Other Parts Discussed in Thread: IWR1843
I have configured the BPM transmission mode of the IWR1843 according to the steps in https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/925558/awr1443boost-bpm-configuration, and I found that the output bin file size is still 50MB. I do not understand this. About more details, based on my understanding, for the IWR1843 with TX0 and TX2 enabled, under the same number of ADCs and Chirps, the bin file size obtained with TDM transmission mode should be twice the size of the bin file obtained with BPM transmission mode.
I have set the number of ADCs to 256, the number of Chirps per frame to 128, and 50 frames. According to this configuration, the file size obtained with TDM should be 50*8*256*128*16*2/8/1024/1024=50MB. The file size obtained with BPM should be 50*4*256*128*16*2/8/1024/1024=25MB. However, I do not understand why the file size obtained with BPM is also 50MB.
