Other Parts Discussed in Thread: CCSTUDIO
如题,如图,失败后,应用无法使用,尝试了很多次安装
我们现在发现msp430 pack 安装时有问题,但还没有找到解决的办法。
请问有问题的机器上是否安装了 WSL? 正在使用的 WINDOWS 版本是什么?
Log started 03/12/2022 at 16:04:04
Preferred installation mode : unattended
Trying to init installer in mode unattended
Mode unattended successfully initialized
[16:04:04] Error reading AppFolder property from C:/ti/ccs1110/ccs/eclipse/ccs.properties
[16:04:04] Using default AppFolder property Texas Instruments/Code Composer Studio
[16:04:04] eclipsedir = C:/ti/ccs1110/ccs/eclipse
这个错误可以忽略。 这不是安装失败的根本原因。
您能否提供此日志:ti_msp430pack11.1.0_install.log
可以~
Log started 02/26/2022 at 14:22:03
[14:22:03] Error reading AppFolder property from C:/ti/ccs1110/ccs/eclipse/ccs.properties
[14:22:03] Using default AppFolder property Texas Instruments/Code Composer Studio
[14:22:03] eclipsedir = C:/ti/ccs1110/ccs/eclipse
Preparing to Install
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers\TI_reg_ids
Unpacking files
Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers\msp430_emu.xml
Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers\TI_reg_ids\MSP430_regids.xml
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\DebugServer\drivers
Unpacking files
Unpacking C:\ti\ccs1110\ccs\ccs_base\DebugServer\drivers\MSP430.dll
Unpacking files
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\msp430
Unpacking files
Unpacking C:\ti\ccs1110\ccs\ccs_base\msp430\ReleaseNotes_MSP430_EmulatorsFiles.txt
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\DPInst
Unpacking files
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\DPInst\DPInst64.exe
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\DPInst\DPInst.exe
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections
Unpacking files
Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections\TIMSP430-USB.xml
Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections\TIMSP430-USB2.xml
Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections\TIMSP430-USB3.xml
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC
Unpacking files
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\msp430tools.inf
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\msp430tools.cat
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\USB_CDC_CERT.p7b
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\installCerts.bat
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF
Unpacking files
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\430CDC.inf
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\430cdc.cat
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\installCerts.bat
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\USB_eZ_RF.p7b
Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64
Unpacking files
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\WdfCoInstaller01009.dll
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\difxapi.dll
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\ump3410.cat
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\umpf3410.i51
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\umpusbvista.sys
Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\usbuart3410.inf
Unpacking files
Unpacking C:\ti\ccs1110\ccs\ccs_base\DebugServer\drivers\TI_Bug_Icon_Red.ico
Executing C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\USB_eZ-RF\installCerts.bat
Script exit code: 0
Script output:
C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF>C:\WINDOWS\system32\certutil -addstore -f "TrustedPublisher" "USB_eZ_RF.p7b"
TrustedPublisher "ÊÜÐÅÈεķ¢²¼Õß"
Ïà¹ØÖ¤Êé:
¾«È·Æ¥Åä:
ÔªËØ 10:
ÐòÁкÅ: 5200e5aa2556fc1a86ed96c9d44b33c7
°ä·¢Õß: CN=VeriSign Class 3 Public Primary Certification Authority - G5, OU=(c) 2006 VeriSign, Inc. - For authorized use only, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US
NotBefore: 2010/2/8 8:00
NotAfter: 2020/2/8 7:59
