MMWCAS-RF-EVM: 运行cascade_radar_object_detect Usecase时,修改采样点参数出现的问题
Part Number: MMWCAS-RF-EVM
Other Parts Discussed in Thread: AWR2243
尊敬的TI工程师:
        我们目前在使用PROCESSOR_SDK_RADAR_03_08_00_00中的cascade_radar_object_detect示例,使用的是AWR2243 MMWCAS-RF-EVM和配套的MMWCAS-DSP-EVM,我们根据https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/882929/awr2243-the-appimage-form-sdk3-7-and-sdk3-8-can-not-running-in-cascade-radar-with-awr2243/3345600?tisearch=e2e-sitesearch&keymatch=The%20appimage%20form%20sdk3.7%20and%20sdk3.8#3345600讨论中提供的方法成功运行了该示例。
        我们目前遇到的问题是,修改采样点数后运行失败。
        我们使用了文档ProcessorSDKRadar_UserGuide中的方法指定雷达的参数,即将radar_test_vector文件夹复制到SD卡中。我们指定采样点数为256,采样频率为4000时,示例可以成功运行,但当我们将采样数指定为512,(为了获得固定的带宽,采样频率也相应地修改为8000)时,示例运行不成功。
串口不断发送  [DSP1 ] 58.909260 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed
以下是完整的日志信息:
TDA2xx SBL Boot
 DPLL Configuration Completed
 Clock Domain Configuration Completed
 Module Enable Configuration Completed
 TI EVM PAD Config Completed
 DDR Config Completed
 App Image Download Begins
 SD Boot - file open completed successfully
 IPU1 CPU0 Image Load Completed
 IPU1 CPU1 Image Load Completed
 DSP1 Image Load Completed
 EVE1 Image Load Completed
 EVE2 Image Load Completed
 EVE3 Image Load Completed
 EVE4 Image Load Completed
 App Image Download Completed
 Putting MPU CPU1 in Off mode
 EVE MMU configuration completed
 PMCCNTR counts once every 64 clock cycles, multiple by 64 to get actual CPU cycles
 SBL Initial Config Cycles - 100049  (8.53 ms)
 SOC Init Cycles - 170602  (14.55 ms)
 DDR Config Clock Cycles - 58443  (4.98 ms)
 App Image Load Cycles - 39797126  (3396.2 ms)
 Slave Core Bootup Cycles - 208524  (17.79 ms)
 SBL Boot-up Cycles - 40335801  (3441.98 ms)
 Time at which SBL started IPU1_0 - 121920  (3720.70 ms)
 Putting MPU in Retention...
[IPU1-0]      3.724089 s:  ***** IPU1_0 Firmware build time 13:37:53 Apr 13 2023
[IPU1-0]      3.724303 s:  *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU1-0]      3.726133 s:  SYSTEM: System Common Init in progress !!!
[IPU1-0]      3.736655 s:  SYSTEM: IPC init in progress !!!
[IPU1-0]      3.736747 s:  SYSTEM: IPCLIB init in progress !!!
[IPU1-0]      3.737143 s:  SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[IPU1-0]      3.737265 s:  SYSTEM: IPCLIB: register to [DSP1] event 15...
[IPU1-0]      3.737357 s:  SYSTEM: IPCLIB: register to [EVE1] event 15...
[IPU1-0]      3.737418 s:  SYSTEM: IPCLIB: register to [EVE2] event 15...
[IPU1-0]      3.737509 s:  SYSTEM: IPCLIB: register to [EVE3] event 15...
[IPU1-0]      3.737631 s:  SYSTEM: IPCLIB: register to [EVE4] event 15...
[IPU1-0]      3.737692 s:  SYSTEM: IPCLIB init DONE !!!
[IPU1-0]      3.737753 s:  SYSTEM: Notify init done !!!
[IPU1-0]      3.739583 s:  SYSTEM: MsgQ init done !!!
[IPU1-0]      3.740407 s:  SYSTEM: Work Queue init done !!!
[IPU1-0]      3.740498 s:  SYSTEM: IPC init DONE !!!
[IPU1-0]      3.744250 s:  SYSTEM: System Common Init Done !!!
[IPU1-0]      3.744342 s:  SYSTEM: System Init in progress !!!
[IPU1-0]      3.744403 s:  SYSTEM: BSP Common Init in progress !!!
[IPU1-0]      3.744494 s:  SYSTEM: BSP Common Init Done !!!
[IPU1-0]      3.744555 s:  SYSTEM: BSP Platform Init in progress !!!
[IPU1-0]      3.744677 s:  SYSTEM: BSP Platform Init Done !!!
[IPU1-0]      3.744738 s:  SYSTEM: FVID2 Init in progress !!!
[IPU1-0]      3.744891 s:  SYSTEM: FVID2 Init Done !!!
[IPU1-0]      3.744952 s:  SYSTEM: VPS Init in progress !!!
