AWR1843BOOST: 系统出错
Part Number: AWR1843BOOST
Other Parts Discussed in Thread: AWR1843, DCA1000EVM
在mmWave Studio上配置好之后,按下DCA1000 ARM后,继续按Trigger Frame,这时发生AWR1843板上INERR红灯常亮,DCA1000板上FPGA_ERR变红,mmWave Studio系统卡住。等待一分钟左右后(见studio output中17:27:34--17:28:53),DCA1000板的FGPA_ERR红灯熄灭,AWR1843板上INERR红灯依然常亮,mmWave studio的output输出如下:
[17:27:32]  [RadarAPI]: Sending start_record command to DCA1000
[17:27:34]  [RadarAPI]: ar1.StartFrame()
[17:27:34]  [RadarAPI]: Status: Passed
[17:27:34]  Frame start async event received!
[17:27:34]  Frame End async event received!
[17:27:34]  [RadarAPI]: Frame Ended
[17:28:53]  [RadarAPI]:
[17:28:53]  Start Record command : Success
[17:28:53]
[17:28:53]  LVDS buffer full
[17:28:53]
[17:28:53]  Record Process :
[17:28:53]  Timeout Error! System disconnected
[17:28:53]
[17:28:53]  Record stop is done successfully