ʹÓÃÕß: CN=VeriSign Class 3 Code Signing 2010 CA, OU=Terms of use at https://www.verisign.com/rpa (c)10, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US
·Ç¸ùÖ¤Êé
Ö¤Êé¹þÏ£(sha1): 495847a93187cfb8c71f840cb7b41497ad95c64f
Ö¤Êé "VeriSign Class 3 Code Signing 2010 CA" ÒѾÔÚ´æ´¢ÖС£
Ç©ÃûÓ빫ԿƥÅä
Ïà¹ØÖ¤Êé:
¾«È·Æ¥Åä:
ÔªËØ 9:
ÐòÁкÅ: 18dad19e267de8bb4a2158cdcc6b3b4a
NotBefore: 2006/11/8 8:00
NotAfter: 2036/7/17 7:59
ʹÓÃÕß: CN=VeriSign Class 3 Public Primary Certification Authority - G5, OU=(c) 2006 VeriSign, Inc. - For authorized use only, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US
Ç©ÃûÓ빫ԿƥÅä
¸ùÖ¤Êé: ʹÓÃÕßÓë°ä·¢Õ߯¥Åä
Ö¤Êé¹þÏ£(sha1): 4eb6d578499b1ccf5f581ead56be3d9b6744a5e5
Ö¤Êé "VeriSign Class 3 Public Primary Certification Authority - G5" ÒѾÔÚ´æ´¢ÖС£
Ïà¹ØÖ¤Êé:
¾«È·Æ¥Åä:
ÔªËØ 0:
ÐòÁкÅ: 39ad63d2f5c9efdc46d734ae5e381b8f
°ä·¢Õß: CN=VeriSign Class 3 Code Signing 2010 CA, OU=Terms of use at https://www.verisign.com/rpa (c)10, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US
NotBefore: 2014/2/26 8:00
NotAfter: 2017/2/26 7:59
ʹÓÃÕß: CN=Texas Instruments Incorporated, OU=Digital ID Class 3 - Microsoft Software Validation v2, O=Texas Instruments Incorporated, L=Dallas, S=Texas, C=US
·Ç¸ùÖ¤Êé
Ö¤Êé¹þÏ£(sha1): ee0c8ba018ce926432c3cc23523a34073d01954a
Ö¤Êé "Texas Instruments Incorporated" ÒѾÔÚ´æ´¢ÖС£
CertUtil: -addstore ÃüÁî³É¹¦Íê³É¡£
Script stderr:
Executing C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\DPInst\DPinst64.exe /q /se /sa /lm /path "C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\USB_eZ-RF"
Script exit code: unknown signal
Script output:
Script stderr:
child killed: unknown signal
Error running C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\DPInst\DPinst64.exe /q /se /sa /lm /path "C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\USB_eZ-RF": child killed: unknown signal
[14:22:06] dpinst return code = unknown signal
Exiting with code -1
Log started 03/12/2022 at 16:12:16 Preferred installation mode : unattended Trying to init installer in mode unattended Mode unattended successfully initialized [16:12:16] Error reading AppFolder property from C:/ti/ccs1110/ccs/eclipse/ccs.properties [16:12:16] Using default AppFolder property Texas Instruments/Code Composer Studio [16:12:16] eclipsedir = C:/ti/ccs1110/ccs/eclipse Preparing to Install Preparing to Install Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers\TI_reg_ids Unpacking files Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers\msp430_emu.xml Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers\TI_reg_ids\MSP430_regids.xml Directory already exists: C:\ti\ccs1110\ccs\ccs_base\DebugServer\drivers Unpacking files Unpacking C:\ti\ccs1110\ccs\ccs_base\DebugServer\drivers\MSP430.dll Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers Unpacking files Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\drivers\msp430_emu.xml Directory already exists: C:\ti\ccs1110\ccs\ccs_base\msp430 Unpacking files Unpacking C:\ti\ccs1110\ccs\ccs_base\msp430\ReleaseNotes_MSP430_EmulatorsFiles.txt Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\DPInst Unpacking files Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\DPInst\DPInst64.exe Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\DPInst\DPInst.exe Directory already exists: C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections Unpacking files Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections\TIMSP430-USB.xml Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections\TIMSP430-USB2.xml Unpacking C:\ti\ccs1110\ccs\ccs_base\common\targetdb\connections\TIMSP430-USB3.xml Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC Unpacking files Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\msp430tools.inf Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\msp430tools.cat Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\USB_CDC_CERT.p7b Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_CDC\installCerts.bat Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF Unpacking files Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\430CDC.inf Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\430cdc.cat Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\installCerts.bat Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF\USB_eZ_RF.p7b Directory already exists: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64 Unpacking files Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\WdfCoInstaller01009.dll Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\difxapi.dll Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\ump3410.cat Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\umpf3410.i51 Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\umpusbvista.sys Unpacking C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_FET_Win7_8_10_64\usbuart3410.inf Directory already exists: C:\ti\ccs1110\ccs\ccs_base\DebugServer\drivers Unpacking files Unpacking C:\ti\ccs1110\ccs\ccs_base\DebugServer\drivers\TI_Bug_Icon_Red.ico Executing C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\USB_eZ-RF\installCerts.bat Script exit code: 0 Script output: C:\ti\ccs1110\ccs\ccs_base\emulation\drivers\msp430\USB_eZ-RF>C:\WINDOWS\system32\certutil -addstore -f "TrustedPublisher" "USB_eZ_RF.p7b" TrustedPublisher "ÊÜÐÅÈεķ¢²¼Õß" Ïà¹ØÖ¤Êé: ¾«È·Æ¥Åä: ÔªËØ 10: ÐòÁкÅ: 5200e5aa2556fc1a86ed96c9d44b33c7 °ä·¢Õß: CN=VeriSign Class 3 Public Primary Certification Authority - G5, OU=(c) 2006 VeriSign, Inc. - For authorized use only, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US NotBefore: 2010/2/8 8:00 NotAfter: 2020/2/8 7:59 ʹÓÃÕß: CN=VeriSign Class 3 Code Signing 2010 CA, OU=Terms of use at https://www.verisign.com/rpa (c)10, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US ·Ç¸ùÖ¤Êé Ö¤Êé¹þÏ£(sha1): 495847a93187cfb8c71f840cb7b41497ad95c64f Ö¤Êé "VeriSign Class 3 Code Signing 2010 CA" ÒѾÔÚ´æ´¢ÖС£ Ç©ÃûÓ빫ԿƥÅä Ïà¹ØÖ¤Êé: ¾«È·Æ¥Åä: ÔªËØ 9: ÐòÁкÅ: 18dad19e267de8bb4a2158cdcc6b3b4a °ä·¢Õß: CN=VeriSign Class 3 Public Primary Certification Authority - G5, OU=(c) 2006 VeriSign, Inc. - For authorized use only, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US NotBefore: 2006/11/8 8:00 NotAfter: 2036/7/17 7:59 ʹÓÃÕß: CN=VeriSign Class 3 Public Primary Certification Authority - G5, OU=(c) 2006 VeriSign, Inc. - For authorized use only, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US Ç©ÃûÓ빫ԿƥÅä ¸ùÖ¤Êé: ʹÓÃÕßÓë°ä·¢Õ߯¥Åä Ö¤Êé¹þÏ£(sha1): 4eb6d578499b1ccf5f581ead56be3d9b6744a5e5 Ö¤Êé "VeriSign Class 3 Public Primary Certification Authority - G5" ÒѾÔÚ´æ´¢ÖС£ Ïà¹ØÖ¤Êé: ¾«È·Æ¥Åä: ÔªËØ 0: ÐòÁкÅ: 39ad63d2f5c9efdc46d734ae5e381b8f °ä·¢Õß: CN=VeriSign Class 3 Code Signing 2010 CA, OU=Terms of use at https://www.verisign.com/rpa (c)10, OU=VeriSign Trust Network, O=VeriSign, Inc., C=US NotBefore: 2014/2/26 8:00 NotAfter: 2017/2/26 7:59 ʹÓÃÕß: CN=Texas Instruments Incorporated, OU=Digital ID Class 3 - Microsoft Software Validation v2, O=Texas Instruments Incorporated, L=Dallas, S=Texas, C=US ·Ç¸ùÖ¤Êé Ö¤Êé¹þÏ£(sha1): ee0c8ba018ce926432c3cc23523a34073d01954a Ö¤Êé "Texas Instruments Incorporated" ÒѾÔÚ´æ´¢ÖС£ CertUtil: -addstore ÃüÁî³É¹¦Íê³É¡£ Script stderr: Executing C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\DPInst\DPinst64.exe /q /se /sa /lm /path "C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\USB_eZ-RF" Script exit code: unknown signal Script output: Script stderr: child killed: unknown signal Error running C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\DPInst\DPinst64.exe /q /se /sa /lm /path "C:\ti\ccs1110/ccs/ccs_base\emulation\drivers\msp430\USB_eZ-RF": child killed: unknown signal [16:12:19] dpinst return code = unknown signal Exiting with code -1
请下载:
https://software-dl.ti.com/ccs/non-esd/misc/ccs1110msp.zip
并将 zip 内容(“extract here”)解压缩到所需位置(例如:“C:\ti”)。
要启动 CCS,请在以下位置运行以下可执行文件(假设您在 C:\ti 中提取 zip):
C:\ti\ccs1110msp\ccs\eclipse\ccstudio.exe
另外请尝试启动debug session。 如果您遇到有关驱动程序的问题,则可能需要额外的步骤。