[IPU1-0]      3.745013 s:  SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0xa0000000 -> 0x80000000]
[IPU1-0]      3.748246 s: *** VPDMA Firmware Loading... ***
[IPU1-0]      3.748368 s: VPDMA Firmware Address = 0x9fc8a500
[IPU1-0]      3.748459 s: VPDMA Load Address     = 0x4897d004
[IPU1-0]      3.748551 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0]      3.748642 s: VPDMA List Busy Status = 0x00000000
[IPU1-0]      3.748734 s: *** VPDMA Firmware Load Success ***
[IPU1-0]      3.749069 s: *** VPDMA Firmware Loading... ***
[IPU1-0]      3.749191 s: VPDMA Firmware Address = 0x9fc8a500
[IPU1-0]      3.749283 s: VPDMA Load Address     = 0x4899d004
[IPU1-0]      3.749374 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0]      3.749466 s: VPDMA List Busy Status = 0x00000000
[IPU1-0]      3.749557 s: *** VPDMA Firmware Load Success ***
[IPU1-0]      3.749893 s: *** VPDMA Firmware Loading... ***
[IPU1-0]      3.749984 s: VPDMA Firmware Address = 0x9fc8a500
[IPU1-0]      3.750076 s: VPDMA Load Address     = 0x489bd004
[IPU1-0]      3.750198 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0]      3.750289 s: VPDMA List Busy Status = 0x00000000
[IPU1-0]      3.750381 s: *** VPDMA Firmware Load Success ***
[IPU1-0]      3.804764 s:  SYSTEM: VPS Init Done !!!
[IPU1-0]      3.805648 s:  UTILS: DMA: HWI Create for INT34 !!!
[IPU1-0]      3.805831 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU1-0]      3.805953 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261576 B (255 KB)
[IPU1-0]      3.806167 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[IPU1-0]      3.806350 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x8a783000, Total size = 355979264 B (339 MB), Free size = 355979264 B (339 MB)
[IPU1-0]      3.806502 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0x00000000, Total size = 0 B (0 MB), Free size = 0 B (0 MB)
[IPU1-0]      3.806655 s:  SYSTEM: Initializing Links !!!
[IPU1-0]      3.968309 s:  SYSTEM: Initializing Links ... DONE !!!
[IPU1-0]      4.058714 s:  BOARD: Board Init in progress !!!
[IPU1-0]      4.059263 s:  BOARD: Board Init Done !!!
[IPU1-0]      4.069328 s:  EEPROM Base Board Name: [DRA74CAS]
[IPU1-0]      4.069663 s:
[IPU1-0]      4.069694 s:  Vision SDK Version    : [REL_VISION_SDK_03_08_00_00]
[IPU1-0]      4.069755 s:  FVID2 Version         : [FVID_02_01_00_01]
[IPU1-0]      4.069816 s:  BSP Version           : [PDK_01_10_04__xx]
[IPU1-0]      4.069907 s:  Platform              : [EVM]
[IPU1-0]      4.069968 s:  SOC                   : [TDA2XX]
[IPU1-0]      4.070029 s:  SOC Revision          : [ES2.0]
[IPU1-0]      4.070090 s:  Board Detected        : [TDA2XX CASCADE RADAR]
[IPU1-0]      4.070182 s:  Base Board Revision   : [REV E]
[IPU1-0]      4.070243 s:  Daughter Card Revision: [REV A]
[IPU1-0]      4.070304 s:
[IPU1-1]      3.736015 s:  ***** IPU1_1 Firmware build time 13:36:11 Apr 13 2023
[IPU1-1]      3.736198 s:  *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU1-1]      3.739431 s:  UTILS: DMA: HWI Create for INT25 !!!
[IPU1-1]      3.768315 s:  SYSTEM: System Common Init in progress !!!
[IPU1-1]      3.768651 s:  SYSTEM: IPC init in progress !!!
[IPU1-1]      3.768773 s:  SYSTEM: IPCLIB init in progress !!!
[IPU1-1]      3.769169 s:  SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[IPU1-1]      3.769322 s:  SYSTEM: IPCLIB: register to [DSP1] event 15...
[IPU1-1]      3.769413 s:  SYSTEM: IPCLIB: register to [EVE1] event 15...
[IPU1-1]      3.769505 s:  SYSTEM: IPCLIB: register to [EVE2] event 15...
[IPU1-1]      3.769627 s:  SYSTEM: IPCLIB: register to [EVE3] event 15...
[IPU1-1]      3.769718 s:  SYSTEM: IPCLIB: register to [EVE4] event 15...
[IPU1-1]      3.769810 s:  SYSTEM: IPCLIB init DONE !!!
[IPU1-1]      3.769901 s:  SYSTEM: Notify init done !!!
[IPU1-1]      3.771731 s:  SYSTEM: MsgQ init done !!!
[IPU1-1]      3.772555 s:  SYSTEM: Work Queue init done !!!
[IPU1-1]      3.772646 s:  SYSTEM: IPC init DONE !!!
[IPU1-1]      3.776581 s:  SYSTEM: System Common Init Done !!!
