Part Number: MMWCAS-DSP-EVM
[12:05:39] Not able to connect with the TDA board. Please check whether the Capture Card is connected to the network!
[12:05:39] ConnectTDA Failed
[12:05:39]
[12:05:39] ***Script completed successfully.***
[12:05:45] Setting up Studio for Cascade started..
[12:05:45] [RadarAPI]: ar1.SelectCaptureDevice("TDA2XX")
[12:05:45] [RadarAPI]: Status: Passed
[12:05:45] [RadarAPI]: TDAStatusCallback Event Registered
[12:05:45] [RadarAPI]: registerTDAStatusCallback Status: Passed
[12:05:45] [RadarAPI]: ar1.ConnectTDA("192.168.33.180", 5001, 15)
[12:05:45] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[12:05:45] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_VERSION_INFO Async event recieved() with status 0. TDA Version : REL_VISION_SDK_03_07_01_00 Aug 5 2019 15:04:45[12:05:45] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[12:05:47] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[12:05:47] [RadarAPI]: ConnectTDACaptureCard Status: Passed
[12:05:47] TDA Capture Card Status : CONNECTED!
[12:05:47] ConnectTDA Successful
[12:05:47] selectCascadeMode Successful
[12:05:47] Setting up Studio for Cascade ended..
[12:05:48] [RadarAPI]: ar1.FullReset(1)
[12:05:48] [RadarAPI]: Status: Passed
[12:05:48] [RadarAPI]: ar1.SOPControl_mult(1,4)
[12:05:48] Master : SOP Reset Successful
[12:05:48] [DeviceId-0] MSS power up done async event received!
[12:05:48] [RadarAPI]: ar1.PowerOn_mult(1, 0, 1000, 0,0)
[12:05:48] Master : SPI Connection Successful
[12:05:48] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(1, C:\\ti\\mmwave_dfp_02_02_04_00\\firmware\\xwr22xx_metaImage.bin)
[12:05:48] Master : FW Download Successful
[12:05:48] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[12:05:48] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[12:05:48] Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[12:05:48] [RadarAPI]: ar1.RfEnable_mult(1)
[12:05:48] [DeviceId-0] BSS power up done async event received!
[12:05:49] Master : RF Power Up Successful
[12:05:49] [RadarAPI]: ar1.ChanNAdcConfig_mult(1, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 1)
[12:05:49] [RadarAPI]: Status: Passed
[12:05:49] Master : Channel & ADC Configuration Successful
[12:05:49] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[12:05:50] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[12:05:50] [RadarAPI]: ar1.FullReset(2)
[12:05:50] [RadarAPI]: Status: Passed
[12:05:50] [RadarAPI]: ar1.SOPControl_mult(2,4)
[12:05:50] Device 2 : SOP Reset Successful
[12:05:50] [DeviceId-1] MSS power up done async event received!
[12:05:50] [RadarAPI]: ar1.AddDevice(2)
[12:05:50] Device 2 : SPI Connection Successful
[12:05:50] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[12:05:51] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[12:05:51] [RadarAPI]: ar1.FullReset(4)
[12:05:51] [RadarAPI]: Status: Passed
[12:05:51] [RadarAPI]: ar1.SOPControl_mult(4,4)
[12:05:51] Device 3 : SOP Reset Successful
[12:05:51] [DeviceId-2] MSS power up done async event received!
[12:05:51] [RadarAPI]: ar1.AddDevice(4)
[12:05:51] Device 3 : SPI Connection Successful
[12:05:51] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[12:05:52] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[12:05:52] [RadarAPI]: ar1.FullReset(8)
[12:05:52] [RadarAPI]: Status: Passed
[12:05:52] [RadarAPI]: ar1.SOPControl_mult(8,4)
[12:05:52] Device 4 : SOP Reset Successful
[12:05:52] [DeviceId-3] MSS power up done async event received!
[12:05:52] [RadarAPI]: ar1.AddDevice(8)
[12:05:52] Device 4 : SPI Connection Successful
[12:05:52] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(14, C:\\ti\\mmwave_dfp_02_02_04_00\\firmware\\xwr22xx_metaImage.bin)
[12:05:53] Slaves : FW Download Successful
[12:05:53] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[12:05:53] [RadarAPI]: Status: Passed
[12:05:53] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[12:05:53] Slave1 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[12:05:53] Slave2 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[12:05:53] Slave3 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[12:05:53] [RadarAPI]: ar1.RfEnable_mult(14)
[12:05:53] [DeviceId-2] BSS power up done async event received!
