Part Number: CD74HC4051
Sir,
When I use MCU, the PWM & analog I/O are not enough. Can I use CD74HC4051 for expansion? If not, are there other products that can achieve this effect? If so, can PWM & analog be implemented on the same CD74HC4051? ?
Sir,
Thank you for contacting TI China E2E forum and choosing our products as part of your solution.
Regarding your query, I will give you response in another case, I will close this duplicate case.