[IPU1-1]      3.776672 s:  SYSTEM: System IPU1_1 Init in progress !!!
[IPU1-1]      3.776764 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU1-1]      3.776886 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 655360 B (640 KB), Free size = 637880 B (622 KB)
[IPU1-1]      3.777069 s:  SYSTEM: Initializing Links !!!
[IPU1-1]      3.881778 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
[IPU1-1]      3.884645 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
[IPU1-1]      3.887543 s:  UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
[IPU1-1]      3.890715 s:  UTILS: PRF: ##### Cannot allocate Object for TFDTPRX  ####
[IPU1-1]      3.894223 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
[IPU1-1]      3.897700 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
[IPU1-1]      3.901177 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
[IPU1-1]      3.904745 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
[IPU1-1]      3.908619 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
[IPU1-1]      3.912523 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
[IPU1-1]      3.916153 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
[IPU1-1]      3.919569 s:  UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
[IPU1-1]      3.919691 s:  SYSTEM: Initializing Links ... DONE !!!
[IPU1-1]      3.920789 s:  SYSTEM: System IPU1_1 Init Done !!!
[DSP1  ]      3.722015 s:  SYSTEM: System Common Init Done !!!
[DSP1  ]      3.722045 s:  SYSTEM: System DSP Init in progress !!!
[DSP1  ]      3.722198 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[DSP1  ]      3.722229 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP1  ]      3.722290 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 524128 B (511 KB)
[DSP1  ]      3.722320 s:  SYSTEM: Initializing Links !!!
[DSP1  ]      3.729701 s:  SYSTEM: Initializing Links ... DONE !!!
[DSP1  ]      3.729732 s:  SYSTEM: System DSP Init Done !!!
[DSP1  ]      3.978771 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[DSP1  ]      3.978801 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[EVE1  ]      3.734673 s:  ***** EVE Firmware build time 13:30:23 Apr 13 2023
[EVE1  ]      3.736350 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[EVE1  ]      3.738851 s:  SYSTEM: System Common Init in progress !!!
[EVE1  ]      3.739980 s:  SYSTEM: IPC init in progress !!!
[EVE1  ]      3.740834 s:  SYSTEM: IPCLIB init in progress !!!
[EVE1  ]      3.742390 s:  SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[EVE1  ]      3.743488 s:  SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[EVE1  ]      3.744647 s:  SYSTEM: IPCLIB: register to [DSP1] event 15...
[EVE1  ]      3.745806 s:  SYSTEM: IPCLIB: register to [EVE2] event 15...
[EVE1  ]      3.746934 s:  SYSTEM: IPCLIB: register to [EVE3] event 15...
[EVE1  ]      3.748063 s:  SYSTEM: IPCLIB: register to [EVE4] event 15...
[EVE1  ]      3.749222 s:  SYSTEM: IPCLIB init DONE !!!
[EVE1  ]      3.750106 s:  SYSTEM: Notify init done !!!
[EVE1  ]      3.751814 s:  SYSTEM: MsgQ init done !!!
[EVE1  ]      3.753095 s:  SYSTEM: Work Queue init done !!!
[EVE1  ]      3.754010 s:  SYSTEM: IPC init DONE !!!
[EVE1  ]      3.767736 s:  SYSTEM: System Common Init Done !!!
[EVE1  ]      3.768773 s:  SYSTEM: System EVE Init in progress !!!
[EVE1  ]      3.770145 s:  UTILS: DMA: HWI Create for INT8 !!!
[EVE1  ]      3.771243 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE1  ]      3.772463 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE1  ]      3.774751 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB)
[EVE1  ]      3.776886 s:  SYSTEM: Initializing Links !!!
[EVE1  ]      3.863813 s:  SYSTEM: Initializing Links ... DONE !!!
[EVE1  ]      3.864698 s:  SYSTEM: System EVE Init Done !!!
[EVE2  ]      3.737936 s:  ***** EVE Firmware build time 13:31:24 Apr 13 2023
[EVE2  ]      3.739705 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[EVE2  ]      3.742207 s:  SYSTEM: System Common Init in progress !!!
[EVE2  ]      3.743396 s:  SYSTEM: IPC init in progress !!!
[EVE2  ]      3.744372 s:  SYSTEM: IPCLIB init in progress !!!
[EVE2  ]      3.745897 s:  SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[EVE2  ]      3.747056 s:  SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[EVE2  ]      3.748185 s:  SYSTEM: IPCLIB: register to [DSP1] event 15...
[EVE2  ]      3.749374 s:  SYSTEM: IPCLIB: register to [EVE1] event 15...
[EVE2  ]      3.750533 s:  SYSTEM: IPCLIB: register to [EVE3] event 15...
[EVE2  ]      3.751723 s:  SYSTEM: IPCLIB: register to [EVE4] event 15...
[EVE2  ]      3.752851 s:  SYSTEM: IPCLIB init DONE !!!
