安装时候卡在配置库这里不动了。
安装log如下:
11:30:03 2024年1月19日 : parameter count = 1
11:30:03 2024年1月19日 : -wrapper
11:30:03 2024年1月19日 : Module Name: TIPSpice.exe
11:30:03 2024年1月19日 : Server OS = False
11:30:03 2024年1月19日 : Operating system version : 10.0.0.0
11:30:03 2024年1月19日 : Checking for proxy
11:30:03 2024年1月19日 : {
"LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip",
"LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt",
"LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json",
"LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json",
"LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json",
"LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip",
"LibFirstInstall_LatestVersion": "23.10.001",
"Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml",
"Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer",
"Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe",
"Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1",
"SoftwareUpdate_Expiry": {
"Timestamp": "01:15:2099 15:07:19 GMT",
"RegularMessage": {
"PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ",
"HyperLink": "license agreement",
"PostHyperLink": "."
"ForceMessage": {
"PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the",
"PostHyperLink": ". Click Cancel to exit."
"UTM_Keyword": {
"TIPSpice_Install": "HQS=pspiceforti",
"Full_Install": "HQS=pspiceforti"
"TI_URLs_Version": [
"17_4_2020_S006",
"17_4_2020_S009",
"23_1_2024_P001"
11:30:03 2024年1月19日 : Checking if Licensing URL is accessible
11:30:04 2024年1月19日 : Initializing
11:30:04 2024年1月19日 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
11:30:04 2024年1月19日 : Response Content length = 1766
11:30:04 2024年1月19日 : C:\Users\58281\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
11:30:04 2024年1月19日 : Reading Json URL File
11:30:04 2024年1月19日 : setting media download server URL from Json File
11:30:04 2024年1月19日 : setting Dll path from Json File
11:30:04 2024年1月19日 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
11:30:04 2024年1月19日 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
11:30:05 2024年1月19日 : ReleaseVersion in XML: 17.40.009 InstalledVersion on system:
11:30:05 2024年1月19日 : LaunchTIPSpiceDlgs()
11:30:05 2024年1月19日 : Checking for compnts.dat
11:30:51 2024年1月19日 : error_code cdsVblRegisterInstallation: VblSuccess
11:30:52 2024年1月19日 : error_code cdsVblRequestLicense: VblSuccess
11:31:01 2024年1月19日 : Set Installation and Home Directory()
11:31:01 2024年1月19日 : Setting default Installation directory : C:\Cadence\PSpiceTI
11:31:01 2024年1月19日 : Reading CDS_HOME environment variable
11:31:01 2024年1月19日 : CDS_HOME is not present or is empty. Need to set CDS_HOME.
11:31:01 2024年1月19日 : First time installation. CDS_HOME will be set to default HOME directory.
11:31:01 2024年1月19日 : Checking if CDS_HOME directory exists and whether user has permission to create it.