[12:05:53] [DeviceId-3] BSS power up done async event received!
[12:05:53] [DeviceId-1] BSS power up done async event received!
[12:05:56] Slaves : RF Power Up Successful
[12:05:56] [RadarAPI]: ar1.ChanNAdcConfig_mult(14, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 2)
[12:05:56] [RadarAPI]: Status: Passed
[12:05:56] Slaves : Channel & ADC Configuration Successful
[12:05:56] [RadarAPI]: ar1.RfLdoBypassConfig_mult(15, 0xF)
[12:05:56] LDO Bypass Successful
[12:05:56] [RadarAPI]: ar1.LPModConfig_mult(15, 0,0)
[12:05:56] Low Power Mode Configuration Successful
[12:05:56] [RadarAPI]: ar1.SetMiscConfig_mult(15, 1, 0, 0, 0)
[12:05:56] Misc Control Configuration Successful
[12:05:56] [RadarAPI]: ar1.RfInitCalibConfig_mult(15, 1, 1, 1, 1, 1, 1, 1, 65537)
[12:05:56] RF Init Calibration Successful
[12:05:56] [RadarAPI]: ar1.RfInit_mult(15)
[12:05:56] [DeviceId-2] RF Init async event received!
[12:05:56] [DeviceId-0] RF Init async event received!
[12:05:56] [DeviceId-3] RF Init async event received!
[12:05:56] [DeviceId-1] RF Init async event received!
[12:05:56] [RadarAPI]: Time stamp, Temperture: 3047,34; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[12:05:57] [RadarAPI]: Status: Passed
[12:05:57] RF Init Successful
[12:05:57] [RadarAPI]: ar1.DataPathConfig_mult(15, 0, 1, 0)
[12:05:57] Data Path Configuration Successful
[12:05:57] [RadarAPI]: ar1.LvdsClkConfig_mult(15, 1,1)
[12:05:57] Clock Configuration Successful
[12:05:57] [RadarAPI]: ar1.CSI2LaneConfig_mult(15, 1, 0, 2, 0, 4, 0, 5,0,3,0, 0)
[12:05:57] CSI2 Configuration Successful
[12:05:57] [RadarAPI]: ar1.ProfileConfig_mult(15, 0, 77, 5, 6, 40, 0, 0, 0, 0, 0, 0, 78.986, 0, 256, 8000, 0, 0, 48)
[12:05:57] Profile Configuration successful
[12:05:57] [RadarAPI]: ar1.ChirpConfig_mult(1, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:57] Device 1 : Chirp 0 Configuration successful
[12:05:57] [RadarAPI]: ar1.ChirpConfig_mult(1, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:57] Device 1 : Chirp 1 Configuration successful
[12:05:57] [RadarAPI]: ar1.ChirpConfig_mult(1, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:57] Device 1 : Chirp 2 Configuration successful
[12:05:57] [RadarAPI]: ar1.ChirpConfig_mult(1, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:57] Device 1 : Chirp 3 Configuration successful
[12:05:57] [RadarAPI]: ar1.ChirpConfig_mult(1, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:57] Device 1 : Chirp 4 Configuration successful
[12:05:57] [RadarAPI]: ar1.ChirpConfig_mult(1, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:57] Device 1 : Chirp 5 Configuration successful
[12:05:57] [RadarAPI]: ar1.ChirpConfig_mult(1, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:58] Device 1 : Chirp 6 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(1, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:58] [RadarAPI]: Status: Passed
[12:05:58] Device 1 : Chirp 7 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(1, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:58] Device 1 : Chirp 8 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(1, 9, 9, 0, 0, 0, 0, 0, 0, 0,1)
[12:05:58] Device 1 : Chirp 9 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(1, 10, 10, 0, 0, 0, 0, 0, 0, 1,0)
[12:05:58] Device 1 : Chirp 10 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(1, 11, 11, 0, 0, 0, 0, 0, 1, 0,0)
[12:05:58] Device 1 : Chirp 11 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(2, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:58] Device 2 : Chirp 0 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(2, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:58] Device 2 : Chirp 1 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(2, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:58] Device 2 : Chirp 2 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(2, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:58] Device 2 : Chirp 3 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(2, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:58] Device 2 : Chirp 4 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(2, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:58] Device 2 : Chirp 5 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(2, 6, 6, 0, 0, 0, 0, 0, 0, 0,1)
[12:05:58] Device 2 : Chirp 6 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(2, 7, 7, 0, 0, 0, 0, 0, 0, 1,0)