[EVE2  ]      3.753766 s:  SYSTEM: Notify init done !!!
[EVE2  ]      3.755444 s:  SYSTEM: MsgQ init done !!!
[EVE2  ]      3.756755 s:  SYSTEM: Work Queue init done !!!
[EVE2  ]      3.757670 s:  SYSTEM: IPC init DONE !!!
[EVE2  ]      3.771487 s:  SYSTEM: System Common Init Done !!!
[EVE2  ]      3.772433 s:  SYSTEM: System EVE Init in progress !!!
[EVE2  ]      3.773805 s:  UTILS: DMA: HWI Create for INT8 !!!
[EVE2  ]      3.774934 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE2  ]      3.776154 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE2  ]      3.778472 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB)
[EVE2  ]      3.780729 s:  SYSTEM: Initializing Links !!!
[EVE2  ]      3.867290 s:  SYSTEM: Initializing Links ... DONE !!!
[EVE2  ]      3.868205 s:  SYSTEM: System EVE Init Done !!!
[EVE3  ]      3.741292 s:  ***** EVE Firmware build time 13:32:25 Apr 13 2023
[EVE3  ]      3.743000 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[EVE3  ]      3.745470 s:  SYSTEM: System Common Init in progress !!!
[EVE3  ]      3.746660 s:  SYSTEM: IPC init in progress !!!
[EVE3  ]      3.747575 s:  SYSTEM: IPCLIB init in progress !!!
[EVE3  ]      3.749130 s:  SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[EVE3  ]      3.750259 s:  SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[EVE3  ]      3.751448 s:  SYSTEM: IPCLIB: register to [DSP1] event 15...
[EVE3  ]      3.752607 s:  SYSTEM: IPCLIB: register to [EVE1] event 15...
[EVE3  ]      3.753736 s:  SYSTEM: IPCLIB: register to [EVE2] event 15...
[EVE3  ]      3.754864 s:  SYSTEM: IPCLIB: register to [EVE4] event 15...
[EVE3  ]      3.756023 s:  SYSTEM: IPCLIB init DONE !!!
[EVE3  ]      3.756938 s:  SYSTEM: Notify init done !!!
[EVE3  ]      3.758707 s:  SYSTEM: MsgQ init done !!!
[EVE3  ]      3.759989 s:  SYSTEM: Work Queue init done !!!
[EVE3  ]      3.760934 s:  SYSTEM: IPC init DONE !!!
[EVE3  ]      3.774507 s:  SYSTEM: System Common Init Done !!!
[EVE3  ]      3.775452 s:  SYSTEM: System EVE Init in progress !!!
[EVE3  ]      3.776855 s:  UTILS: DMA: HWI Create for INT8 !!!
[EVE3  ]      3.777984 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE3  ]      3.779326 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE3  ]      3.781644 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB)
[EVE3  ]      3.783779 s:  SYSTEM: Initializing Links !!!
[EVE3  ]      3.869456 s:  SYSTEM: Initializing Links ... DONE !!!
[EVE3  ]      3.870310 s:  SYSTEM: System EVE Init Done !!!
[EVE4  ]      3.744616 s:  ***** EVE Firmware build time 13:33:24 Apr 13 2023
[EVE4  ]      3.746263 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[EVE4  ]      3.748642 s:  SYSTEM: System Common Init in progress !!!
[EVE4  ]      3.749862 s:  SYSTEM: IPC init in progress !!!
[EVE4  ]      3.750777 s:  SYSTEM: IPCLIB init in progress !!!
[EVE4  ]      3.752363 s:  SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[EVE4  ]      3.753522 s:  SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[EVE4  ]      3.754651 s:  SYSTEM: IPCLIB: register to [DSP1] event 15...
[EVE4  ]      3.755840 s:  SYSTEM: IPCLIB: register to [EVE1] event 15...
[EVE4  ]      3.756969 s:  SYSTEM: IPCLIB: register to [EVE2] event 15...
[EVE4  ]      3.758097 s:  SYSTEM: IPCLIB: register to [EVE3] event 15...
[EVE4  ]      3.759318 s:  SYSTEM: IPCLIB init DONE !!!
[EVE4  ]      3.760202 s:  SYSTEM: Notify init done !!!
[EVE4  ]      3.761880 s:  SYSTEM: MsgQ init done !!!
[EVE4  ]      3.763161 s:  SYSTEM: Work Queue init done !!!
[EVE4  ]      3.764076 s:  SYSTEM: IPC init DONE !!!
[EVE4  ]      3.777648 s:  SYSTEM: System Common Init Done !!!
[EVE4  ]      3.778564 s:  SYSTEM: System EVE Init in progress !!!
[EVE4  ]      3.780058 s:  UTILS: DMA: HWI Create for INT8 !!!
[EVE4  ]      3.781156 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE4  ]      3.782407 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE4  ]      3.784694 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB)
[EVE4  ]      3.786799 s:  SYSTEM: Initializing Links !!!
