Part Number: IWR6843ISK-ODS
Other Parts Discussed in Thread: IWR6843
你好!我在每次运行mmWave Studio 软件时,运行结束bin文件的数据并没有更新,请问是为什么呢?
GM: Constructor
GM: Wed Mar 20 15:42:52 2024
RSTD.Transmit("/Settings")
[15:42:53]
[15:42:53] ### Running Startup script: "C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ###
[15:42:53] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[15:42:53] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[15:42:53] Scripter ignored: Attempt to UnBuild() again or before Build.
[15:42:53] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[15:42:53] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[15:42:53] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[15:42:53] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[15:42:53] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[15:42:53] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[15:42:53] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll")
[15:42:53] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[15:42:53] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[15:42:53] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[15:42:53] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[15:42:53] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[15:42:53] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[15:42:53] RSTD.Transmit("/")
[15:42:53] RSTD.SaveSettings(): Settings saved to "C:\Users\sysu\AppData\Roaming\RSTD\config.xml"
[15:42:53] RSTD.Build()
[15:42:53] RSTD.AL_Build()
[15:42:53] RSTD.AL_LoadXml()
[15:42:53] RSTD.AL_Init()
[15:42:53] RSTD.Clients_Build()
[15:42:53] GM: Init
[15:42:53] GM: Loaded 'C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll'
[15:42:53] GM: 1 Guest (s) init
[15:42:53] GM: 1 Module(s) init
[15:42:53] GM: 2 Tab (s) init
[15:42:53] RSTD.Client_LoadXml()
[15:42:53] [RadarAPI]: ar1.selectRadarMode(0)
[15:42:53] [RadarAPI]: Status: Passed
[15:42:53] Matlab Runtime Engine is installed
[15:42:53] [RadarAPI]: Starting Matlab Engine..
[15:42:59] [RadarAPI]: Matlab Engine Started!
[15:43:01] [RadarAPI]: ar1.selectCascadeMode(0)
[15:43:01] [RadarAPI]: Status: Passed
[15:43:01] [RadarAPI]: ar1.LoadSettings('C:\Users\sysu\AppData\Roaming\RSTD\ar1gui.ini')
[15:43:02] TESTING = false
[15:43:02] RstdNet: Port 2777: Listening..
[15:43:02]
[15:43:02] ***Script completed successfully.***
[15:47:51] [RadarAPI]: Opening Gpio Control Port()
[15:47:51] [RadarAPI]: Status: Passed
[15:47:52] [RadarAPI]: Opening Board Control Port()
[15:47:52] [RadarAPI]: Status: Passed
[15:47:53] [RadarAPI]: ar1.FullReset()
[15:47:53] [RadarAPI]: Status: Passed
[15:47:54] [RadarAPI]: Closing Board Control Port()
[15:47:54] [RadarAPI]: Status: Passed
[15:47:54] [RadarAPI]: Closing Gpio Control Port()
[15:47:54] [RadarAPI]: ar1.SOPControl(2)
[15:47:56] [RadarAPI]: ar1.Connect(3,115200,1000)
[15:47:57] [RadarAPI]: ar1.Calling_IsConnected()
[15:47:59] [RadarAPI]: ar1.SelectChipVersion("IWR6843")
[15:47:59] [RadarAPI]: Status: Passed
[15:47:59] [RadarAPI]: ar1.frequencyBandSelection("60G")
[15:47:59] Device Status : IWR6843/QM/SOP:2/ES:2
[15:47:59] [RadarAPI]: ar1.SaveSettings('C:\Users\sysu\AppData\Roaming\RSTD\ar1gui.ini')
[15:48:02] [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\radarss\\xwr68xx_radarss.bin")
[15:48:02] [RadarAPI]: Downloading BSS ROM RPRC Binary..
[15:48:50] [RadarAPI]: ar1.GetBSSFwVersion()
[15:48:50] [RadarAPI]: BSSFwVersion:(06.02.01.05 (09/03/20))
[15:49:05] [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\masterss\\xwr68xx_masterss.bin")
[15:49:06] [RadarAPI]: Downloading MSS RPRC Binary..
[15:49:25] [RadarAPI]: ar1.GetMSSFwVersion()
[15:49:25] [RadarAPI]: MSSFwVersion:(02.00.00.03 (27/08/19))
[15:50:11] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[15:50:11] [RadarAPI]: Status: Passed
[15:50:11] MSS power up done async event received!
[15:50:14] [RadarAPI]: ar1.SelectChipVersion("IWR6843")
[15:50:14] [RadarAPI]: Status: Passed
[15:50:14] Device Status : IWR6843/QM/SOP:2/ES:2
[15:50:14] [RadarAPI]: ar1.RfEnable()
[15:50:14] BSS power up done async event received!
