I have just started to use the IWR1443BOOST. I am encountering a few issues while running the demo in the SDK(version 2.1).
I have tried to follow the steps listed in the mmWave SDK User Guide. Listed below are the steps i have completed.
- Set the SOP config to 101 and power cycle the board
- Upload the image xwr14xx_mmw_demo_mss.bin . Set the COM port to the UART data port
- On flashing these images, it gives a successfully completed message in the console.(The version of Uniflash is 8.2)
- Set the SOP config to 001 and power cycle the board
- Using the mmWave gallery (https://dev.ti.com/gallery/view/mmwave/mmWave_Demo_Visualizer/ver/2.1.0/).
- Press the "Send Config to Device" button in the Visualizer
- The Console Messages window as shown below
However,after Switching to the Plots tab, I can not see the plots.
What could be the mistake in the procedure that I am following?
请问您板子上的IWR1443 硅版本芯片是哪个版本的?是否SDK 2.1支持?请对照勘误表上的表面打印。
3 Device Markings
https://www.ti.com/lit/er/swrz074c/swrz074c.pdf
请参考下面的FAQ。
Q3. Not able to get the Plot with mmWave Demo Visualizer
https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/856038/faq-queries-related-to-mmwave-demo-visualizer