[EVE4  ]      3.871988 s:  SYSTEM: Initializing Links ... DONE !!!
[EVE4  ]      3.872842 s:  SYSTEM: System EVE Init Done !!!
[IPU1-0]      5.073872 s:  QSPI Init Started
[IPU1-0]      5.074086 s:  MID - 20
[IPU1-0]      5.074147 s:  DID - 21
[IPU1-0]      5.074208 s:  QSPI Init Completed Sucessfully
[IPU1-0]      5.079424 s:
[IPU1-0]      5.079485 s:  Current System Settings,
[IPU1-0]      5.079546 s:  ========================
[IPU1-0]      5.079607 s:  Display Type   : HDMI 1920x1080 @ 60fps
[IPU1-0]      5.079668 s:  My IP address for interface 1 : 192.168.1.200
[IPU1-0]      5.079729 s:  My IP address for interface 2 : 0.0.0.0
[IPU1-0]      5.079790 s:
[IPU1-0]      5.079820 s:  ============
[IPU1-0]      5.079881 s:  Usecase Menu
[IPU1-0]      5.079912 s:  ============
[IPU1-0]      5.079973 s:
[IPU1-0]
[IPU1-0]  Vision SDK Usecases,
[IPU1-0]  --------------------
[IPU1-0]
[IPU1-0]  1: RADAR Usecases
[IPU1-0]  2: MISC Tests
[IPU1-0]
[IPU1-0]  s: System Settings
[IPU1-0]
[IPU1-0]  x: Exit
[IPU1-0]
[IPU1-0]  Enter Choice:
[IPU1-0]
[IPU1-1]      6.139449 s:  NSP GMAC: PHY 2 Found on MAC Port 0
[IPU1-1]      8.920270 s:  NETWORK_CTRL: Starting Server (port=5000) !!!
[IPU1-1]      8.920545 s:  NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
[IPU1-1]      9.139846 s:  NDK: Link Status: 1000Mb/s Full Duplex on PHY 2
[IPU1-0]     12.826602 s:
[IPU1-0]     12.826724 s:
[IPU1-0]
[IPU1-0]  RADAR Usecases
[IPU1-0]
[IPU1-0]  9: Cascade Radar (4 AWR1243) Capture + Null (TDA2xx Only)
[IPU1-0]  a: Cascade Radar (4 AWR1243) Capture + Radar Object Detect (DSP) + NetworkTx (TDA2xx Only)
[IPU1-0]  b: Cascade Radar (4 AWR1243) Capture + FFT (EVE) + Tx Beam Form Static Map (DSP)  + NetworkTx (TDA2xx Only)
[IPU1-0]
[IPU1-0]  x: Exit
[IPU1-0]
[IPU1-0]
[IPU1-0]     14.693863 s:
[IPU1-0]     14.693924 s:
[IPU1-0]
[IPU1-0]  ========================
[IPU1-0]  2D FFT Core Selection
[IPU1-0]
[IPU1-0]  1: DSP
[IPU1-0]
[IPU1-0]  2: EVE
[IPU1-0]
[IPU1-0]     15.104099 s: CHAINS_COMMON_CASCADE AR12xx Initializing FPGA ...
[IPU1-0]     16.703592 s: CHAINS_COMMON_CASCADE AR12xx Initializing FPGA Done...
[IPU1-0]     16.703806 s: Parsing radar_test_vector/sensor_master_config.txt
[IPU1-0]     16.734917 s: NUM_SENSORS = 4
[IPU1-0]     16.735069 s: FE_PARAMS = cascade_fe_master_params_MIMO.txt
[IPU1-0]     16.735130 s: FFT_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     16.735191 s: DSPALGO_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     16.735466 s: Parsing radar_test_vector/cascade_fe_master_params_MIMO.txt
[IPU1-0]     16.752485 s: SENSOR [0]:
[IPU1-0]     16.752577 s: Parsing Front End Config File: radar_test_vector/cascade/cascade_fe_params_mimo_master.txt
[IPU1-0]     16.765540 s: SENSOR [1]:
[IPU1-0]     16.765662 s: Parsing Front End Config File: radar_test_vector/cascade/cascade_fe_params_mimo_Map2.txt
[IPU1-0]     16.772036 s: SENSOR [2]:
[IPU1-0]     16.772158 s: Parsing Front End Config File: radar_test_vector/cascade/cascade_fe_params_mimo_Map4.txt
[IPU1-0]     16.778838 s: SENSOR [3]:
[IPU1-0]     16.778930 s: Parsing Front End Config File: radar_test_vector/cascade/cascade_fe_params_mimo_Map8.txt
[IPU1-0]     16.785762 s:  CHAINS: Init AR12xx ...
[IPU1-0]     16.786036 s:  UTILS_MCSPI: McSPI is configured in interrupt mode!!
[IPU1-0]     16.786433 s:  UTILS_MCSPI: McSPI is configured in interrupt mode!!
[IPU1-0]     16.786677 s:  UTILS_MCSPI: McSPI is configured in interrupt mode!!