[15:50:15] [RadarAPI]: ar1.GetMSSFwVersion()
[15:50:15] [RadarAPI]: MSSFwVersion:(02.00.00.03 (27/08/19))
[15:50:15] [RadarAPI]: ar1.GetBSSFwVersion()
[15:50:15] [RadarAPI]: BSSFwVersion:(06.02.01.05 (09/03/20))
[15:50:29] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 1, 1, 1, 1, 1, 2, 1, 0)
[15:50:29] [RadarAPI]: Status: Passed
[15:50:31] [RadarAPI]: ar1.LPModConfig(0, 0)
[15:50:31] [RadarAPI]: Status: Passed
[15:50:32] [RadarAPI]: ar1.RfInit()
[15:50:33] [RadarAPI]: Status: Passed
[15:50:33] RF Init async event received!
[15:50:33] [RadarAPI]: Time stamp, Temperture: 18133,36; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[15:50:37] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[15:50:37] [RadarAPI]: Status: Passed
[15:50:39] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[15:50:39] [RadarAPI]: Status: Passed
[15:50:41] [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
[15:50:41] [RadarAPI]: Status: Passed
[15:50:58] [RadarAPI]: ar1.ProfileConfig(0, 60, 10, 6, 60, 0, 0, 0, 0, 0, 0, 50.006, 0, 256, 10000, 0, 131072, 30)
[15:50:58] [RadarAPI]: Status: Passed
[15:51:34] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 1, 1)
[15:51:34] [RadarAPI]: Status: Passed
[15:51:36] Test Source Already Disabled...!!!
[15:51:36] [RadarAPI]: ar1.DisableTestSource(0)
[15:51:37] [RadarAPI]: Status: Passed
[15:51:37] [RadarAPI]: ar1.FrameConfig(0, 0, 1000, 8, 5, 0, 0, 1)
[15:52:47] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[15:52:47] [RadarAPI]: Sending dll_version command to DCA1000
[15:52:48] [RadarAPI]:
[15:52:48] DLL Version : 1.0
[15:52:48] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[15:52:48] [RadarAPI]: Status: Passed
[15:52:49] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[15:52:49] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[15:52:49] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[15:52:50] [RadarAPI]: Sending fpga command to DCA1000
[15:52:50] FPGA Configuration command : Success
[15:52:50] [RadarAPI]: Sending record command to DCA1000
[15:52:50] Configure Record command : Success
[15:52:50] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[15:52:50] [RadarAPI]: Sending fpga_version command to DCA1000
[15:52:51] [RadarAPI]:
[15:52:51]
[15:52:51] FPGA Version : 2.8 [Record]
[15:52:51]
[15:53:08] [RadarAPI]: ar1.CaptureCardConfig_StartRecord("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\PostProc\\adc_data.bin", 1)
[15:53:08] [RadarAPI]: Sending start_record command to DCA1000
[15:53:10] [RadarAPI]: ar1.StartFrame()
[15:53:10] [RadarAPI]: Status: Passed
[15:53:10] Frame start async event received!
[15:53:15] [RadarAPI]: Frame Ended
[15:53:19] [RadarAPI]:
[15:53:19] Start Record :
[15:53:19] Timeout Error! System disconnected
[15:53:22] [RadarAPI]: ar1.StartMatlabPostProc("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[15:53:22] [RadarAPI]: No of files Captured: 1, Total no of frames for each device : 1000
[15:53:32] [RadarAPI]: ar1.StartMatlabPostProc("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[15:53:32] [RadarAPI]: No of files Captured: 1, Total no of frames for each device : 1000
[17:00:54] FPGA Version : 2.8 [Record]
[17:00:54]
[17:00:59] [RadarAPI]: ar1.CaptureCardConfig_StartRecord("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\PostProc\\adc_data.bin", 1)
[17:00:59] [RadarAPI]: Sending start_record command to DCA1000
[17:01:07] [RadarAPI]: ar1.StartFrame()
[17:01:07] [RadarAPI]: Status: Passed
[17:01:08] Frame start async event received!
[17:01:10] [RadarAPI]:
[17:01:10] Start Record :
[17:01:10] Timeout Error! System disconnected
[17:01:12] [RadarAPI]: Frame Ended
[17:01:12] Frame End async event received!
[17:01:16] [RadarAPI]: ar1.StartMatlabPostProc("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\PostProc\\adc_data.bin")
[17:01:16] [RadarAPI]: No of files Captured: 0, Total no of frames for each device : 1000
[17:01:16] Error : The number of files captured is zero!
请看下面的handbook,关于这个错误信息引起的原因。
SW2.5 on DCA1000 set to hardware mode instead of software mode
https://dev.ti.com/tirex/explore/node?node=A__ALXBNwzujD9wALoMbM4BAQ__radar_toolbox__1AslXXD__LATEST
