Part Number: LM5045
LM5045 Full-Bridge PWM Controller With Integrated MOSFET Drivers,want to use it at half circuit. just use LO1 and LO2 into drive IC's LI and HI,then drive IC relieve the drive signals to the upper Mosfet and the lower
mosfet? how to deal with 5045 other upper drive signal(HS1、HO1、BST1 & HS2、HO2、BST2)? thanks!
LM5045 全桥控制芯片,想用于半桥电路,LO1和LO2 直接接驱动芯片的HI和LI管脚,驱动芯片再发出驱动信号驱动半桥电路的上管和下管。5045 其他驱动信号(HS1、HO1、BST1 & HS2、HO2、BST2)怎么处理?谢谢!
