hello ,I found that there are only two Signal Cable in the xpr on my DLPC4420AEVM development board. If it has 4K pixel function, do we need other wiring ports? Which specific wires are there? thank you
Hi,
What's the DMD EVM you have to work with DLPC4420AEVM? Can you please point out what these two signal cables you are referring to?
