如何在CCS内嵌的sysconfig中刷新ti_config相关源文件和头文件?
存之后,.c/.h并没有相应更新,我如何刷新
您需要在保存之后,build工程才会有相应的改变
具体可以看一下
At project build time, the SysConfig build tool is invoked first (prior to the Compiler and Linker), and will generate source files in the project's Debug/syscfg directory (where Debug is the build configuration), as seen in the CCS build console.
