Other Parts Discussed in Thread: AWR2243
换言之MMWCAS-cascade-EVM能否用外部信号进行控制,使其进行数据采集
你好,
能否尝试配置AWR2243 master为外触发,通过外部MCU提供frame sync控制AWR2243 master发波,从而控制ADC数据输出么?
Thanks,
Chris
你好,
更新一下,需要所有芯片都通过外部输入frame sync,射频配置需要配置为external trigger。没有相关的例子。
Thanks,
Chris
你好,当我按操作更换电阻并企图给TP_1一个外部触发信号,我发现一些问题,当我安装后GUI配置时其他和之前软件触发一样,但我将芯片1设置为硬件触发,当我triggerframe时报错如下
[18:58:37] Test Source Already Disabled...!!!
[18:58:37] [RadarAPI]: ar1.DisableTestSource_mult(8,0)
[18:58:37] [RadarAPI]: Status: Passed
[18:58:37] [RadarAPI]: ar1.FrameConfig_mult(8, 0, 2, 10, 128, 100, 0, 2)
[18:58:39] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(8, 0, 0, adc_data, 0)
[18:58:39] Device 0 - Configuring TDA with Width : 2048 and Height : 384
[18:58:39] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[18:58:39] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[18:58:39] Device 1 - Configuring TDA with Width : 2048 and Height : 384
[18:58:39] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[18:58:39] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[18:58:39] Device 2 - Configuring TDA with Width : 2048 and Height : 384
[18:58:39] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[18:58:39] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[18:58:39] Device 3 - Configuring TDA with Width : 2048 and Height : 384
[18:58:39] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[18:58:39] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[18:58:39] Sending Frame Periodicity of 100 to TDA..
[18:58:39] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[18:58:39] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[18:58:39] Sending Capture Directory with name /mnt/ssd/adc_data to TDA..
[18:58:39] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[18:58:39] Sending File Allocation of 0 files to TDA..
[18:58:39] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[18:58:39] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[18:58:39] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[18:58:39] Sending Number of frames to capture with value of 0 to TDA..
[18:58:39] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[18:58:39] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[18:58:39] [RadarAPI]: Status: Passed for notifying TDA about Start Frame
[18:58:40] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[18:58:49] [RadarAPI]: ar1.StartFrame_mult(8)
[18:58:49] [RadarAPI]: Status: Passed
[18:58:49] [DeviceId-3] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[18:58:50] [DeviceId-3] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[18:58:50] [DeviceId-3] Frame start async event received!
[18:58:50] [DeviceId-3] Frame End async event received!
[18:58:50] Status: Passed for notifying TDA about Stop Frame
[18:58:50] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
你好,当个尝试更改lua脚本进行外触发采集,似乎有效,但是当我变更numloops和interlooptime后,发现采集为空,studio输出界面如下
[16:42:08] ***Script completed successfully.***
[16:42:27] Loops Remaining : 5
[16:42:27] Starting TDA ARM...
[16:42:27] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, 5demo, 0)
[16:42:27] Device 0 - Configuring TDA with Width : 2048 and Height : 192
[16:42:27] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[16:42:27] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:27] Device 1 - Configuring TDA with Width : 2048 and Height : 192
[16:42:27] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[16:42:27] Device 2 - Configuring TDA with Width : 2048 and Height : 192
[16:42:27] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[16:42:27] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:27] Device 3 - Configuring TDA with Width : 2048 and Height : 192
[16:42:27] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:27] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[16:42:27] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:27] Sending Frame Periodicity of 100 to TDA..
[16:42:27] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[16:42:27] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:27] Sending Capture Directory with name /mnt/ssd/5demo to TDA..
[16:42:27] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[16:42:28] Sending File Allocation of 0 files to TDA..
[16:42:28] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[16:42:28] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:28] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[16:42:28] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[16:42:28] Sending Number of frames to capture with value of 0 to TDA..
[16:42:28] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[16:42:28] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[16:42:28] [RadarAPI]: Status: Passed for notifying TDA about Start Frame
[16:42:28] TDA ARM Successful
[16:42:29] Starting Frame Trigger sequence...
