Part Number: TMUX7219
As above, when "SEL" was set, "s2" was connected to "D". Capacitor "C1" was charged from source "V2". At the beginning of charging, the cursh current would be very large. Would the device be damaged at this situation?
datasheet 给出了其不同封装、不同电压、不同环境温度下的连续电流,如下截图:
浪涌电流的话,我认为应该由其发热功率确定,看下下面FAQ是否对您有帮助:
[FAQ] More Frequently Asked Questions about signal switches and multiplexers 这里有一个计算EXCEL表格
[FAQ] Frequently Asked Questions - Switches & Multiplexers Forum
