Other Parts Discussed in Thread: DCA1000EVM
LOG信息如下:
GM: Constructor
GM: Fri Mar 31 17:28:50 2023
RSTD.Transmit("/Settings")
[17:28:51]
[17:28:51] ### Running Startup script: "C:\TI\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ###
[17:28:51] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[17:28:51] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[17:28:51] Scripter ignored: Attempt to UnBuild() again or before Build.
[17:28:51] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\TI\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[17:28:51] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[17:28:51] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[17:28:51] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[17:28:51] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[17:28:51] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[17:28:51] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\TI\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll")
[17:28:51] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[17:28:51] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[17:28:51] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[17:28:51] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[17:28:51] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[17:28:51] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[17:28:51] RSTD.Transmit("/")
[17:28:51] RSTD.SaveSettings(): Settings saved to "C:\Users\Administrator\AppData\Roaming\RSTD\config.xml"
[17:28:51] RSTD.Build()
[17:28:51] RSTD.AL_Build()
[17:28:51] RSTD.AL_LoadXml()
[17:28:51] RSTD.AL_Init()
[17:28:51] RSTD.Clients_Build()
[17:28:51] GM: Init
[17:28:51] GM: Loaded 'C:\TI\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll'
[17:28:51] GM: 1 Guest (s) init
[17:28:51] GM: 1 Module(s) init
[17:28:51] GM: 2 Tab (s) init
[17:28:51] RSTD.Client_LoadXml()
[17:28:51] [RadarAPI]: ar1.selectRadarMode(0)
[17:28:51] [RadarAPI]: Status: Passed
[17:28:51] Matlab Runtime Engine is installed
[17:28:51] [RadarAPI]: Starting Matlab Engine..
[17:29:12] [RadarAPI]: Matlab Engine Started!
[17:29:14] [RadarAPI]: ar1.selectCascadeMode(0)
[17:29:14] [RadarAPI]: Status: Passed
[17:29:14] [RadarAPI]: ar1.LoadSettings('C:\Users\Administrator\AppData\Roaming\RSTD\ar1gui.ini')
[17:29:14] TESTING = false
[17:29:14] RstdNet: Port 2777: Listening..
[17:29:14]
[17:29:14] ***Script completed successfully.***
[17:29:19] [RadarAPI]: Opening Gpio Control Port()
[17:29:19] Status: Failed to open/close GpioControl, Error Type: PROTOCOL ERROR
[17:29:19] [RadarAPI]: Opening Board Control Port()
[17:29:19] [RadarAPI]: Status: Failed to open/close BoardControl, Error value: -1
[17:29:20] [RadarAPI]: ar1.FullReset()
[17:29:20] [RadarAPI]: Status: Failed To give full reset, Error Value: -7
[17:29:21] [RadarAPI]: ar1.SOPControl(2)
[17:29:21] [RadarAPI]: Status: Passed
[17:29:22] [RadarAPI]: ar1.Connect(5,115200,1000)
[17:29:24] [RadarAPI]: Error: Connection failed: Calling_ConnectTarget returned 3
[17:29:24] [RadarAPI]: ar1.Calling_IsConnected()
[17:29:24] [RadarAPI]: ar1.SaveSettings('C:\Users\Administrator\AppData\Roaming\RSTD\ar1gui.ini')
[17:29:45] [RadarAPI]: Opening Gpio Control Port()
[17:29:45] Status: Failed to open/close GpioControl, Error Type: PROTOCOL ERROR
[17:29:46] [RadarAPI]: Opening Board Control Port()
[17:29:46] [RadarAPI]: Status: Failed to open/close BoardControl, Error value: -1
[17:29:47] [RadarAPI]: ar1.FullReset()
[17:29:47] [RadarAPI]: Status: Failed To give full reset, Error Value: -7
[17:29:47] [RadarAPI]: ar1.SOPControl(2)
[17:29:47] [RadarAPI]: Status: Passed
[17:29:49] [RadarAPI]: ar1.Connect(5,115200,1000)
[17:29:50] [RadarAPI]: ar1.Calling_IsConnected()
[17:29:51] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[17:29:51] [RadarAPI]: Status: Passed
[17:29:51] [RadarAPI]: ar1.deviceVariantSelection("XWR1843")
[17:29:51] [RadarAPI]: ar1.frequencyBandSelection("77G")
[17:29:51] [RadarAPI]: ar1.SelectChipVersion("XWR1843")
[17:29:51] Device Status : XWR1843/ASIL-B/SOP:2/ES:2
[17:29:51] [RadarAPI]: ar1.SaveSettings('C:\Users\Administrator\AppData\Roaming\RSTD\ar1gui.ini')
[17:29:53] [RadarAPI]: ar1.DownloadBSSFw("C:\\TI\\rollbackBackupDirectory\\C\\TI\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\radarss\\xwr18xx_radarss.bin")
[17:29:54] [RadarAPI]: Downloading BSS Patch RPRC Binary..
[17:30:01] [RadarAPI]: ar1.GetBSSFwVersion()
[17:30:01] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[17:30:02] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[17:30:02] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[17:30:03] [RadarAPI]: ar1.DownloadMSSFw("C:\\TI\\rollbackBackupDirectory\\C\\TI\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\masterss\\xwr18xx_masterss.bin")
[17:30:04] [RadarAPI]: Downloading MSS RPRC Binary..
[17:30:14] [RadarAPI]: ar1.GetMSSFwVersion()
[17:30:14] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[17:30:16] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[17:30:16] [RadarAPI]: Status: Passed
[17:30:16] MSS power up done async event received!
[17:30:35] [RadarAPI]: ar1.ReadRegister(0xffffe214, 0, 31)
[17:30:35] [RadarAPI]: ar1.ReadRegister(0xffffe210, 0, 31)
[17:30:36] [RadarAPI]: ar1.ReadRegister(0xffffe218, 0, 31)
[17:30:36] [RadarAPI]: ar1.DownloadBSSFw("C:\\TI\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\radarss\\xwr18xx_radarss.bin")
[17:30:40] [RadarAPI]: Downloading BSS Patch RPRC Binary..
[17:30:48] [RadarAPI]: ar1.GetBSSFwVersion()
[17:30:48] [RadarAPI]: BSSFwVersion:(00.00.00.00 (00/00/00))
[17:30:48] [RadarAPI]: Warning: BSS firmware version Mismatch!
[17:30:48] BSS FW Download Success
[17:30:48] [RadarAPI]: ar1.DownloadMSSFw("C:\\TI\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\masterss\\xwr18xx_masterss.bin")
[17:32:40] MSS FW Download failure
[17:32:40] [RadarAPI]: ar1.PowerOff()
[17:32:40] [RadarAPI]: Status: Passed
[17:32:40] Power On Success
[17:32:42] [RadarAPI]: Error: ReadRegister failed with error -2
[17:32:43] [RadarAPI]: Error: ReadRegister failed with error -2
[17:32:44] [RadarAPI]: Error: ReadRegister failed with error -2
[17:32:46] [RadarAPI]: Error: ReadRegister failed with error -2
