I would like to know if TI has a current acquisition module with an acquisition range of 0.1uA-50mA, and he can transmit the acquired data to the MCU through the serial port
Hello,here are a couple Precision Designs that will give you an idea of how it may be accomplished:
TIPD135: This TIPD uses the PGA281 on the high-side to sense 4 decades of load current (10uA-100mA). It is supplied with +/-15V.
https://www.ti.com/tool/TIPD135
TIPD104: This TIPD uses the INA326 on the low side. There is a switch that changes the gain of the device once, which allows for the sensing of 3 decades of load current. Please note that this Precision Design was only simulated.
https://www.ti.com/tool/TIPD104