11:31:01 2024年1月19日 : Creating directory : C:\cds_spb_home
11:31:18 2024年1月19日 : Checking for memory space
11:31:18 2024年1月19日 : Memory space available
11:31:18 2024年1月19日 : Target Dir: D:\Cadence\PSpiceTI
11:31:18 2024年1月19日 : Working Dir: C:\cds_spb_home
11:31:18 2024年1月19日 : Silent ini file created
11:31:21 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
11:31:21 2024年1月19日 : Starting download of 0x0409.ini Attempt no 1 DataSize is 22480
11:31:21 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
11:31:21 2024年1月19日 : Completing download of 0x0409.ini
11:31:22 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
11:31:22 2024年1月19日 : Starting download of data1.cab Attempt no 1 DataSize is 31794546
11:31:23 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
11:31:24 2024年1月19日 : Completing download of data1.cab
11:31:25 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
11:31:25 2024年1月19日 : Starting download of data2.cab Attempt no 1 DataSize is 170127360
11:31:27 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
11:31:27 2024年1月19日 : Starting download of data1.hdr Attempt no 1 DataSize is 5038454
11:31:27 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
11:31:27 2024年1月19日 : Completing download of data1.hdr
11:31:29 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
11:31:29 2024年1月19日 : Starting download of data3.cab Attempt no 1 DataSize is 209715200
11:31:33 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
11:31:34 2024年1月19日 : Completing download of data2.cab
11:31:36 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
11:31:36 2024年1月19日 : Starting download of data4.cab Attempt no 1 DataSize is 209715200
11:31:41 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
11:31:42 2024年1月19日 : Completing download of data3.cab
11:31:44 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
11:31:44 2024年1月19日 : Starting download of data5.cab Attempt no 1 DataSize is 209715200
11:31:48 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
11:31:48 2024年1月19日 : Completing download of data4.cab
11:31:52 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
11:31:52 2024年1月19日 : Starting download of data6.cab Attempt no 1 DataSize is 209715200
11:31:53 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
11:31:53 2024年1月19日 : Completing download of data5.cab
11:31:56 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
11:31:56 2024年1月19日 : Starting download of data7.cab Attempt no 1 DataSize is 209715200
11:32:03 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
11:32:03 2024年1月19日 : Completing download of data6.cab
11:32:07 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
11:32:08 2024年1月19日 : Completing download of data7.cab
11:32:10 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
11:32:10 2024年1月19日 : Starting download of data8.cab Attempt no 1 DataSize is 209715200
11:32:11 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
11:32:11 2024年1月19日 : Starting download of data9.cab Attempt no 1 DataSize is 83923568
11:32:16 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
11:32:17 2024年1月19日 : Completing download of data9.cab
11:32:19 2024年1月19日 : 解密操作失败,请参见内部异常。
11:32:19 2024年1月19日 : An exception occured when downloading file : https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
11:32:19 2024年1月19日 : Deleting partially downloaded file: data8.cab of Size 189720430
11:32:21 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
11:32:21 2024年1月19日 : Starting download of installsetup.exe Attempt no 1 DataSize is 954488
11:32:21 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
11:32:21 2024年1月19日 : Completing download of installsetup.exe
11:32:24 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
11:32:24 2024年1月19日 : Starting download of ISSetup.dll Attempt no 1 DataSize is 1637496
11:32:24 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
11:32:24 2024年1月19日 : Completing download of ISSetup.dll
11:32:28 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
11:32:28 2024年1月19日 : Starting download of data8.cab Attempt no 2 DataSize is 209715200
11:32:30 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
11:32:30 2024年1月19日 : Starting download of layout.bin Attempt no 1 DataSize is 994
11:32:30 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
11:32:30 2024年1月19日 : Completing download of layout.bin
11:32:33 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
11:32:33 2024年1月19日 : Starting download of pspInstall.pdf Attempt no 1 DataSize is 85357
11:32:33 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
11:32:33 2024年1月19日 : Completing download of pspInstall.pdf
11:32:38 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
11:32:38 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
11:32:38 2024年1月19日 : Starting download of setup.bmp Attempt no 1 DataSize is 414056
11:32:38 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
11:32:38 2024年1月19日 : Completing download of setup.bmp
11:32:39 2024年1月19日 : Completing download of data8.cab
11:32:41 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
11:32:41 2024年1月19日 : Starting download of setup.ini Attempt no 1 DataSize is 2430
11:32:41 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
11:32:41 2024年1月19日 : Completing download of setup.ini
11:32:42 2024年1月19日 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
11:32:42 2024年1月19日 : Starting download of setup.inx Attempt no 1 DataSize is 575660
11:32:42 2024年1月19日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
11:32:42 2024年1月19日 : Completing download of setup.inx
11:32:42 2024年1月19日 : 1703998 1703998
11:32:42 2024年1月19日 : Setup exe path: D:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
11:32:42 2024年1月19日 : Allegro Installation Start pid: 33920
11:32:49 2024年1月19日 : NumberOfComponentsToBeInstalled = 40106
11:32:49 2024年1月19日 : Updated NumberOfComponentsToBeInstalled = 40913.08
11:32:49 2024年1月19日 : Updated NumberOfComponentsInstalled = 402
11:35:19 2024年1月19日 : Feature transfer complete..disabling close button
11:35:19 2024年1月19日 : Installing: Runtime packages and redistributables
11:35:40 2024年1月19日 : Installing: Configuring documentation
11:35:44 2024年1月19日 : Installing: Configuring file associations
11:35:45 2024年1月19日 : Installing: Setting permissions for files and folders
11:37:45 2024年1月19日 : Installing: Creating Registries
11:37:45 2024年1月19日 : Installing: SQL Lite ODBC Driver
11:37:49 2024年1月19日 : Installing: Finishing Installation
11:38:05 2024年1月19日 : Running Library Configuration Executable
11:38:05 2024年1月19日 : Starting process: D:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
13:11:42 2024年1月19日 : Exiting Installation Installing Dialog
13:11:42 2024年1月19日 : An exception occured which is causing the program to close.
