Part Number: TDA3XEVM
Other Parts Discussed in Thread: AWR1243,
把采集AWR1243的数据通过网口传输,这个cfg.mk文件该如何配置
[Cortex_M4_IPU1_C0] IPU1-0 Remote Log Shared Memory @ 0xa7ee00a0
IPU1-1 Remote Log Shared Memory @ 0xa7eee8a0
HOST Remote Log Shared Memory @ 0xa7ef10a0
DSP1 Remote Log Shared Memory @ 0xa7ef60a0
DSP2 Remote Log Shared Memory @ 0xa7ef88a0
EVE1 Remote Log Shared Memory @ 0xa7efb0a0
EVE2 Remote Log Shared Memory @ 0xa7efd8a0
EVE3 Remote Log Shared Memory @ 0xa7f000a0
EVE4 Remote Log Shared Memory @ 0xa7f028a0
IPU2 Remote Log Shared Memory @ 0xa7f050a0
SYSTEM: UART: INTERRUPT Mode is Selected
MAC Port 0 Address:
b4-bc-7c-ae-e5-64
MAC Port 1 Address:
b4-bc-7c-ae-e5-65
GMACSW has been started successfully
Registration of the GMACSW Successful
Network Added: If-1:192.168.1.200
MAC Port 0 Address:
b4-bc-7c-ae-e5-64
MAC Port 1 Address:
b4-bc-7c-ae-e5-65
[Cortex_M4_IPU1_C1]
[Cortex_M4_IPU1_C0] IPU1-1 Remote Log Shared Memory @ 0xa7eee8a0
[Cortex_M4_IPU1_C1] MAC Port 0 Address:
[Cortex_M4_IPU1_C0] HOST Remote Log Shared Memory @ 0xa7ef10a0
[Cortex_M4_IPU1_C1] b4-bc-7c-ae-e5-64
[Cortex_M4_IPU1_C0] DSP1 Remote Log Shared Memory @ 0xa7ef60a0
[Cortex_M4_IPU1_C1]
[Cortex_M4_IPU1_C0] DSP2 Remote Log Shared Memory @ 0xa7ef88a0
[Cortex_M4_IPU1_C1] MAC Port 1 Address:
[Cortex_M4_IPU1_C0] EVE1 Remote Log Shared Memory @ 0xa7efb0a0
[Cortex_M4_IPU1_C1] b4-bc-7c-ae-e5-65
[Cortex_M4_IPU1_C0] EVE2 Remote Log Shared Memory @ 0xa7efd8a0
[Cortex_M4_IPU1_C1] GMACSW has been started successfully
[Cortex_M4_IPU1_C0] EVE3 Remote Log Shared Memory @ 0xa7f000a0
[Cortex_M4_IPU1_C1] Registration of the GMACSW Successful
[Cortex_M4_IPU1_C0] EVE4 Remote Log Shared Memory @ 0xa7f028a0
[Cortex_M4_IPU1_C1] Network Added: If-1:192.168.1.200
[Cortex_M4_IPU1_C0] IPU2 Remote Log Shared Memory @ 0xa7f050a0
[Cortex_M4_IPU1_C1] Negotiated connection: FullDuplex 1000 Mbs
[Cortex_M4_IPU1_C1]
[Cortex_M4_IPU1_C1]
[Cortex_M4_IPU1_C1]
[Cortex_M4_IPU1_C1]
我已经试过将NDK_PROC_TO_USE=ipu1_1,上面是CCS Console输出的log,显示ip地址是192.168.1.200,但是无法ping通,而且程序一直在running,但是没有运行算法link,很明显是卡在某个地方
下面图片是每个核程序暂停的位置,程序一直在这里面循环
下面分别是NDK_config.cfg和cfg.mk,请看一下问题可能出在哪里
====================cfg.mk===================
# This file defines the modules included in $(MAKECONFIG) config
# Modules are split into,
# - Use-cases specified in uc_cfg.mk
# - Other system config/feature, specified in this file
# Any specific overrides are also specified in this file
# Example, for TDA3x SoC EVE2/3/4 are not present and hence force marked as <blank>, i.e disabled
# Additional config options
# CPUs to included in build
PROC_IPU1_0_INCLUDE=yes
