AWR2243: 2243
Part Number: AWR2243
哪些批次编号可以级联使用
  • 你好,
    请问你购买的AWR2243是近期从Arrow或者是TI estore购买的么?如果是,是支持级联的。
    Thanks,
    Chris
  • 我在之前的调试中发现可能由于自己购买了不支持级联的AWR2243芯片,因此无法实现四芯片级联调试。我近期购买了一批新的AWR2243芯片用于级联调试,产品批号为26ZDYF9。根据我在论坛上查阅到的资料,这批芯片产于22年6月。然而令人失望的是,我依然无法使用mmWaveStudio进行四芯片级联调试。
    请告知我可以用于四芯片级联调试的AWR2243产品批号有哪些,谢谢!
    In my previous debugging, I found that I may not be able to achieve quad-chip cascade debugging due to my purchase of AWR2243 chips that do not support cascade. I recently purchased a new batch of AWR2243 chips for cascade debugging, batch number 26ZDYF9. According to the information I read on the forum, this batch of chips was produced in June 22. However, it is disappointing that I still cannot use mmWaveStudio for quad-chip cascade debugging.
    Please let me know what AWR2243 product batch numbers can be used for four-chip cascade debugging, thank you!
  • 你好,
    请问你的芯片是在TI官网或者是在Arrow近期购买的吗?
    Thanks,
    Chris