[12:05:58] Device 2 : Chirp 7 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(2, 8, 8, 0, 0, 0, 0, 0, 1, 0,0)
[12:05:58] Device 2 : Chirp 8 Configuration successful
[12:05:58] [RadarAPI]: ar1.ChirpConfig_mult(2, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:58] Device 2 : Chirp 9 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(2, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] [RadarAPI]: Status: Passed
[12:05:59] Device 2 : Chirp 10 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(2, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] Device 2 : Chirp 11 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] Device 3 : Chirp 0 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] Device 3 : Chirp 1 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] Device 3 : Chirp 2 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 3, 3, 0, 0, 0, 0, 0, 0, 0,1)
[12:05:59] Device 3 : Chirp 3 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 4, 4, 0, 0, 0, 0, 0, 0, 1,0)
[12:05:59] Device 3 : Chirp 4 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 5, 5, 0, 0, 0, 0, 0, 1, 0,0)
[12:05:59] Device 3 : Chirp 5 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] Device 3 : Chirp 6 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] Device 3 : Chirp 7 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] Device 3 : Chirp 8 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] Device 3 : Chirp 9 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] Device 3 : Chirp 10 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(4, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[12:05:59] Device 3 : Chirp 11 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(8, 0, 0, 0, 0, 0, 0, 0, 0, 0,1)
[12:05:59] Device 4 : Chirp 0 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(8, 1, 1, 0, 0, 0, 0, 0, 0, 1,0)
[12:05:59] Device 4 : Chirp 1 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(8, 2, 2, 0, 0, 0, 0, 0, 1, 0,0)
[12:05:59] Device 4 : Chirp 2 Configuration successful
[12:05:59] [RadarAPI]: ar1.ChirpConfig_mult(8, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[12:06:00] [RadarAPI]: Status: Passed
[12:06:00] Device 4 : Chirp 3 Configuration successful
[12:06:00] [RadarAPI]: ar1.ChirpConfig_mult(8, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[12:06:00] Device 4 : Chirp 4 Configuration successful
[12:06:00] [RadarAPI]: ar1.ChirpConfig_mult(8, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[12:06:00] Device 4 : Chirp 5 Configuration successful
[12:06:00] [RadarAPI]: ar1.ChirpConfig_mult(8, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[12:06:00] Device 4 : Chirp 6 Configuration successful
[12:06:00] [RadarAPI]: ar1.ChirpConfig_mult(8, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[12:06:00] Device 4 : Chirp 7 Configuration successful
[12:06:00] [RadarAPI]: ar1.ChirpConfig_mult(8, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[12:06:00] Device 4 : Chirp 8 Configuration successful
[12:06:00] [RadarAPI]: ar1.ChirpConfig_mult(8, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[12:06:00] Device 4 : Chirp 9 Configuration successful
[12:06:00] [RadarAPI]: ar1.ChirpConfig_mult(8, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[12:06:00] Device 4 : Chirp 10 Configuration successful
[12:06:00] [RadarAPI]: ar1.ChirpConfig_mult(8, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[12:06:00] Device 4 : Chirp 11 Configuration successful
[12:06:00] Test Source Already Disabled...!!!
[12:06:00] [RadarAPI]: ar1.DisableTestSource_mult(1,0)
[12:06:00] [RadarAPI]: ar1.FrameConfig_mult(1, 0, 11, 10, 64, 100, 0, 1)
[12:06:00] Master : Frame Configuration successful
[12:06:00] [RadarAPI]: ar1.DisableTestSource_mult(14,0)
[12:06:00] [RadarAPI]: ar1.FrameConfig_mult(14, 0, 11, 10, 64, 100, 0, 2)
[12:06:00] Slaves : Frame Configuration successful
[12:06:00]
[12:06:00] ***Script completed successfully.***
[12:06:02] Loops Remaining : 1
[12:06:02] Starting TDA ARM...
[12:06:02] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, Cascade_Capture_22xx, 0)
[12:06:02] Status: Failed. TDA ARM already done!
[12:06:02] TDA ARM Failed
[12:06:02]
[12:06:02] ***Script completed successfully.***
使用标准的lua脚本,突然就无法录制数据了。
检查SSD中adc录制是空的,剩余空间也存在,重新刷写SD卡镜像,格式化nvme0n1p1都没有任何效果。
