_3_62_01_16_core D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set MMWAVE_XWR2XXX_DFP_INSTALL_PATH=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_dfp_02_02_04_00 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>SET MCU_PLUS_AM273X_INSTALL_PATH=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mcu_plus_sdk_am273x_08_04_00_17 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>SET MCU_PLUS_AWR294X_INSTALL_PATH=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mcu_plus_sdk_awr294x_08_04_00_22 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>SET SYSCONFIG_INSTALL_PATH=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/sysconfig_1.13.0 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set MMWAVE_AWR294X_DFP_INSTALL_PATH=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_dfp_02_04_05_00 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set AWR294X_RADARSS_IMAGE_BIN=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_dfp_02_04_05_00/firmware/radarss/xwr2xxx_radarss_metarprc.bin D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set C66X_CODEGEN_INSTALL_PATH=D:\zj\AWR2243\ti-cgt-c6000_8.3.12 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set C66x_DSPLIB_INSTALL_PATH=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/dsplib_c66x_3_4_0_0 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>set C66x_MATHLIB_INSTALL_PATH=D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mathlib_c66x_3_1_2_1 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>call checkenv.bat ----------------------------------------------- mmWave Build Environment Configured ----------------------------------------------- D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\scripts\windows>cd ..\..\ti\demo\am273x\mmw D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw>gmake all gmake PROC_CHAIN=TDM objClean mmwDemo bin gmake[1]: Entering directory 'D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/demo/am273x/mmw' Cleaning the Millimeter Wave Demo MSS Objects Cleaning the Millimeter Wave Demo DSS Objects Cleaning the syscfg files Generating SysConfig files ... D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/sysconfig_1.13.0/nodejs/node D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/sysconfig_1.13.0/dist/cli.js --product D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mcu_plus_sdk_am273x_08_04_00_17/.metadata/product.json --context r5fss0-0 --part Default --package ZCE --output ./mss/mssgenerated/ ./mss/mss.syscfg Running script... Validating... Generating Code (mss.syscfg)... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_dpl_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_dpl_config.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_drivers_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_drivers_config.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_drivers_open_close.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_drivers_open_close.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_pinmux_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_power_clock_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_board_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_board_config.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_board_open_close.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_board_open_close.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_enet_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_enet_config.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_enet_open_close.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_enet_open_close.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\mss\mssgenerated\ti_enet_soc.c... Generating SysConfig files ... D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/sysconfig_1.13.0/nodejs/node D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/sysconfig_1.13.0/dist/cli.js --product D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mcu_plus_sdk_am273x_08_04_00_17/.metadata/product.json --context c66ss0 --part Default --package ZCE --output ./dss/dssgenerated/ ./dss/dss.syscfg Running script... Validating... Generating Code (dss.syscfg)... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_dpl_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_dpl_config.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_drivers_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_drivers_config.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_drivers_open_close.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_drivers_open_close.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_pinmux_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_power_clock_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_board_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_board_config.