[IPU1-0]     16.786860 s:  UTILS_MCSPI: McSPI is configured in interrupt mode!!
[IPU1-0]     17.015585 s:  AR12XX: Firmware Download Started : Ftype: BSS_BUILD
[IPU1-0]     17.037272 s:  AR12XX: Firmware Download Successful : Ftype: BSS_BUILD
[IPU1-0]     17.690569 s:  AR12XX: Firmware Download Started : Ftype: BSS_BUILD
[IPU1-0]     17.753339 s:  AR12XX: Firmware Download Successful : Ftype: BSS_BUILD
[IPU1-0]     17.789269 s:  AWR12XX: Version Master : 2.2.1.7
[IPU1-0]     17.789361 s:  AWR12XX: Version RF:2.2.0.13
[IPU1-0]     17.789452 s:  AWR12XX: Version mmWaveLink:1.2.0.0
[IPU1-0]     17.789605 s:  AWR12XX: Version Master Patch[dd.mm.yy]:29.7.20
[IPU1-0]     17.789727 s:  AWR12XX: Version RF Patch[dd.mm.yy]:6.7.22
[IPU1-0]     17.791374 s:  CHAINS: Config AR12xx ...
[IPU1-0]     17.791465 s:  CHAINS: Configuring the parameters for Normal Frame for Radar Number 1
[IPU1-0]     17.791587 s:  CHAINS: Configuring the parameters for Normal Frame for Radar Number 2
[IPU1-0]     17.791709 s:  CHAINS: Configuring the parameters for Normal Frame for Radar Number 3
[IPU1-0]     17.791801 s:  CHAINS: Configuring the parameters for Normal Frame for Radar Number 4
[IPU1-0]     17.888061 s:  AWR12XX: RF Boot Status = 0x73bfefb
[IPU1-0]     17.888153 s:  AWR12XX: RF Boot Time = 10916 us
[IPU1-0]     17.994418 s:  AWR12XX: RF Boot Status = 0x73bfefb
[IPU1-0]     17.994540 s:  AWR12XX: RF Boot Time = 10916 us
[IPU1-0]     18.102055 s:  AWR12XX: RF Boot Status = 0x73bfefb
[IPU1-0]     18.102147 s:  AWR12XX: RF Boot Time = 10916 us
[IPU1-0]     18.208320 s:  AWR12XX: RF Boot Status = 0x73bfefb
[IPU1-0]     18.208412 s:  AWR12XX: RF Boot Time = 10916 us
[IPU1-0]     18.219453 s:  CHAINS: Init AR12xx ... DONE !!!
[IPU1-0]     18.219697 s: Parsing radar_test_vector/sensor_master_config.txt
[IPU1-0]     18.234734 s: NUM_SENSORS = 4
[IPU1-0]     18.234795 s: FE_PARAMS = cascade_fe_master_params_MIMO.txt
[IPU1-0]     18.234886 s: FFT_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     18.234947 s: DSPALGO_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     18.235039 s: Parsing radar_test_vector/algo_master_params_cascade.txt
[IPU1-0]     18.241139 s: Parsing FFT Algorithm Params File: radar_test_vector/cascade/algo_configurations.txt
[IPU1-0]     18.540200 s: Parsing radar_test_vector/sensor_master_config.txt
[IPU1-0]     18.555114 s: NUM_SENSORS = 4
[IPU1-0]     18.555175 s: FE_PARAMS = cascade_fe_master_params_MIMO.txt
[IPU1-0]     18.555267 s: FFT_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     18.555328 s: DSPALGO_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     18.555419 s: Parsing radar_test_vector/algo_master_params_cascade.txt
[IPU1-0]     18.561245 s: Parsing radar_test_vector/sensor_master_config.txt
[IPU1-0]     18.574055 s: NUM_SENSORS = 4
[IPU1-0]     18.574117 s: FE_PARAMS = cascade_fe_master_params_MIMO.txt
[IPU1-0]     18.574178 s: FFT_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     18.574269 s: DSPALGO_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     18.574361 s: Parsing radar_test_vector/algo_master_params_cascade.txt
[IPU1-0]     18.580400 s: Parsing radar_test_vector/sensor_master_config.txt
[IPU1-0]     18.593027 s: NUM_SENSORS = 4
[IPU1-0]     18.593119 s: FE_PARAMS = cascade_fe_master_params_MIMO.txt
[IPU1-0]     18.593180 s: FFT_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     18.593271 s: DSPALGO_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     18.593363 s: Parsing radar_test_vector/algo_master_params_cascade.txt
[IPU1-0]     18.599676 s: Parsing radar_test_vector/sensor_master_config.txt
[IPU1-0]     18.612792 s: NUM_SENSORS = 4
[IPU1-0]     18.612883 s: FE_PARAMS = cascade_fe_master_params_MIMO.txt
[IPU1-0]     18.612944 s: FFT_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     18.613005 s: DSPALGO_PARAMS = algo_master_params_cascade.txt
[IPU1-0]     18.613097 s: Parsing radar_test_vector/algo_master_params_cascade.txt
[IPU1-0]     18.619227 s: Parsing Radar DSP Process Algorithm Params File: radar_test_vector/cascade/algo_configurations.txt
[IPU1-0]     18.925394 s: FILE_IO: Calibration file(calib_coef.bin) is present in sd card
[IPU1-0]     18.925547 s: Chains: NetworkTx Link
[IPU1-0]     18.925608 s:
[IPU1-0]
[IPU1-0]  Select Network Mode,
[IPU1-0]  1: TFDTP
[IPU1-0]  2: TCP/IP
[IPU1-0]
[IPU1-0]
[IPU1-0]     20.218721 s: Chains: Using TFDTP. Ensure using –-usetfdtp with network tools..