[16:42:29] [RadarAPI]: ar1.StartFrame_mult(8)
[16:42:29] [RadarAPI]: Status: Passed
[16:42:29] Device 4 : Start Frame Successful
[16:42:29] [RadarAPI]: ar1.StartFrame_mult(4)
[16:42:29] [DeviceId-3] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:29] Device 3 : Start Frame Successful
[16:42:29] [RadarAPI]: ar1.StartFrame_mult(2)
[16:42:29] [DeviceId-2] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:29] Device 2 : Start Frame Successful
[16:42:29] [RadarAPI]: ar1.StartFrame_mult(1)
[16:42:29] [DeviceId-1] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:29] [DeviceId-3] Frame start async event received!
[16:42:29] Device 1 : Start Frame Successful
[16:42:29] Capturing AWR device data to the TDA SSD...
[16:42:30] [DeviceId-2] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:30] [DeviceId-1] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:30] [DeviceId-0] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:30] [DeviceId-3] Frame End async event received!
[16:42:30] Status: Passed for notifying TDA about Stop Frame
[16:42:30] [DeviceId-2] Frame start async event received!
[16:42:30] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:30] [RadarAPI]: Frame Ended
[16:42:30] [DeviceId-1] Frame start async event received!
[16:42:30] [DeviceId-2] Frame End async event received!
[16:42:30] [DeviceId-1] Frame End async event received!
[16:42:30] [DeviceId-0] Frame start async event received!
[16:42:30] [DeviceId-0] Frame End async event received!
[16:42:35] Capture sequence completed...
[16:42:38] Loops Remaining : 4
[16:42:38] Starting TDA ARM...
[16:42:38] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, 5demo, 0)
[16:42:38] Device 0 - Configuring TDA with Width : 2048 and Height : 192
[16:42:38] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[16:42:38] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:38] Device 1 - Configuring TDA with Width : 2048 and Height : 192
[16:42:38] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[16:42:38] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:38] Device 2 - Configuring TDA with Width : 2048 and Height : 192
[16:42:38] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[16:42:38] Device 3 - Configuring TDA with Width : 2048 and Height : 192
[16:42:38] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[16:42:38] Sending Frame Periodicity of 100 to TDA..
[16:42:38] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[16:42:38] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:38] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:38] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:38] Sending Capture Directory with name /mnt/ssd/5demo to TDA..
[16:42:38] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[16:42:38] Sending File Allocation of 0 files to TDA..
[16:42:38] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[16:42:38] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[16:42:38] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[16:42:38] Sending Number of frames to capture with value of 0 to TDA..
[16:42:38] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[16:42:38] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[16:42:38] [RadarAPI]: Status: Passed for notifying TDA about Start Frame
[16:42:38] TDA ARM Successful
[16:42:39] Starting Frame Trigger sequence...
[16:42:39] [RadarAPI]: ar1.StartFrame_mult(8)
[16:42:39] [RadarAPI]: Status: Passed
[16:42:39] Device 4 : Start Frame Successful
[16:42:39] [RadarAPI]: ar1.StartFrame_mult(4)
[16:42:40] [DeviceId-3] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:40] [RadarAPI]: Status: Passed
[16:42:40] Device 3 : Start Frame Successful
[16:42:40] [RadarAPI]: ar1.StartFrame_mult(2)
[16:42:40] [DeviceId-2] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:40] Device 2 : Start Frame Successful
[16:42:40] [RadarAPI]: ar1.StartFrame_mult(1)
[16:42:40] [DeviceId-1] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:40] Device 1 : Start Frame Successful
[16:42:40] Capturing AWR device data to the TDA SSD...
[16:42:40] [DeviceId-3] Frame start async event received!
[16:42:40] [DeviceId-0] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:40] [DeviceId-3] Frame End async event received!
[16:42:40] Status: Passed for notifying TDA about Stop Frame
[16:42:40] [DeviceId-2] Frame start async event received!
[16:42:40] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:40] [RadarAPI]: Frame Ended
[16:42:40] [DeviceId-1] Frame start async event received!
[16:42:40] [DeviceId-0] Frame start async event received!
[16:42:40] [DeviceId-2] Frame End async event received!
[16:42:40] [DeviceId-1] Frame End async event received!
[16:42:40] [DeviceId-0] Frame End async event received!
[16:42:45] Capture sequence completed...
[16:42:48] Loops Remaining : 3
[16:42:48] Starting TDA ARM...