13:11:42 2024年1月19日 : Details of exception are : 配额不足,无法处理此命令。
13:11:42 2024年1月19日 : Stack Trace for the exception is 在 MS.Win32.ManagedWndProcTracker.HookUpDefWindowProc(IntPtr hwnd)
在 MS.Win32.ManagedWndProcTracker.OnAppDomainProcessExit()
在 MS.Internal.ShutDownListener.HandleShutDown(Object sender, EventArgs e)
13:11:42 2024年1月19日 : Message: An error occurred and PSpice for TI needs to close.
Refer to cdsPspiceTIlog.txt at C:\Users\58281\AppData\Roaming\Cadence\PspiceTIInstall for error details.
15:43:33 2024年2月2日 : parameter count = 1
15:43:33 2024年2月2日 : -wrapper
15:43:33 2024年2月2日 : Module Name: TIPSpice.exe
15:43:33 2024年2月2日 : Server OS = False
15:43:33 2024年2月2日 : Operating system version : 10.0.0.0
15:43:33 2024年2月2日 : Checking for proxy
15:43:33 2024年2月2日 : {
"RegularMessage": {
"ForceMessage": {
"UTM_Keyword": {
"17_4_2020_S006",
"17_4_2020_S009",
"23_1_2024_S001"
15:43:33 2024年2月2日 : Checking if Licensing URL is accessible
15:43:34 2024年2月2日 : Initializing
15:43:34 2024年2月2日 : Deleting file : C:\Users\58281\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt
15:43:34 2024年2月2日 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
15:43:34 2024年2月2日 : Response Content length = 1766
15:43:34 2024年2月2日 : C:\Users\58281\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
15:43:34 2024年2月2日 : Reading Json URL File
15:43:34 2024年2月2日 : setting media download server URL from Json File
15:43:34 2024年2月2日 : setting Dll path from Json File
15:43:34 2024年2月2日 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
15:43:34 2024年2月2日 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
15:43:35 2024年2月2日 : ReleaseVersion in XML: 17.40.009 InstalledVersion on system: 17.40.009
15:43:35 2024年2月2日 : Repair mode
15:43:35 2024年2月2日 : Check if CDS_HOME is set
15:43:35 2024年2月2日 : Product is already installed. Current value of CDS_HOME = C:\cds_spb_home
15:43:37 2024年2月2日 : ReleaseVersion in XML: 17.40.009 InstalledVersion on system: 17.40.009
15:43:37 2024年2月2日 : LaunchTIPSpiceDlgs()
15:43:37 2024年2月2日 : Checking for compnts.dat
15:46:50 2024年2月2日 : error_code cdsVblRegisterInstallation: VblSuccess
15:46:50 2024年2月2日 : error_code cdsVblRequestLicense: VblSuccess
15:46:57 2024年2月2日 : Set Installation and Home Directory()
15:47:02 2024年2月2日 : Checking for memory space
15:47:02 2024年2月2日 : Memory space available
15:47:02 2024年2月2日 : Target Dir: D:\Cadence\PSpiceTI
15:47:02 2024年2月2日 : Working Dir: C:\cds_spb_home
15:47:02 2024年2月2日 : Silent ini file created
15:47:03 2024年2月2日 : Skipping download of 0x0409.ini DataSize is 22480
15:47:03 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
15:47:03 2024年2月2日 : Skipping download of data1.hdr DataSize is 5038454
15:47:03 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
15:47:03 2024年2月2日 : Skipping download of data1.cab DataSize is 31794546
15:47:03 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
15:47:03 2024年2月2日 : Skipping download of data2.cab DataSize is 170127360
15:47:03 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
15:47:03 2024年2月2日 : Skipping download of data3.cab DataSize is 209715200
15:47:03 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
15:47:03 2024年2月2日 : Skipping download of data4.cab DataSize is 209715200
15:47:03 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
15:47:04 2024年2月2日 : Skipping download of data5.cab DataSize is 209715200
