Hi all,
I have a question about a Pspice statement 'EHYS INP1 INP2 VALUE { IF( V(1) > {VTHRESH},-V(HYS),0) }', which is found in the Pspice model, lmg1020.lib. I have known that E is represent a VCVS, which has 4 pins. However, there are only 2 pins represented by statement in 'EHYS INP1 INP2 VALUE { IF( V(1) > {VTHRESH},-V(HYS),0) }'. So how should I understand this? Please let me konw if you have any answer. Or maybe you will draw a diagram about this VCVS? Thank you for your time.