[IPU1-0]     20.218873 s:  CAPTURE: Create in progress !!!
[IPU1-0]     20.219087 s:  CAPTURE: VIP1 Slice0 PortA capture mode is [16-bit] !!!
[IPU1-0]     20.638900 s:  CAPTURE: VIP1 Slice1 PortA capture mode is [16-bit] !!!
[IPU1-0]     21.058744 s:  CAPTURE: VIP2 Slice0 PortA capture mode is [16-bit] !!!
[IPU1-0]     21.478527 s:  CAPTURE: VIP2 Slice1 PortA capture mode is [16-bit] !!!
[IPU1-0]     21.898432 s:  CAPTURE: Create Done !!!
[IPU1-0]     21.898889 s:  SELECT: OUT QUE0: OUT CH0: IN CH0: 4096 x 640, pitch = (8192, 0)
[IPU1-0]     21.899042 s:  SELECT: OUT QUE1: OUT CH0: IN CH1: 4096 x 640, pitch = (8192, 0)
[IPU1-0]     21.899194 s:  SELECT: OUT QUE2: OUT CH0: IN CH2: 4096 x 640, pitch = (8192, 0)
[IPU1-0]     21.899316 s:  SELECT: OUT QUE3: OUT CH0: IN CH3: 4096 x 640, pitch = (8192, 0)
[IPU1-0]     21.899499 s:  ALGORITHM: Create in progress (algId = 8) !!!
[IPU1-0]     22.070792 s:  ALG: ti.radar.fft: CH0 BUF0: 0x91f88c00 ( 5242880 B )
[IPU1-0]     22.144116 s:  ALG: ti.radar.fft: CH0 BUF1: 0x92488e00 ( 5242880 B )
[IPU1-0]     22.217318 s:  ALG: ti.radar.fft: CH0 BUF2: 0x92989000 ( 5242880 B )
[IPU1-0]     22.290764 s:  ALG: ti.radar.fft: CH0 BUF3: 0x92e89200 ( 5242880 B )
[IPU1-0]     22.291069 s:  ALGORITHM: Create Done (algId = 8) !!!
[IPU1-0]     22.291404 s:  ALGORITHM: Create in progress (algId = 8) !!!
[IPU1-0]     22.462239 s:  ALG: ti.radar.fft: CH0 BUF0: 0x9338f000 ( 5242880 B )
[IPU1-0]     22.535685 s:  ALG: ti.radar.fft: CH0 BUF1: 0x9388f200 ( 5242880 B )
[IPU1-0]     22.609009 s:  ALG: ti.radar.fft: CH0 BUF2: 0x93d8f400 ( 5242880 B )
[IPU1-0]     22.682242 s:  ALG: ti.radar.fft: CH0 BUF3: 0x9428f600 ( 5242880 B )
[IPU1-0]     22.682516 s:  ALGORITHM: Create Done (algId = 8) !!!
[IPU1-0]     22.682882 s:  ALGORITHM: Create in progress (algId = 8) !!!
[IPU1-0]     22.854602 s:  ALG: ti.radar.fft: CH0 BUF0: 0x94795400 ( 5242880 B )
[IPU1-0]     22.927255 s:  ALG: ti.radar.fft: CH0 BUF1: 0x94c95600 ( 5242880 B )
[IPU1-0]     23.000152 s:  ALG: ti.radar.fft: CH0 BUF2: 0x95195800 ( 5242880 B )
[IPU1-0]     23.072896 s:  ALG: ti.radar.fft: CH0 BUF3: 0x95695a00 ( 5242880 B )
[IPU1-0]     23.073171 s:  ALGORITHM: Create Done (algId = 8) !!!
[IPU1-0]     23.073506 s:  ALGORITHM: Create in progress (algId = 8) !!!
[IPU1-0]     23.244738 s:  ALG: ti.radar.fft: CH0 BUF0: 0x95b9b800 ( 5242880 B )
[IPU1-0]     23.317391 s:  ALG: ti.radar.fft: CH0 BUF1: 0x9609ba00 ( 5242880 B )
[IPU1-0]     23.390319 s:  ALG: ti.radar.fft: CH0 BUF2: 0x9659bc00 ( 5242880 B )
[IPU1-0]     23.463033 s:  ALG: ti.radar.fft: CH0 BUF3: 0x96a9be00 ( 5242880 B )
[IPU1-0]     23.463307 s:  ALGORITHM: Create Done (algId = 8) !!!
