Other Parts Discussed in Thread: TDC7201, MSP430F5529,
代码文件名为tdc720x_calculation.c
#include <stdint.h>
#include <string.h>
#include <stdio.h>
#include "TI_TDC720x.h"
#include "TI_MSP430.h"
#include "TI_MSP430_hardware_board.h"
#include "TI_MSP430_spi.h"
#include "timer_queue.h"
#include "tdc720x_calculation.h"
#include "uart_commn.h"
extern uint8_t TDC720x_reg_local_copy[];
// default onboard clk in ns
float tdc_clk_period = 125.0;
float start2stop[MAX_STOPS];
uint8_t outString[128];
int32_t meas_result_regrs[MEAS_RESULT_REG_NUM];
float norm_lsb;
float ccnt;
float mreg[13];
float Time1,Time2,Time3,Time4,Time5,Time6;
float Clk_count1,Clk_count2,Clk_count3,Clk_count4,Clk_count5;
float Calibration1,Calibration2;
float st2sp[5];
float nlsb;
void TDC720x_calc(uint8_t *buf, uint8_t dev)
TDC720x_build_mreg(buf);
TDC720x_start2stopn(dev);
print_start2stopn();
void print_start2stopn(void)
uint8_t i;
#if 0
float tmp;
for(i=0; i < MEAS_RESULT_REG_NUM; i++)
tmp = (float) meas_result_regrs[i];
sprintf((char *)outString, "mreg[%d]: %4.6f ", i, tmp);
putsUART((unsigned char *)outString,strlen((char *)outString));
if (((i+1) % 3) == 0)
sprintf((char *)outString, " \r\n");
sprintf((char *)outString, "norm_lsb: %4.6f ", norm_lsb);
sprintf((char *)outString, "cal_count: %4.6f \r\n", ccnt);
#endif
for (i=0;i<MAX_STOPS;i++)
sprintf((char *)outString, "Start_to_Stop[%d]: %4.6f ", i+1, start2stop[i]);
//计算飞行时间
void TDC720x_start2stopn(uint8_t dev)
uint8_t n;
TDC720x_normlsb(dev);
mreg[0] = Time1; mreg[1] = Clk_count1; mreg[2] = Time2;
mreg[3] = Clk_count2; mreg[4] = Time3; mreg[5] = Clk_count3;
mreg[6] = Time4; mreg[7] = Clk_count4; mreg[8] = Time5;
mreg[9] = Clk_count5; mreg[10] = Time6; mreg[11] = Calibration1;
mreg[12] = Calibration2;
st2sp[0] = nlsb * (Time1 - Time2) + tdc_clk_period * Clk_count1;
st2sp[1] = nlsb * (Time1 - Time3) + tdc_clk_period * Clk_count2;
st2sp[2] = nlsb * (Time1 - Time4) + tdc_clk_period * Clk_count3;
st2sp[3] = nlsb * (Time1 - Time5) + tdc_clk_period * Clk_count4;
st2sp[4] = nlsb * (Time1 - Time6) + tdc_clk_period * Clk_count5;
// 最多5个stop
for(n=0; n < MAX_STOPS; n++)
start2stop[n] = norm_lsb * (meas_result_regrs[0] - meas_result_regrs[2*(n+1)]) +
tdc_clk_period * meas_result_regrs[2*(n+1)-1];
//校准得到的归一化LSB值
void TDC720x_normlsb(uint8_t dev)
uint8_t tdcbyte, cal2cy;
// read config2 register - use local saved data
tdcbyte = (TI_TDC720x_SPIByteReadReg(TI_TDC720x_CONFIG2_REG, dev) & CAL2MASK)>>CAL2SHFT;
switch (tdcbyte)
case 0:
cal2cy = 2;
break;
case 1:
cal2cy = 10;
break;
case 2:
cal2cy = 20;
break;
case 3:
cal2cy = 40;
default:
cal2cy = 10;
ccnt = (float) (meas_result_regrs[12]-meas_result_regrs[11])/(cal2cy-1);
norm_lsb = tdc_clk_period / ccnt;
void TDC720x_build_mreg(uint8_t *buf)
uint8_t i;
meas_result_regrs[i] = (((uint32_t) buf[3*i]) << 16) +
(((uint32_t) buf[(3*i)+1]) << 8) +
(((uint32_t) buf[(3*i)+2]));