[16:42:48] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, 5demo, 0)
[16:42:48] Device 0 - Configuring TDA with Width : 2048 and Height : 192
[16:42:48] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[16:42:48] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:48] Device 1 - Configuring TDA with Width : 2048 and Height : 192
[16:42:48] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[16:42:48] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:48] Device 2 - Configuring TDA with Width : 2048 and Height : 192
[16:42:48] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[16:42:48] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:48] Device 3 - Configuring TDA with Width : 2048 and Height : 192
[16:42:48] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[16:42:48] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:48] Sending Frame Periodicity of 100 to TDA..
[16:42:48] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[16:42:48] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:48] Sending Capture Directory with name /mnt/ssd/5demo to TDA..
[16:42:48] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[16:42:48] Sending File Allocation of 0 files to TDA..
[16:42:48] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[16:42:48] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[16:42:48] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[16:42:48] Sending Number of frames to capture with value of 0 to TDA..
[16:42:48] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[16:42:48] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[16:42:49] [RadarAPI]: Status: Passed for notifying TDA about Start Frame
[16:42:49] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:49] TDA ARM Successful
[16:42:50] Starting Frame Trigger sequence...
[16:42:50] [RadarAPI]: ar1.StartFrame_mult(8)
[16:42:50] [RadarAPI]: Status: Passed
[16:42:50] Device 4 : Start Frame Successful
[16:42:50] [RadarAPI]: ar1.StartFrame_mult(4)
[16:42:50] [DeviceId-3] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:50] Device 3 : Start Frame Successful
[16:42:50] [RadarAPI]: ar1.StartFrame_mult(2)
[16:42:50] [DeviceId-2] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:50] Device 2 : Start Frame Successful
[16:42:50] [RadarAPI]: ar1.StartFrame_mult(1)
[16:42:50] [DeviceId-1] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:50] Device 1 : Start Frame Successful
[16:42:50] Capturing AWR device data to the TDA SSD...
[16:42:50] [DeviceId-3] Frame start async event received!
[16:42:50] [DeviceId-0] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:50] [DeviceId-3] Frame End async event received!
[16:42:50] Status: Passed for notifying TDA about Stop Frame
[16:42:50] [DeviceId-2] Frame start async event received!
[16:42:50] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:50] [RadarAPI]: Frame Ended
[16:42:51] [DeviceId-1] Frame start async event received!
[16:42:51] [DeviceId-0] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:42:51] [DeviceId-0] Frame start async event received!
[16:42:51] [DeviceId-2] Frame End async event received!
[16:42:51] [DeviceId-1] Frame End async event received!
[16:42:51] [DeviceId-0] Frame End async event received!
[16:42:55] Capture sequence completed...
[16:42:58] Loops Remaining : 2
[16:42:58] Starting TDA ARM...
[16:42:58] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, 5demo, 0)
[16:42:58] Device 0 - Configuring TDA with Width : 2048 and Height : 192
[16:42:58] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[16:42:58] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:58] Device 1 - Configuring TDA with Width : 2048 and Height : 192
[16:42:58] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[16:42:58] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:58] Device 2 - Configuring TDA with Width : 2048 and Height : 192
[16:42:58] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[16:42:58] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:58] Device 3 - Configuring TDA with Width : 2048 and Height : 192
[16:42:58] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[16:42:58] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:58] Sending Frame Periodicity of 100 to TDA..
[16:42:58] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[16:42:58] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:58] Sending Capture Directory with name /mnt/ssd/5demo to TDA..
[16:42:58] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[16:42:59] Sending File Allocation of 0 files to TDA..
[16:42:59] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[16:42:59] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:42:59] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[16:42:59] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[16:42:59] Sending Number of frames to capture with value of 0 to TDA..
[16:42:59] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[16:42:59] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[16:42:59] [RadarAPI]: Status: Passed for notifying TDA about Start Frame
[16:42:59] TDA ARM Successful
[16:43:00] Starting Frame Trigger sequence...
[16:43:00] [RadarAPI]: ar1.StartFrame_mult(8)
[16:43:00] [RadarAPI]: Status: Passed
[16:43:00] Device 4 : Start Frame Successful
[16:43:00] [RadarAPI]: ar1.StartFrame_mult(4)
[16:43:00] [DeviceId-3] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:43:00] Device 3 : Start Frame Successful
[16:43:00] [RadarAPI]: ar1.StartFrame_mult(2)
[16:43:01] [DeviceId-2] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:43:01] [RadarAPI]: Status: Passed
[16:43:01] Device 2 : Start Frame Successful
[16:43:01] [RadarAPI]: ar1.StartFrame_mult(1)
[16:43:01] [DeviceId-3] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:43:01] [DeviceId-1] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:43:01] Device 1 : Start Frame Successful
[16:43:01] Capturing AWR device data to the TDA SSD...
