DLP-3P-SEARCH: Question on DLP9500 Diffraction Efficiency Data vs. DMD_Diffraction_Efficiency_Calculator (UV Application)
Part Number: DLP-3P-SEARCH
Other Parts Discussed in Thread: DLP9500
Dear IT Engineer,
I am an optical design engineer, and we are currently performing system-level efficiency calculations. I would like to ask whether the diffraction efficiency value in the DLP9500 datasheet is the same as the value calculated using the DMD_Diffraction_Efficiency_Calculator. If we are working in the UV wavelength range, does it mean we should use the results from the DMD_Diffraction_Efficiency_Calculator instead of the values provided in the datasheet to calculate efficiency?
