AWR1443BOOST: How can I transmit point cloud data from an AWR1443BOOST to a PC several hundred meters away?
Part Number: AWR1443BOOST
Hi,
    I’m using the TI AWR1443BOOST to generate point cloud data . By default, the board outputs this data over its USB-UART (XDS110) interface, which only supports reliable distances of a few meters. I would like to know how to send the real-time point cloud stream to a computer located several hundred meters away.
   Please advise on proven approaches, required converters or modules, and any example configurations or part numbers that have been used successfully in similar mmWave radar deployments.
Thank you!