[16:43:01] [DeviceId-3] Frame start async event received!
[16:43:01] [DeviceId-0] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:43:01] [DeviceId-3] Frame End async event received!
[16:43:01] Status: Passed for notifying TDA about Stop Frame
[16:43:01] [DeviceId-2] Frame start async event received!
[16:43:01] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:43:01] [DeviceId-1] Frame start async event received!
[16:43:01] [RadarAPI]: Frame Ended
[16:43:01] [DeviceId-0] Frame start async event received!
[16:43:01] [DeviceId-2] Frame End async event received!
[16:43:01] [DeviceId-1] Frame End async event received!
[16:43:01] [DeviceId-0] Frame End async event received!
[16:43:06] Capture sequence completed...
[16:43:09] Loops Remaining : 1
[16:43:09] Starting TDA ARM...
[16:43:09] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, 5demo, 0)
[16:43:09] Device 0 - Configuring TDA with Width : 2048 and Height : 192
[16:43:09] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[16:43:09] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:43:09] Device 1 - Configuring TDA with Width : 2048 and Height : 192
[16:43:09] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[16:43:09] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:43:09] Device 2 - Configuring TDA with Width : 2048 and Height : 192
[16:43:09] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[16:43:09] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:43:09] Device 3 - Configuring TDA with Width : 2048 and Height : 192
[16:43:09] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[16:43:09] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:43:09] Sending Frame Periodicity of 100 to TDA..
[16:43:09] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[16:43:09] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:43:09] Sending Capture Directory with name /mnt/ssd/5demo to TDA..
[16:43:09] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[16:43:09] Sending File Allocation of 0 files to TDA..
[16:43:09] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[16:43:09] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[16:43:09] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[16:43:09] Sending Number of frames to capture with value of 0 to TDA..
[16:43:09] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[16:43:09] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[16:43:09] [RadarAPI]: Status: Passed for notifying TDA about Start Frame
[16:43:10] TDA ARM Successful
[16:43:11] Starting Frame Trigger sequence...
[16:43:11] [RadarAPI]: ar1.StartFrame_mult(8)
[16:43:11] [RadarAPI]: Status: Passed
[16:43:11] Device 4 : Start Frame Successful
[16:43:11] [RadarAPI]: ar1.StartFrame_mult(4)
[16:43:11] [DeviceId-3] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:43:11] Device 3 : Start Frame Successful
[16:43:11] [RadarAPI]: ar1.StartFrame_mult(2)
[16:43:11] [DeviceId-2] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:43:11] Device 2 : Start Frame Successful
[16:43:11] [RadarAPI]: ar1.StartFrame_mult(1)
[16:43:11] [DeviceId-1] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:43:11] Device 1 : Start Frame Successful
[16:43:11] Capturing AWR device data to the TDA SSD...
[16:43:11] [DeviceId-3] Frame start async event received!
[16:43:11] [DeviceId-0] MSS ESM Fault error status Async event recieved(0x400000, 0x0)
[16:43:11] [DeviceId-3] Frame End async event received!
[16:43:11] Status: Passed for notifying TDA about Stop Frame
[16:43:11] [DeviceId-2] Frame start async event received!
[16:43:11] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[16:43:11] [RadarAPI]: Frame Ended
[16:43:11] [DeviceId-1] Frame start async event received!
[16:43:11] [DeviceId-0] Frame start async event received!
[16:43:11] [DeviceId-2] Frame End async event received!
[16:43:11] [DeviceId-1] Frame End async event received!
[16:43:12] [DeviceId-0] Frame End async event received!
[16:43:16] Capture sequence completed...
[16:43:19] Starting Transfer files using WinSCP..
[16:43:20] The no of files captured in the directory is zero! Nothing to transfer!
[16:43:20] Transferring files FAILED!
Edberg,
如果你阅读Cascade_Capture.lua,num_loops >1就是会循环采集。
你如果要采集更多帧数据,可以修改Cascade_Configuration_MIMO.lua里的number of frame (framecfg)。
Thanks,
Chris
