Other Parts Discussed in Thread: MATHLIB
你好,我在之前的帖子中提到关于exp2sp的实际结果与预期功能不符的问题,请问相关团队验证过了吗?
抱歉,因为帖子已经超过1个月,所以自动锁住了。我重新开了个帖,请关注下面帖子的回复。
https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/1266422/awr1642-is-it-a-bug-for-exp2sp-function
请看下面e2e工程师的回复。
As mentioned in the previous threads, the function has passed the test cases as per the report. Have you tried running the exp2sp test in the mathlib? If you don't see the error there, can you please try to see what the differences are in the customer's test when compared with the Mathlib test?