PROC_IPU1_1_INCLUDE=yes
PROC_DSP1_INCLUDE=yes
PROC_DSP2_INCLUDE=no
PROC_EVE1_INCLUDE=yes
VSDK_BOARD_TYPE=TDA3XX_EVM
# Enable below macro when building in Radar SDK
RADAR_ONLY=yes
# Radar board type to be used
# To run on TDA3x EVM without TDA3XX_AR12_VIB_DAB_BOOSTER
# set RADAR_BOARD=none
RADAR_BOARD=TDA3XX_AR12_VIB_DAB_BOOSTER
# Supported values: ipu1_0 none
# when RADAR_BOARD is TDA3XX_AR12_VIB_DAB_BOOSTER, this MUST be none
ifeq ($(RADAR_BOARD),none)
FATFS_PROC_TO_USE=ipu1_0
endif
# Supported values: ipu1_0 ipu1_1 none
# NOTE, on TDA3x EVM NDK and FATFS cannot be enabled at the same time
#Used to control TFDTP stack (supported values: yes no)
NSP_TFDTP_INCLUDE=no
#Enable IPv6 Support
NDK_ENABLE_IPV6=no
# Supported values: DDR_MEM_512M DDR_MEM_128M
DDR_MEM=DDR_MEM_128M
WORKQ_INCLUDE=yes
# Used to control building of algorithm source.
# By default algorithm source not included in Vision SDK
BUILD_ALGORITHMS=no
# Applies profile to all cores
# Supported profiles: release debug
PROFILE=debug
PROFILE ?= release
PROFILE_ipu1_0 ?= $(PROFILE)
PROFILE_ipu1_1 ?= $(PROFILE)
PROFILE_c66xdsp_1 ?= $(PROFILE)
PROFILE_c66xdsp_2 ?= $(PROFILE)
PROFILE_arp32_1 ?= $(PROFILE)
DSS_INCLUDE=yes
CAL_INCLUDE=yes
ISS_INCLUDE=yes
ISS_ENABLE_DEBUG_TAPS=no
WDR_LDC_INCLUDE=yes
RTI_INCLUDE=no
# Use the Starterware IPC Library.
IPC_LIB_INCLUDE=yes
# EMIF ECC and Freedom from Interference (FFI) are clubbed together as they
# involve consolidated memory map changes
# ECC_FFI_INCLUDE=yes is not supported for DDR_MEM_128M
# If ECC_FFI_INCLUDE is set to no - memory map will match older versions.
# Firewall configuration and DSP XMC configuration is enabled/disabled using this
# flag
# Vision SDK does not enable EMIF ECC but expects SBL to enable it.
# Vision SDK sets up ECC error handlers irrespective of value of ECC_FFI_INCLUDE.
ECC_FFI_INCLUDE=no
# DCC is integrated in a way that requires ESM.
# Both modules are, therefore, clubbed together
# These are present only in TDA3XX
# Setting this to "no" only disables usage of these modules
# Source files are always enabled in build for TDA3XX
DCC_ESM_INCLUDE=no
# Enable below macro to enable DCAN integration into Vision SDK.
DCAN_INCLUDE=no
CPU_IDLE_ENABLED=yes
# Enable below macro to view the bandwidth used by different IPs in the device
# as a graphical plot on the display screen.
DATA_VIS_INCLUDE=no
HS_DEVICE=no
include $($(MAKEAPPNAME)_PATH)/configs/$(MAKECONFIG)/uc_cfg.mk
如果您有公司邮箱的话,建议您到e2e论坛上咨询,有专门的产品线工程师支持。
https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum
