Part Number: PSPICE-FOR-TI
21:00:24 2023年2月22日 : parameter count = 1
21:00:24 2023年2月22日 : -wrapper
21:00:24 2023年2月22日 : Module Name: TIPSpice.exe
21:00:24 2023年2月22日 : Server OS = False
21:00:24 2023年2月22日 : Operating system version : 10.0.0.0
21:00:24 2023年2月22日 : Checking for proxy
21:00:25 2023年2月22日 : {
"LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip",
"LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt",
"LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json",
"LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json",
"LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json",
"LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip",
"LibFirstInstall_LatestVersion": "17.40.006",
"Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml",
"Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer",
"Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe",
"Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1",
"SoftwareUpdate_Expiry": {
"Timestamp": "01:15:2099 15:07:19 GMT",
"RegularMessage": {
"PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ",
"HyperLink": "license agreement",
"PostHyperLink": "."
"ForceMessage": {
"PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the",
"PostHyperLink": ". Click Cancel to exit."
"UTM_Keyword": {
"TIPSpice_Install": "HQS=pspiceforti",
"Full_Install": "HQS=pspiceforti"
"TI_URLs_Version": [
"17_4_2020_S006"
21:00:25 2023年2月22日 : Checking if Licensing URL is accessible
21:00:41 2023年2月22日 : Error Message: 操作超时
21:00:41 2023年2月22日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
URL: https://cdsplicwc.cadence.com/chws/test/connection.html
Error Description: 操作超时
View log file for details at C:\Users\86138\AppData\Roaming\Cadence\PspiceTIInstall\cdsPspiceTIlog.txt
21:01:08 2023年2月22日 : parameter count = 1
21:01:08 2023年2月22日 : -wrapper
21:01:08 2023年2月22日 : Module Name: TIPSpice.exe
21:01:08 2023年2月22日 : Server OS = False
21:01:08 2023年2月22日 : Operating system version : 10.0.0.0
21:01:08 2023年2月22日 : Checking for proxy
21:01:09 2023年2月22日 : {
"RegularMessage": {
"ForceMessage": {
"UTM_Keyword": {
"17_4_2020_S006"
21:01:09 2023年2月22日 : Checking if Licensing URL is accessible
21:01:24 2023年2月22日 : Error Message: 操作超时
21:01:24 2023年2月22日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
21:09:44 2023年2月22日 : parameter count = 1
21:09:44 2023年2月22日 : -wrapper
21:09:44 2023年2月22日 : Module Name: TIPSpice.exe
21:09:44 2023年2月22日 : Server OS = False
21:09:44 2023年2月22日 : Operating system version : 10.0.0.0
21:09:44 2023年2月22日 : Checking for proxy
21:09:44 2023年2月22日 : {
"RegularMessage": {
"ForceMessage": {
"UTM_Keyword": {
"17_4_2020_S006"
21:09:44 2023年2月22日 : Checking if Licensing URL is accessible
21:10:00 2023年2月22日 : Error Message: 操作超时
21:10:00 2023年2月22日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
21:19:58 2023年2月22日 : parameter count = 1
21:19:58 2023年2月22日 : -wrapper
21:19:58 2023年2月22日 : Module Name: TIPSpice.exe
21:19:58 2023年2月22日 : Server OS = False
21:19:58 2023年2月22日 : Operating system version : 10.0.0.0
21:19:58 2023年2月22日 : Checking for proxy
21:19:58 2023年2月22日 : {
"RegularMessage": {
"ForceMessage": {
"UTM_Keyword": {
"17_4_2020_S006"
21:19:58 2023年2月22日 : Checking if Licensing URL is accessible
21:20:14 2023年2月22日 : Error Message: 操作超时
21:20:14 2023年2月22日 : Message: Unable to access the URL required for installation. Check if URL is accessible and then try again.
