我使用的是object_data_over_can例程,SDK版本为02_01_00_04,在烧写模式下烧录ccsdebug.bin文件后,切换为调试模式后进行加载,编译操作,在编译完ARM核和DSP核后,控制台报错:
C674X_0: Power Failure on Target CPU
C674X_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
是什么原因?在此之前我可以调试nonos例程,不会报错
