Other Parts Discussed in Thread: CCSTUDIO
在win10系统安装CCS6.2,提示失败,杀毒软件已经关闭。log文件和失败提示如下:
11/15/2022 02:49:15(GMT) - InstallBins - cmd = "D:/ccsv6/eclipse/downloads/sd_emupack_setup_5.2.0.14.exe" --mode silent --prefix "D:/ccsv6/ccs_base" /noc2400 /noc5400 /noomap /nodavinci
11/15/2022 02:49:15(GMT) - InstallBins - CCS_INFO: Installing com.sd.ccstudio.emulation.win32
11/15/2022 02:49:43(GMT) - InstallBins - Return Code: SIGSEGV com.sd.ccstudio.emulation.win32
11/15/2022 02:49:43(GMT) - InstallBins - CCS_INFO: error message: child killed: segmentation violation
11/15/2022 02:49:54(GMT) - InstallBins - CCS_INFO: Installing com.sd.ccstudio.emulation.win32
11/15/2022 02:50:19(GMT) - InstallBins - Return Code: SIGSEGV com.sd.ccstudio.emulation.win32
11/15/2022 02:50:19(GMT) - InstallBins - CCS_INFO: error message: child killed: segmentation violation
11/15/2022 02:50:30(GMT) - InstallBins - CCS_INFO: Installing com.sd.ccstudio.emulation.win32
11/15/2022 02:50:55(GMT) - InstallBins - Return Code: SIGSEGV com.sd.ccstudio.emulation.win32
11/15/2022 02:50:55(GMT) - InstallBins - CCS_INFO: error message: child killed: segmentation violation
11/15/2022 02:50:56(GMT) - processOtherFeatures - CCS_INFO: Finished installing binary sd_emupack_setup_5.2.0.14.exe
11/15/2022 02:50:56(GMT) - processOtherFeatures - CCS_INFO: Deleting binary D:/ccsv6/eclipse/downloads/sd_emupack_setup_5.2.0.14.exe
11/15/2022 02:50:56(GMT) - processOtherFeatures - new state: install failed
11/15/2022 02:50:56(GMT) - checkStatus - CCS_ERROR: Installer failed to install com.sd.ccstudio.emulation.win32 correctly. The 2 most common reasons for failure are:
1. Anti-virus on your computer could have impeded the executable.
2. Download is corrupted.
Please submit these logs to TI for analysis using the next dialog.
You may also visit the TI E2E CCS Support forum for additional help.
The install logs are located in: D:/ccsv6/install_logs/20221115112613.
11/15/2022 02:50:56(GMT) - checkStatus - file does not exist D:/Users/huamr/AppData/Local/Temp/ccs_56d4c6e3-76c7-45b9-6043-53253660c027/eclipse/ws/.metadata/.log
11/15/2022 02:51:00(GMT) - checkStatus - saving D:/ccsv6/install_logs
11/15/2022 02:51:04(GMT) - checkStatus - CCS_ERROR: Code Composer Studio v6 installation failed.
