IWR1642BOOST: 传感器论坛
Part Number: IWR1642BOOST
Other Parts Discussed in Thread: AWR1642
对于IWR1642BOOST:从工业工具箱运行演示代码时出现 MATLAB 错误 - 传感器论坛 - 传感器 - TI E2E 支持论坛该帖子中所出现的“If you have access to edit matlab, you can add a delay between the UART writes to give the device more time to process the trackingcfg command.”这句话,想询问一下如果我想在UART 写入之间添加延迟的话,应该在MATLAB中打开哪个文件进行添加?并且应该添加的代码如何编写才能实现延迟的功能?