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_board_open_close.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_board_open_close.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_enet_config.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_enet_config.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_enet_open_close.c... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_enet_open_close.h... Writing D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw\dss\dssgenerated\ti_enet_soc.c... [R5 Device/Type: am273x/am273x] Building file: D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/demo/utils/mmwdemo_adcconfig.c [R5 Device/Type: am273x/am273x] Building file: D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/demo/utils/mmwdemo_monitor.c [R5 Device/Type: am273x/am273x] Building file: ./mss/mmw_cli.c [R5 Device/Type: am273x/am273x] Building file: D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/demo/utils/mmwdemo_flash.c [R5 Device/Type: am273x/am273x] Building file: ./mss/mss_main.c [R5 Device/Type: am273x/am273x] Building file: D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/demo/utils/mmwdemo_rfparser.c [R5 Device/Type: am273x/am273x] Building file: ./mss/mssgenerated/ti_board_config.c [R5 Device/Type: am273x/am273x] Building file: ./mss/mssgenerated/ti_board_open_close.c [R5 Device/Type: am273x/am273x] Building file: ./mss/mssgenerated/ti_dpl_config.c [R5 Device/Type: am273x/am273x] Building file: ./mss/mssgenerated/ti_drivers_config.c [R5 Device/Type: am273x/am273x] Building file: ./mss/mssgenerated/ti_pinmux_config.c [R5 Device/Type: am273x/am273x] Building file: ./mss/mssgenerated/ti_power_clock_config.c [R5 Device/Type: am273x/am273x] Building file: ./mss/mssgenerated/ti_drivers_open_close.c D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/ti-cgt-armllvm_2.1.1.LTS/bin/tiarmclang -Wl,--diag_suppress=10063 -Wl,--ram_model -Wl,--reread_libs -Wl,-iD:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mcu_plus_sdk_am273x_08_04_00_17/source/kernel/freertos/lib -Wl,-iD:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mcu_plus_sdk_am273x_08_04_00_17/source/drivers/lib -Wl,-iD:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mcu_plus_sdk_am273x_08_04_00_17/source/board/lib -Wl,-iD:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/ti-cgt-armllvm_2.1.1.LTS/lib -Wl,-iD:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/control/mmwavelink/lib -Wl,-iD:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/control/mmwave/lib -Wl,-iD:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/utils/cli/lib -Wl,-iD:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/control/dpm/lib -Wl,-iD:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/utils/mathutils/lib -Wl,-iD:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/utils/testlogger/lib -Wl,-m=am273x_mmw_demo_mssTDM.map \ -o am273x_mmw_demo_mssTDM.xer5f obj_am273x/mmwdemo_adcconfig.oer5f obj_am273x/mmwdemo_monitor.oer5f obj_am273x/mmw_cli.oer5f obj_am273x/mmwdemo_flash.oer5f obj_am273x/mss_main.oer5f obj_am273x/mmwdemo_rfparser.oer5f obj_am273x/mssgenerated/ti_board_config.oer5f obj_am273x/mssgenerated/ti_board_open_close.oer5f obj_am273x/mssgenerated/ti_dpl_config.oer5f obj_am273x/mssgenerated/ti_drivers_config.oer5f obj_am273x/mssgenerated/ti_pinmux_config.oer5f obj_am273x/mssgenerated/ti_power_clock_config.oer5f obj_am273x/mssgenerated/ti_drivers_open_close.oer5f -lboard.am273x.r5f.ti-arm-clang.release.lib -lfreertos.am273x.r5f.ti-arm-clang.release.lib -ldrivers.am273x.r5f.ti-arm-clang.release.lib -llibc.a -llibtestlogger_am273x.aer5f -llibmmwavelink_am273x.aer5f -llibmmwave_am273x.aer5f -llibdpm_am273x.aer5f -llibmathutils.aer5f -llibcli_am273x.aer5f \ D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/platform/am273x/r5f_linker.cmd mss/mmw_mss_linker.cmd ****************************************************************************** Built the MSS for Millimeter Wave Demo ****************************************************************************** [C66 Device/Type: am273x/am273x] Building file: ./dss/dss_main.c C:/Users/try3701/AppData/Local/Temp/make28372-24.sh: 1: C:/Users/try3701/AppData/Local/Temp/make28372-24.sh: D:zjAWR2243ti-cgt-c6000_8.3.12/bin/cl6x: not found gmake[1]: *** [D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/common/mmwave_sdk.mak:274: obj_am273x/dss_main.oe66] Error 127 gmake[1]: Leaving directory 'D:/zj/AWR2243/mmwave_mcuplus_sdk_04_03_00_01/mmwave_mcuplus_sdk_04_03_00_01/ti/demo/am273x/mmw' gmake: *** [makefile:70: mmwDemoTDM] Error 2 D:\zj\AWR2243\mmwave_mcuplus_sdk_04_03_00_01\mmwave_mcuplus_sdk_04_03_00_01\ti\demo\am273x\mmw>
