Part Number: CODECOMPOSER
Building file: "D:/CCS/C2000Ware_3_04_00_00_Software/device_support/f2833x/common/source/DSP2833x_ADC_cal.asm"
subdir_rules.mk:9: recipe for target 'DSP2833x_ADC_cal.obj' failed
'D:\env.bat' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
gmake: *** [DSP2833x_ADC_cal.obj] Error 1
Building file: "D:/CCS/C2000Ware_3_04_00_00_Software/device_support/f2833x/common/source/DSP2833x_Adc.c"
subdir_rules.mk:16: recipe for target 'DSP2833x_Adc.obj' failed
或批处理文件。
gmake: *** [DSP2833x_Adc.obj] Error 1
Building file: "D:/CCS/C2000Ware_3_04_00_00_Software/device_support/f2833x/common/source/DSP2833x_CodeStartBranch.asm"
subdir_rules.mk:23: recipe for target 'DSP2833x_CodeStartBranch.obj' failed
或批处理文件。
gmake: *** [DSP2833x_CodeStartBranch.obj] Error 1
Building file: "D:/CCS/C2000Ware_3_04_00_00_Software/device_support/f2833x/common/source/DSP2833x_DMA.c"
subdir_rules.mk:30: recipe for target 'DSP2833x_DMA.obj' failed
或批处理文件。
gmake: *** [DSP2833x_DMA.obj] Error 1
Building file: "D:/CCS/C2000Ware_3_04_00_00_Software/device_support/f2833x/common/source/DSP2833x_DefaultIsr.c"
subdir_rules.mk:37: recipe for target 'DSP2833x_DefaultIsr.obj' failed
或批处理文件。
gmake: *** [DSP2833x_DefaultIsr.obj] Error 1
Building file: "D:/CCS/C2000Ware_3_04_00_00_Software/device_support/f2833x/headers/source/DSP2833x_GlobalVariableDefs.c"
subdir_rules.mk:44: recipe for target 'DSP2833x_GlobalVariableDefs.obj' failed
或批处理文件。
Building file: "D:/CCS/C2000Ware_3_04_00_00_Software/device_support/f2833x/common/source/DSP2833x_PieCtrl.c"
subdir_rules.mk:51: recipe for target 'DSP2833x_PieCtrl.obj' failed
gmake: *** [DSP2833x_GlobalVariableDefs.obj] Error 1
或批处理文件。
gmake: *** [DSP2833x_PieCtrl.obj] Error 1
Building file: "D:/CCS/C2000Ware_3_04_00_00_Software/device_support/f2833x/common/source/DSP2833x_PieVect.c"
subdir_rules.mk:58: recipe for target 'DSP2833x_PieVect.obj' failed
或批处理文件。
gmake: *** [DSP2833x_PieVect.obj] Error 1
Building file: "D:/CCS/C2000Ware_3_04_00_00_Software/device_support/f2833x/common/source/DSP2833x_SysCtrl.c"
subdir_rules.mk:65: recipe for target 'DSP2833x_SysCtrl.obj' failed
或批处理文件。
gmake: *** [DSP2833x_SysCtrl.obj] Error 1
Building file: "D:/CCS/C2000Ware_3_04_00_00_Software/device_support/f2833x/common/source/DSP2833x_usDelay.asm"
subdir_rules.mk:72: recipe for target 'DSP2833x_usDelay.obj' failed
或批处理文件。
gmake: *** [DSP2833x_usDelay.obj] Error 1
Building file: "../Example_2833xAdcToDMA.c"
subdir_rules.mk:79: recipe for target 'Example_2833xAdcToDMA.obj' failed
或批处理文件。
gmake: *** [Example_2833xAdcToDMA.obj] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
还是不行,用的是C2000ware里面的例程