[IPU1-0]     23.464802 s:  IPC_OUT_0   : Create in progress !!!
[IPU1-0]     23.465107 s:  IPC_OUT_0   : Create Done !!!
[DSP1  ]     23.465259 s:  IPC_IN_0   : Create in progress !!!
[DSP1  ]     23.465686 s:  IPC_IN_0   : Create Done !!!
[DSP1  ]     23.465991 s:  ALGORITHM: Create in progress (algId = 11) !!!
[IPU1-0]     23.545019 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[IPU1-0]     23.545171 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 162616 B (158 KB)
[IPU1-0]     23.545324 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[IPU1-0]     23.545446 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x8a783000, Total size = 355979264 B (339 MB), Free size = 102060032 B (97 MB)
[IPU1-0]     23.545598 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0x00000000, Total size = 0 B (0 MB), Free size = 0 B (0 MB)
[IPU1-0]     23.569419 s:  CAPTURE: Start in progress !!!
[IPU1-0]     23.576831 s:  CAPTURE: Start Done !!!
[IPU1-0]     23.576953 s:  CHAINS: AR12xx Starting Radar Sensor ...
[IPU1-0]     23.580644 s:  CHAINS: AR12xx Starting Radar Sensor ... DONE !!!
[IPU1-0]     23.582413 s:
[IPU1-0]
[IPU1-0]  Chains Run-time Menu
[IPU1-0]
[IPU1-0]  0: Stop Chain
[IPU1-0]
[IPU1-0]  p: Print Performance Statistics
[IPU1-0]
[IPU1-0]  g: Control GUI output
[IPU1-0]
[IPU1-0]  c: Control Calibration
[IPU1-0]
[IPU1-0]  d: Control Peak Detection
[IPU1-0]
[IPU1-0]
[IPU1-1]     23.543128 s:  IPC_IN_0   : Create in progress !!!
[IPU1-1]     23.544043 s:  IPC_IN_0   : Create Done !!!
[IPU1-1]     23.544744 s:  NETWORK_TX: NETWORK_TX: Server listening (port=29172) !!!
[IPU1-1]     23.545934 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[IPU1-1]     23.546056 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 655360 B (640 KB), Free size = 637592 B (622 KB)
[DSP1  ]     23.539742 s:  ALG: ti.radar.dspcascademimo: CH0 BUF0: 0x997bc000 ( 675616 B )
[DSP1  ]     23.541115 s:  ALG: ti.radar.dspcascademimo: CH0 BUF1: 0x99861000 ( 675616 B )
[DSP1  ]     23.542457 s:  ALG: ti.radar.dspcascademimo: CH0 BUF2: 0x99906000 ( 675616 B )
[DSP1  ]     23.542518 s:  ALGORITHM: Create Done (algId = 11) !!!
[DSP1  ]     23.542884 s:  IPC_OUT_0   : Create in progress !!!
[DSP1  ]     23.542945 s:  IPC_OUT_0   : Create Done !!!
[DSP1  ]     23.546330 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[DSP1  ]     23.546361 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 136640 B (133 KB)
[DSP1  ]     23.546422 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 498816 B (487 KB)
[EVE1  ]     23.546727 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE1  ]     23.547886 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 18304 B (17 KB)
[EVE1  ]     23.549990 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261600 B (255 KB)
[EVE2  ]     23.552278 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE2  ]     23.553467 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 18304 B (17 KB)
[EVE2  ]     23.555511 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261600 B (255 KB)
[EVE3  ]     23.557829 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE3  ]     23.558988 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 18304 B (17 KB)
[EVE3  ]     23.561093 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261600 B (255 KB)
[EVE4  ]     23.563350 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE4  ]     23.564509 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 18304 B (17 KB)
[EVE4  ]     23.566522 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261600 B (255 KB)
[DSP1  ]     25.593942 s:  *** UTILS: CPU MHz = 20 Mhz ***
[DSP1  ]     57.229213 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.259195 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.289208 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.319221 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.349203 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.379216 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.409199 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.439211 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.469224 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.499206 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.529219 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.559202 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.589214 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.619227 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.649210 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.679222 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.709235 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.739217 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.769230 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.799213 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.829225 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.859238 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.889221 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.919233 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.949216 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     57.979228 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.009241 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.039224 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.069236 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.099219 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.129231 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.159244 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.189227 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.219239 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.249222 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.279235 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.309247 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.339230 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.369242 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.399225 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.429238 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.459250 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.489233 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.519246 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.549258 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.579241 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.609253 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.639236 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.669249 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.699261 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.729244 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.759256 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.789239 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.819252 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.849264 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.879247 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1  ]     58.909260 s:  UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
期待您的回复!
Liam Tian
