在ccs中导入controlsuite的工程,遇到错误,提示如下:
See details below.
Error: Import failed for project 'IDDKv2_PM_Servo_F2837x_FCL_Example01' because its compiler definition is not available. Please install the C2000v16.12 compiler before importing this project - click 'View > CCS App Center' to check if compiler updates are available, or install the compiler manually and register it with CCS through 'Preferences > CCS > Build > Compilers'.
导入前需要先安装C2000v16.12 compiler,在www.ti.com/tool/C2000-CGT内只能找到C2000v16.9.11 compiler。如何解决这个问题?
