msp432p401r
NTERNAL ERROR: C:/ti/ccs1220/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl had an internal inconsistency and aborted
while processing file ../CG_Control.c
This is caused by a defect in the TI C/C++ Compiler.
TI Customer Support may be able to suggest a workaround to avoid this.
Upgrading to the newest version of the compiler may fix this problem.
Contact TI in the E2E support forums at http://e2e.ti.com under
"Development Tools", "TI C/C++ Compiler". See the link titled
"Submitting an issue".
We need to see this ENTIRE error message and a complete, reproducible
test case including ALL of the command-line options.
gmake: *** [CG_Control.obj] Error 2
gmake: Target 'all' not remade because of errors.