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
15:47:04 2024年2月2日 : Skipping download of data6.cab DataSize is 209715200
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
15:47:04 2024年2月2日 : Skipping download of data7.cab DataSize is 209715200
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
15:47:04 2024年2月2日 : Skipping download of data9.cab DataSize is 83923568
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
15:47:04 2024年2月2日 : Skipping download of installsetup.exe DataSize is 954488
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
15:47:04 2024年2月2日 : Skipping download of ISSetup.dll DataSize is 1637496
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
15:47:04 2024年2月2日 : Skipping download of layout.bin DataSize is 994
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
15:47:04 2024年2月2日 : Skipping download of pspInstall.pdf DataSize is 85357
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
15:47:04 2024年2月2日 : Skipping download of setup.bmp DataSize is 414056
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
15:47:04 2024年2月2日 : Skipping download of setup.ini DataSize is 2430
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
15:47:04 2024年2月2日 : Skipping download of setup.inx DataSize is 575660
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
15:47:04 2024年2月2日 : 465510 465510
15:47:04 2024年2月2日 : Setup exe path: D:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
15:47:04 2024年2月2日 : Skipping download of data8.cab DataSize is 209715200
15:47:04 2024年2月2日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
15:47:05 2024年2月2日 : Allegro Installation Start pid: 11272
15:47:13 2024年2月2日 : NumberOfComponentsToBeInstalled = 40106
15:47:13 2024年2月2日 : Updated NumberOfComponentsToBeInstalled = 40913.08
15:47:13 2024年2月2日 : Updated NumberOfComponentsInstalled = 402
15:50:42 2024年2月2日 : Feature transfer complete..disabling close button
15:50:42 2024年2月2日 : Installing: Runtime packages and redistributables
15:51:08 2024年2月2日 : Installing: Configuring documentation
15:51:13 2024年2月2日 : Installing: Configuring file associations
15:51:15 2024年2月2日 : Installing: Setting permissions for files and folders
15:51:50 2024年2月2日 : Installing: Creating Registries
15:51:50 2024年2月2日 : Installing: SQL Lite ODBC Driver
15:51:56 2024年2月2日 : Installing: Finishing Installation
15:52:13 2024年2月2日 : Running Library Configuration Executable
15:52:13 2024年2月2日 : Starting process: D:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
网络状态如下:
The PSpice for TI installer accesses the internet to download and install various packages. Before starting the installer, ensure the following: 1. Internet connection is available 2. Security protocol TLS 1.2 is enabled 3. Following endpoints or resource locations are accessible from the system: a. https://pcb.cadence.com/startPages b. https://software-dl.ti.com/pspice c. https://cdsplicwc.cadence.com/chws If proxy credentials are required to access the Internet, provide the same when requested by the installer. 15:43:33 2024年2月2日 : *****CONNECTION STATUS CHECK***** 15:43:33 2024年2月2日 : Internet Connection : Available (Passed) 15:43:33 2024年2月2日 : Security Protocol TLS 1.2: Available. If PSpice for TI installation fails, unblock TLS 1.2 15:43:33 2024年2月2日 : Proxy Test : Proxy Credentials not needed
